Question about Dryers
Performa gas dryer model# pyg2000aww. has a gas smell only when in use and can smell within 10 minutes or so from starting. no odor transfer to clothes.also dryer shuts off before timer reaches off position.
    President:
  • 3,074 Answers
Venting issue, if you have windows or a door by the dryer open when in use, should clear the smell. hope this helped Tim
Posted on May 22, 2011
Strong gas odor only when oven is in operation?
If you're talking about the acrid smell immediately after starting the oven, that's aldehyde gas, a byproduct of cold gas combustion where the flame contacts the cold metal oven surfaces. That smell should disappear within the first minute or two, and it's entirely normal for a gas oven. If you're talking instead about the smell of fuel gas, then your burner may need to be adjusted; it may be running much too "rich".
Aug 23, 2014 | Electrolux Ovens
GAS Odor? Gas dryer smells of gas after it runs a cycle, just replace ignition gas valve assembly, still has gas smell?
Did you also replace the coils on the valve assembly?
Which parts did you replace exactly?
Nov 07, 2012 | Dryers
Amana gas dryer Model #ALG866SWB: When pushing
The motor is bad and needs to be replaced.
Jul 23, 2010 | Amana ALG643RB Gas Dryer
Have a maytag gas front loading dryer pyg2200AWW and the drum does not turn. From what I can read from the various posting, it seems that the belt has broken. Not sure how to tear this thing apart as most...
Have a performa dryer model #pyg2200aww the problem is it dries for the first 10 to 15 minutes and then it shuts off, if we wait for 20 minutes it starts again but then it shuts off again.
Jun 06, 2010 | Maytag Performa PAV2200
Smelled mild gas odor after moving dryer. Replaced gas line connection. Still smell gas. Tried to tighten gas line have strong gas odor after running dryer. Does not seem to be heating
The gas valve should not be opening unless the glow igniter glows and sends a signal to the gas valve. I suspect a small leak in either the gas pipe or at the gas valve. You will have to get to the gas valve to perform a leak test. While the dryer is open, replace the igniter.
Jan 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
When drying clothes in my gas dryer, you can smell gas upon opening the door. If the dryer is not running, you do not smell a gas odor. Sometimes our clothes also have a gas smell.This just started a week...
Hi, from what you describe, it sounds like you may have incomplete combustion, which would leave a residual odor while burning. Check your vent, on the outside where the flap opens and the exhaust leaves the building. Anything blocking that vent may cause an air flow problem. If you have good air flow when the dryer is running, the problem is going to be at the gas valve/burner and may need a professional. In my town, the gas company will come out and check problems like this for no charge, they don't replace parts but are good at troubleshooting. Best of luck.
Jan 17, 2010 | Estate TGDS740JQ Gas Dryer
I have a gas dryer. Dryer heats up but doesn't dry clothes completely all the time. Sometimes I have to run it 2 -3 times. What do i need to replace? Maytag Performa Model # PYG2000AWW REV. 10 Serial #...
I got cut short.. and disconnected...so if this is a repeat, please forgive me:
Dryers 101
1. Heat alone does not dry clothes
2. Air alone does not dry clothes.
3. Only dry, heated air passing over and through clothes will dry them...
I recommend the following:
Set the dryer for "Air Dry".
Go outside and check the dryer exhaust.
Confirm that the exhaust is spewing out lots of air.
If it is, then you have a need for a technician to inspect everything - in person.
If it is NOT, the you need to determine the clog - or reason that air is not moving through your dryer, clothes and exhaust system.
ONLY 2 possibilities exist:
1. Fan motor is frozen and needs replacement....or
2. Duct/exhaust is clogged with lint and will not allow air to pass through.
Please check for both, clean/clear/fix as needed.
Nov 04, 2009 | Dryers
MAYTAG PERFORMA PYET244AYW
It could very well be a thermostat problem, however, it could also be the drive motor itself starting to burn out. Some dryers are equipped with a "Thermal Limiter" that will cut the power to heat. It doesn't seem to be the case for you. I would defiantely look into another thermostat but if it comes down to the motor, depending on the price, You may want to buy a new dryer.
Apr 01, 2008 | Maytag PYE2300AY Electric Dryer
Strong odor after staining floors
Is it possible that some finishing paint or what not have leaked onto the venting? And every time your dryer is turned on the venting heats up and evaporates the finishing stuff? If it is a considerable amount then it may take a while to completely eliminate the odour.
Aug 09, 2007 | GE DBXR463GB Gas Dryer
Dryers Logo
83 people viewed this question
Top Dryers Experts
