Question about Texas Instruments TI-89 Calculator
TRYING TO INSTALL CD THAT CAME WITH TI-89 TITANIUM. COMPUTER SAYS "THE FOLLOWING PAGES HAVE BECOME UNRESPONSIVE. KILL PAGES? " I CLICK YES BUT NOTHING HAPPENS. COMP JUST HANGS. WHATS UP??
  • Texas Instru... Master
  • 7,993 Answers
Go to the education.ti.com web site and download the TI Connect software. Install it on your computer. If you need the manual download it also. As to pages becoming unresponsive, it may be due to many causes: web browser, site busy, configuration of the computer, too may applications opened.
Posted on May 22, 2011
My TI-89 Titanium's screen froze. Well actually, the cursor kept blinking but none of the buttons worked. I got it to restart using the (-) and ) button trick, but rather than going back to normal it went...
Hi kelsers,
You need to re-install your calculator's OS. After this process your Ti 89 Titanium will operate properly. If you do the process below make sure you use new batteries.
Warning!!! If you do this procedure make sure that your computer and, calculator are connect. Use Ti Connect software and, make sure you can install the OS on the calculator without any interruption. At any time even at the very beginning of this process, if your computer or, calculator gets interrupted or you have a power failure during the installation of the OS, your calculator will be destroyed. So not attempt this procedure during a thunder storm.
You can use the Ti OS Downloader but, you will have no idea what OS is stored by the Ti OS Downloader. So, I suggest following my instructions and, installing the newest Ti 89 Titanium OS 3.10v.
Procedure to installing the newest Ti 89 Titanium OS 3.10v.
You can also get the latest copy of Ti 89 Titanium OS 3.10v by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 89 Titanium OS 3.10v." Once your at the Ti site click the Download Item, Ti 89 Titanium OS 3.10v. Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti 89 Titanium OS 3.10v. will download to you. Click, "SAVE". And then a folder will pop up. It is probably a folder that you download too. If so, you may want to change it and, "Save as" to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 89 Titanium guidebook too, if needed.
Link your computer and calculator with the USB cable or, Direct Black Link cable that came with the calculator.
Remove one of the AAA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. On the older TI-89 you should see "Press I to install code...", and you should press the [9] key to continue. But, on your Ti 89 titanium it should say, "Waiting to receive..." or, "Waiting to received OS...". Now you need to follow the instructions in the paragraph below to restore the calculator's operating system.
Next, drag the Ti 89 Titanium OS 3.10v. that you copied earlier to "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Next the OS Downloader Warning will pop-up. Click, "OK" to continue and, the new OS will begin to install. The Ti Device window should pop up and, click on to the port where your Ti 89 Titanium is located, USB1 cable or Direct Black COM1. Just click, "Select" and, the OS will continue to download. Upon completion the newest Ti 89 Titanium OS 3.01v. will be installed.
Jan 10, 2011 | Texas Instruments TI-89 Calculator
Ti-89 titanium
Having gone over a month with no response, I assume this is no longer a problem.
Jun 26, 2010 | Texas Instruments TI-89 Calculator
When I turn the switch on, ti-89 titanium does not turn on.
If you connect calculator to computer using Ti connect device explorer you might be able to see what files are on the calculator. I don't know if you downloaded from the web but, 3rd party programs and shells tent to miss up the calculator. This would able you to delete out possible problems which could be re installed later.
Sep 22, 2009 | Texas Instruments TI-89 Calculator
The TI-89 Titanium calc. purchased in Oct. 09 won't turn on
Try to increase the contrast
1. Turn it on
2. press [2nd] and release button
3. Press [UpArrow] and release button
4. Repeat steps 2 and 3 until contrast is adequate.
If that does not work use the link below to install TIConnect software
http://education.ti.com/educationportal/sites/US/productDetail/us_ti_connect.html
Install it on your computer and run it to oppen the main Window. Then connect you calculator to a USB port and, in the TIConnect main window Click the TIConnect TIDeviceInfo. It will try retrieve the info.
If it does your calculator is fine.
If it tells you Device Not found , Click communication settings in same pop up window where it said Not found, and Select Device, Select Cable, Select Port and try OK..
If all that does not work, then it may be time look for a repair shop.
If you are lucky and it works, you should reinstall the OS, which can be downloaded from education.ti.com. You drag and drop the OS on the TIconnect main window. Calculator must of couse be connected to computer.
Hope it helps
Apr 05, 2009 | Texas Instruments TI-89 Calculator
I am trying to download the new OS for the ti 89 titanium but i am not sure how to get it onto my calculator.
Use the link below to download TIConnect software
Hope it helps
Dec 08, 2008 | Texas Instruments TI-89 Calculator
Solving multiple non-linear equations
Type it like this: solve( equation1 and equation2 and moreEquations, {list of variables to solve for})
Put all of your equations right after the opening parenthesis separated by the word and, then a comma, then within curly braces each variable you want to solve for each separated by a comma.
Apr 26, 2008 | Texas Instruments TI-89 Calculator
TI-89 Won't Turn On
Please don't get your hopes up, but perhaps something in the following few suggestions will work:
For the TI-89 Family, TI-92 Family, and Voyage™ 200:
  1. Adjust the contrast by pressing and releasing the Diamond Key key followed by pressing and releasing the [+] key; repeat as necessary. To adjust or lighten the display, use the [-] key.
  2. Users of the TI-89 Titanium or Voyage 200 should see the following case before performing the following reset procedure to prevent the loss of valuable Apps.
    On the TI-92 family or Voyage 200, hold the [2nd] key and the [hand] key, then press and release the [on] key. On the TI-89 family, press and hold the [2nd] key, left arrow, and right arrow; then press and release the [on] key. This should reinitialize the operating system, in which you should see a progress bar filling on the screen.
  3. Remove one of the AAA or AA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. TI-89, 92 Plus, or Voyage 200 users should see "Press I to install code...", and should press the [9] key. The calculator should then say, "Waiting to receive...". TI-89 Titanium users should see "Waiting to receive..." or "Waiting to received OS...". You will need to restore the calculator's operating system.
To reinstall the Calculator's operating system, take a look at the following TI site.
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetNumber=12089
I would hunt around on the TI knowledge base to see if there are some more useful suggestions if nothing above works. If I find any more info that could be useful I will post it.
Mar 06, 2008 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
96 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
