Question about Treadmill Doctor IMAGE 10.4Q TREADMILL Drive Motor
Image 10.4 Q Board lights up but motor won't run. Shows error Code E2
Image 10.2qi motor won't turn on. control board is fine and power is on.
1) Please test the main motor, see my personal TIPS for motor help.
2) test the output board for input voltage motor, if there are NOT the board is faulty.
see the diagram and block diagram
You can RUN the software calibration for diagnostic,troubleshooting, and fix it.
Happy NEW YEAR, God bless you
Dec 31, 2012 | Image 10.2QI/10.2Ql Treadmill Walking Belt
Technofit TS500i treadmill error code?? ( E1 & E2) please help!!!!!!!!!
Dear Sir:
The error code E1or E2 coming from this reasons.
1) Adjust the speed sensor, see the diagram attached, clean, and tight the connector wires.
2) Test the main motor input voltages coming from the output from the main motor board.
3) The main motor or motor board can be faulty or need repair.
See my personal TIPS for HELP and guide you.
sincerely. God bless you
Apr 23, 2012 | Exercise & Fitness
Error 2 in Goldstar MTD 602 treadmill
1) Adjust the speed sensor 2) Tight very well the connection from speed sensor. 3) Faulty Sensor speed 4) Faulty Main Motor measure for 115 VAC without load. 5) Main motor board faulty , test for 115 VAC,and oupput for +5Vdc. 6) See the transformer for 115 VAC,for primary voltage and secondary voltage. 7) See if some component such: resistors, capacitor, diode, or IC burn. 8) Lubricate the deck belt. 9) Adjust the tension for deck belt for lift 2-3" max. 10)error code e1 vs e2 in some mark is equal is different from some manufacturer.
See the block diagram for your diagnostic, for strong resultant.
Sincerely. Merry Christmas.
ernesto cuadra
managua, nicaragua.
Dec 18, 2011 | Exercise & Fitness
I've changed the ink cartidges but the black and color ink lights remain on and it won't print. I think the E2 error message is on.
This hapens when refilled cartridges are installed in the printer. To rectify the problem, look for the 'Resume button' normally black with a red circle around an arrow head pointing towards you. With the printer powered on, press and hold this button down for about 10 seconds. The error code will usually clear and the printer will print but the orange lights will still flash.
Sep 11, 2011 | Canon PIXMA MP160 All-In-One InkJet...
My machine shows an f11 or f14 error code and it won't work. What can I do?
Circuit Board Medics can rebuild and upgrade the CCU to eliminate the F11 error and prevent it from happening again. Find more details at http://circuitboardmedics.com/whirlpool-f11-code/
This video shows how to remove the CCU from the machine.
Aug 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite he3 dryer says PF
The PF and E2 (F02) error codes are related. The PF indicates that the dryer is experiencing a power failure. The F-02 error code indicates a Keypad/User Interface failure. The error codes for this dryer are shown in the third image below.
You could have a loose wire harness connection between the machine control board and the user interface control board that could cause there error messages and symptoms. The first image below shows how to access these components. I recommend that you unplug the dryer and then access these components. Check the wire harness connections on between the user interface control board and the machine control board. If the connections are okay then you will likely need to replace the user interface control board to correct this problem. The part number for the user interface control board is 8564396. You can order this part from the Sears PartsDirect website. It costs just over $100.
Sep 20, 2010 | Kenmore Dryers
E2 Code on Treadmill after starting
This is a speed sensor error. Unplug the unit then remove the motor shroud locate the power board with LED lights plug in unit locate the 5v DC if this is on then replace the speed sensor.The sensor is located on the frame by the front roller pulley or on the Drive Motor itself. Call IconFitness @ 1800-999-3756.
Jun 26, 2010 | York Barbell Home Use Fold-Up Treadmill
E2 error codes shows on my Pro Form 730 si treadmill
Did you find a solution for this issue? I have a similar situation
Sep 28, 2009 | Exercise & Fitness
I am getting an E2 error on the display. The
either any of the key(button)is got stuck up prtessed or the motor of the washer is got weak.due to this e2 error code shows up.the washer works if the motor is weak but if there are more clothes in the washer and due to that motor cannot spin properly so it shows e2.First clean the washer internally after emptying it completely then check.if still e2 error then motor needs replacement . you can get new motor at www.repairclinic.com
Aug 30, 2009 | Amana Washing Machines
Treadmill Doctor IMAGE 10.4Q TREADMILL Drive Motor Logo
76 people viewed this question
Top Treadmill Doctor Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Treadmill Doctor Exercise and Fitnes Expert? Answer questions, earn points and help others
