Question about Samsung AS18A6RB Air Conditioner
Heating Problem Hi , My split (2 Piece) aircon is not producing Heat, but its' working on cooling. I put it in heat mode and 30 Degrees still not working for heat. What might be the problem? Please help me in regards to this. -CHAD
    Habit-Forming:
  • 109 Answers
Put it in heat mode and check the pipes to outdoor unit,if the pipes are white from ice then the problem is to outdoor unit and is the coil of 4valve.its like a cube with 2 cables,change it.
Posted on Jul 09, 2009
Not cooling
outside freeze sensor locking out operation
Jan 04, 2014 | Dometic Rooftop RV Air Conditioner
I have 3 Fujitsu heat / cooling multi split ductless units connected to one rooftop unit. Only in heating mode and only coming from the same indoor unit is a loud almost screeching/vibration sound. It can...
If it happens in heat it must happen in cooling. The indoor unit has nothing to do with if it's heating or cooling. You likely have 2 moving parts in the machine, the blower wheel and the swing fins. Turn swing option off, eliminate that. You get the rest...
Jun 04, 2017 | GE Zoneline AZ38H12DAD Split System Air...
It comes on but the heat is cool.
how cold is it outside? Aircons are only efficient at heating (assuming they have a proper heat pump design) down to around 0-5 degrees C. below -10 degrees C you might not achieve any heating at all.
If there is a preheat cycle or defrost ensure you allow this to complete before expecting heat from it.
Remember heating is the reverse cycle of cooling so if your system has a gas leak it might not work anyway.
Jan 04, 2013 | Heating & Cooling
The heat sistem is not working well is working but 30% of eficency than it was working beafore.It hear like water on it ..help im frezzing
Air conditioning real definition is not giving cool but removing heat from the room. In same way for heating, it's not heating, removing cool from the room. When your indoor coil, air filter and blower wheel are full of dust, you won't get even 30% of cool or heat depend on your selection.
Simple solution for your problem is clean indoor unit completely. Check all sensor is working well. In heat mode keep temp minimum +3 degree than room temp. thanks and helpful.
Jan 30, 2011 | LG LS-L1210CL Mini Split Air Conditioner
We just moved into a rental. It has the Fugitsu wall-mounted Air-conditioner model: ar-jw2 but, there was no manual left behind and we are trying to use the heat, however, it just blows cool air, we're not...
Look, if you select a temperature above ambient temperature, it will switch from cooling to heating.(assuming that the aircon has a heat pump. most do these days.) Just dont rush the aircon because every time you make a setting change, it takes a while to regulate.
Aug 12, 2010 | Heating & Cooling
Fujitsu heatpump 13 years old is not heating room as it used to.filters are clean.i have gauges and would like to know what pressures are good and what pressures indicate low refrigerant or worn...
The refrigerant and compressor are related in cooling the room.As for heating problem the thermostat needs to be checked.
if you're used to a certain temperature of air and your heat pump is producing much cooler air, take the following steps. (Note that a heat pump may go into a defrost mode to prevent icing. When this happens, it can temporarily output cold air. Also be aware that the heat pump will have to work harder to produce heat.)
1) First be sure the thermostat is set properly. Try raising the set temperature 5 degrees F. and waiting a few minutes.
2) Be sure the room-heating registers are open.
3) Check the heat pump filter. If it's dirty, change it.
4) Be sure the auxiliary heating elements are working .
5) Clean the coils of the outdoor condensing unit.
If still the same problem then thermostat needs to be checked and replaced.
Thanks.
Jun 15, 2010 | Heating & Cooling
My LS-H186 VML 1Metal Art Cool 12000 BTU Air Con does not heat up
You should also check the outside unit to make sure the coil is not clogged with dirt or grass clippings and the fan is working. The reversing valve that switches it from cool to heat could also be a problem. If it isn't shifting it will not switch between heat and cool.
Apr 29, 2010 | LG Art Cool LA181CNW Split System Air...
Airconditioner LG LSk181-N2 shutting off
Sounds like your aircon is stuck on heating mode. Or. The outdoor fan speed is affected by ambient temperature, or low refrigerant. In heating mode the indoor fan will come on for a while to sense temperature and will then wait for the outdoor unit to pump up pressure and build up heat.
Feb 01, 2009 | LG LS-K1830CL Cool Mini Split Air...
Heating problem
Hi Radan, Did you get this problem solved? We have an Electrolux Kelvinator Split System and ours is doing exactly the same thing. I am struggling to find a solulution. Would be great if you can offer any advice.
Thanks Nicolle
May 03, 2008 | Heating & Cooling
Samsung AS18A6RB Air Conditioner Logo
371 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
