Question about Garden
I have changed the oil in my Husqvarna YTH2454 lawn tractor and the display on the hour meter still shows "change oil" how can you make this go away?
    President:
  • 3,074 Answers
It will take one to two hours of run time and it will clear, Hope this helped Tim
Posted on May 22, 2011
How to change belt on 54inch cut husqvarna lawn tractor model yth2454
Which belt? The cutting deck belt or the belt which drives the mower?
Jul 07, 2014 | Husqvarna YTH2454 54in 25 HP Lawn Tractor
White smoke is coming out of exhaust of husqvarna yth2454
smell the oil and if it smells like gas you have a bad seal on the needle valve in the carb and gas overflows into the crankcase change the needle and seat change the oil and if possible add a fuel shut of valve and close it when not in use
Jun 24, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
No power to husqvarna carb solenoid
Ignition switch, or wireing issue, out with the multi meter to find where the power has been lost.
May 06, 2012 | Husqvarna YTH2454 54in 25 HP Lawn Tractor
What does the hour meter on my mower actually tell me? It is flashing between hours of usage and chg oil. I changed oil and filter about four running hours ago. I cut grass for a few hours and then...
Hi, the meter flashes oil change when they are due(at pre-programed intervals) and will stop flashing two running hours after flashing starts. The hours that are showing are total running hours from new. Hope this helps, regards Phil.
May 31, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Describe your Troubleshooting Husqvarna YTH2454 Problem The tractor will not move forward or backward. Any idea what the problem might be?
Check to see if your drive belt has slipped off the pulley assembly, or if you have broken a pulley or the belt itself broke.
May 08, 2011 | Husqvarna Lawn Tractor  25 HP 54in Deck...
I changed the oil in my Craftsman Lawn Tractor 24HP Model No 917-288320 and the "change oil" message on the LED screen won't go away. Is there a reset button somewhere?
Below is excerpt from the owners manual:
SERVICE REMINDER/HOUR METER
Service reminder shows the total number
of hours the engine has run and flashes to
indicate that the engine or mower needs
servicing. When service is required, the
service reminder will flash for two hours.
To service engine and mower, see the
Maintenance section of this manual.
NOTE: Service reminder runs when the ignition
key is in any position but "STOP". For
accurate reading, be sure key remains in the
"STOP" position when engine is not running.
It should reset the 2 hours has expired
Jan 16, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do i reset the change oil light on a 1040 cub cadet 1000 series
The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display. The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time. "CHG"/"OIL"/TIME will alternate on the display for five(5) minutes after the meter reaches 50 hours. The display will also flash as described above for five(5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two(2) hours ( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...). While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five(5) minutes. The meter display will return to normal function automatically after the reminder maintenance time interval of two(2) hours.There is no method of manually re-setting this Service Monitor gauge.
Aug 30, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Ch6 Oil code
Hello, W/D here.
What you are actually getting is Chg Oil (change oil). This is preprogrammed in, as a reminder for you to service the engine. It will go back to the hour meter mode after about 1 hour of additional runtime. If you have changed your oil and filter, there is nothing else to do. The oil and filter need to be changed regularly. If the oil breaks down in your engine, it will lose it's lubricating properties and the engine will seize up.
Best regards, --W/D--
Aug 20, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Error on display
This is a oil change code, telling you it's time to change the oil. It takes up to 3 running hours to reset and will do so automatically. There is no manual reset. If you've changed the oil & filter, you're all set. Thanks for your question, and please let us know the outcome by rating this solution.  Papa.
Sep 14, 2008 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Garden Logo
177 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
