Question about Canon PIXMA MP190 All-In-One InkJet Printer
Hello I am trying to print labels from gartner studios using a Canon MP190 PIXMA printer. The printer won't grab the label sheet (it's 3' x 11'). It just pulls the label sheet through.
  • 161 Answers
SOURCE: okidata ml390/391 Turbo
you have to set this on your computer. when the print box comes up you need to choose the label catagory to make your printer print labels just right
Posted on Aug 06, 2007
  • 12 Answers
SOURCE: Envelopes and labeles
Go the "print" dialog and select "settings". Ensure that the paper size, margins and orientation are not set for 8.5x11.  You did not mention the software you are using to print the envelopes/labels so this is the only guess I can give.   I have seen software that made me have to override the settings before.
Posted on Oct 15, 2007
  • 112 Answers
SOURCE: paper feed
The feed rollers are slipping on the surface of the label, causing the page to load incorrectly. There is no permanent solution at this time. Try one of the following workarounds to correct this issue. Workarounds Workaround 1 Adjust the top margin using Page Setup.
  1. Click File , then Page Setup in the program being used, (accessing Page Setup may vary from program to program. Refer to the Help file for that program).
  2. Adjust the top margin until printing is correct on the label.
Workaround 2 Manually print one sheet at a time. Place one sheet of labels in the input tray at a time, printing only that page. Repeat for all pages of labels needed.
Posted on Jan 15, 2008
SOURCE: Toshiba Studio 200 CP
Use the manual paper feeder, and set the paper type labels
Posted on Jun 18, 2008
kristy22
  • 4 Answers
SOURCE: canon HL 5040 printer grabs multiple papers to print
try one sheet at a time that may work.
Posted on Oct 21, 2008
Printer suddenly started drawing paper through without printing anything on it. cannot figure out why.
Click on start ,click on devises and printers. right click on printer image, click on troubleshoot , follow instructions.
May 21, 2015 | Canon PIXMA MX300 All-in-One Printer
I am trying to print a label through the document feeder and keep receiving error messages on my Brother MFC9320CW AllInOne Printer .."Open the Top cover and pull out all 4 drum units completely and...
Try putting more than one sheet of labels in the paper tray. Even if you're printing one label, it helps the printer grab the paper without that error somehow. If you're already using more than one sheet, I don't know. Good luck either way!!! :)
Jan 18, 2011 | Office Equipment & Supplies
I can`t find the serial number on my printer its a canon pixma mp190.
located inside the printer. Only the model number is visible outside.
Oct 01, 2009 | Canon PIXMA MP190 All-In-One InkJet...
I have pixma mx300 Can I print CD labels? Thanks Bryan Will my Cannon Pixma MX300 print Cd Labels.For standard printing the paper is fed from the back.
You can print adhesive sheet labels (such as avery 5931/8931) with no problems. Some canon printers will also print directly on CDs; check this website: http://damnprinter.com/. They have lists of printers that will work and pretty good instructions. I didn't see the MP300 listed. I managed to get a canon 6600D printer to print directly onto CDs, but I had to buy a tray (ebay-$12.00) and it took about an hour to convince it to do the job. The website says to follow the steps "several" times if necessary; it took a while.
Aug 03, 2009 | Canon Office Equipment & Supplies
Printing labels setup on the PXMA MX860
You don't need to do anything to set the printer up except to tell it you have heavier stock than normal.
Your answer lies in the program you are using to print labels. Please tell me which program you are using and what other office type programs you have on the computer and I will try to give you a viable solution.
Chris
May 27, 2009 | Canon PIXMA MX850 Multifunction Printer
We have a new Canon MP190 printer. Cannot figure
1. Go to the following link: http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
2. Menu 1, select "Multifunction"
3. Menu 2, select "Inkjet"
4. Menu 3, select "PIXMA MP190"
5. Click "GO"
6. Under "Please enter your question:", enter the following text: "How do I install the ink cartridge(s)?"
7. Click "Search"
8. From the search results, select the first selection. You will get a page with diagrams illustrating how to install the ink cartridges.
May 15, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Lexmark T640 won't print on label sheet a SECOND time...
try changing feed rollers. For a quick fix, remove the rubber rollers and flip them inside out. It should work
Jan 28, 2009 | Lexmark T640 Laser Printer
Jun 18, 2008 | Toshiba e-Studio 200 All-In-One Laser...
Label Printing
I had the same issue when using Avery labels, here's what resolved it for me.
Go to Control Panel, Printers, go to the active default, right mouse click, click Printing Prefrences..., change the drop down "Type is:" to 'Other Photo Paper" and apply.
You should then be good to go!
Feb 10, 2008 | HP DeskJet F380 All-In-One Printer
Canon PIXMA MP190 All-In-One InkJet Printer Logo
262 people viewed this question
old marine
old marine
