Question about Asko TLS752XXL Dryer
Brand new ASko T752, H7 error code, no heat, gas supply is fine. Other Asko dryers have a reset button, this one does not, at least not visible on the back. What else could it be?
2 Suggested Answers
KevinWhite
  • 1902 Answers
SOURCE: brand new ASko T752, H7
Hello & Welcome to FixYa
H7 error in your Asko Dryer means that there is a problem with gas valve, either the valve is blocked or the gas supply is not fine. Check your gas supply at the connection of the gas hoses and the valves. If you have already checked all this then use warranty and get the valve replaced. Please get back to me if you have any other questions.
Kevin
Posted on May 22, 2011
Can I get a list of error messages for an ASKO TL751 clothes dryer?
I googled: Asko TL751 Electric Dryer Error code HI
You may find a manual in this search that gives you the code
If I had to guess it means the high heat is not working, or the high
temperature protection has opened to protect the dryer from
self distruction.
Your owner's manual should give the error codes.
No manual? manualslib.com may have it. YOu may want it next time anyway.
Mar 31, 2015 | Asko TL751 Electric Dryer
ASKO TL751 error messages ?
Asko dryers as model T760 or T780 indicate failure by error message (like "Overflow", "Sensor", "Thermistor", ...) while the model TL751 indicate failure by error code ("H1", "H2", ...)
Below you can see a list of error codes:
H1 error - Humidity sensor error
H2 error - Drying temperature sensor open/short error
H5 error - Heater overheated (ELECTRIC TYPE)
Heater disconnection check and H4/H6 error (ELECTRIC TYPE)
H3 Error - Flame Detector Open Defect (Gas Type)
H7 Error - Gas Valve Defect or Gas Blocked-off (Gas Type)
H8 Error - Igniter Defect or Flame Detector Short (Gas Type)
Dado
Getting smell of gas & H7 alarm on 2-week old asko dryer...any thoughts on why? Thanks.....Eric
DISSCONNECT ALL ELECTRICAL POWER from unit before doing ANYTHING ELSE!!!!! Check all Gas connections IMMEDIATELLY!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Be certain non have come loose due to vibration during operation (check and retighten all fittings associated with this device). Should all gas connections be found properly connected & tight, refer to owners manual regarding pilot light. If pilot light has gone out, gas smell will be sensed in the area of appliance, even when NOT turned on! Should pilot be found to be lit..... all connection determined to be connected properly & tight..... IMMEDIATE action should be taken to shut gas supplying appliance OFF !!!!!!!!!!! Contact Professional Service Representative at earliest convenience !!!!!!! DO NOT APPLY GAS PRESSURE TO UNIT TILL ISSUE IS RESOLVED!!!!!!!! GAS CAN BE EXTREMELLY DANGEROUS and EVERY CAUTION SHOULD BE OBSERVED WHEN WORKING IN THE AREA to PROPERLY VENTILATE to open air source. DO NOT ALLOW VAPORS TO ACCUMULATE & AVOID ALL SPARKES & OPEN FLAMES !!!!!!
May 14, 2011 | Asko TLS752XXL Dryer
ASKO T760 has no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 31, 2010 | Asko T761 Electric Dryer
Not heating runs finer
on most asko dryers you should find a reset button it is found on the back of the unit have a look for it in your user guide u mite find it in there
Oct 29, 2009 | Asko T721 Electric Dryer
Asko dryer: room temp air, is not heating
first try the reset button .. a black rubber button at the back panel about middle...
Hope it helps if NOT let me know more about your problem... and I will help
Jul 02, 2009 | Asko TL751 Electric Dryer
Asko Dryer stops running when you release the start button.
Hi, this is a simple issue here. these switches will fail from time to time. the start switch is unable to hold the circuit, in return, opening it upon release of the button.
Simply replacing the switch will fix this issue. switch is 20 dollars tops.
May 28, 2009 | Asko T701 Electric Dryer
Asko T700 Electric Commercial Dryer Problem
There's a reset button on the back of the dryer. It's a small black kinda rubber button about half way down the back panel near the center. push that button to reset it. should do the trick.
Jul 03, 2008 | Asko T700 Electric Commercial Dryer
Asko T781 Electric Dryer Doesn't Turn On
Have you reset the cut out on the back? its a little black button that you push in until it clicks. If it does not click, then it probably wasnt the problem. The next most likely cause is a melted fuse holder inside the box on the rear where the power cord goes in. There is a bypass kit available to repair this problem from ASKO, as the fuses are not needed. If you are able to do some simple wiring, you can do this. Otherwise find an AUTHORIZED asko servicer and they will know what I'm talking about. Good luck!
May 30, 2007 | Asko T781 Electric Dryer
Asko TLS752XXL Dryer Logo
504 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Are you an Asko Dryer Expert? Answer questions, earn points and help others
