Question about Kenmore 22422 Top Load Washer
I have a kenmore washer top load model#22442100 it needs a new switch for the spin cycle but i can figure out how to get the top off to change it
  • Kenmore Master
  • 2,605 Answers
Welcome to FixYa.
Here`s a helpful link for changing it out, and it covers most whirlpool built washers including Kenmore and removing the screws...locating them can be tricky on some models...this helps.
http://videos.wittysparks.com/id/3098139337
If this gives you any trouble I will try to help in any manner I can of course, let me know. Good luck.
Regards,
Macmarkus :)
Posted on May 22, 2011
Testimonial: "this was the answer i was looking for"
  • 3 Answers
Welcome to http://www.voguecatch.com
Air Jordan (1-24) shoes $35
UGG BOOT $50
Nike shox (R4, NZ, OZ, TL1, TL2, TL3) $35
Handbags ( Coach Lv fendi D&G) $35
T-shirts (polo, ed hardy, lacoste) $16
Jean (True Religion, ed hardy, coogi)$34
Sunglasses ( Oakey, coach, Gucci, Armaini)$15
New era cap $16
Bikini (Ed hardy, polo) $18
FREE SHIPPING
Posted on May 23, 2011
My kenmore 22442100 top load washer will not stop filling I have to watch it and manually stop water and advance timer past fill cycle please help advise.
your load select switch, has a hose connected to it, it goes to the bottom of tub. This tells water to shut off when it reaches desired water level for load size you selected. This hose gets clogged with soap, you have to open area where switch is, take hose off of switch and blow it out. This should solve your problem. If it does not, then load selector switch should be replaced. I am going with first solution, more common. Thanks
Sep 27, 2010 | Kenmore 22422 Top Load Washer
No spin cycle
This is usually caused by the pressure switch. Here is a link with the other possible problems. To check the pressure switch follow the link to the video. http://appliancehelponline.com/topwashernospin.html
Jul 16, 2010 | Kenmore 24032\24036 Top Load Washer
Some times the washer machine will spin and then
sounds like your clutch is slipping,,,,you can put a #10 washer in one of the clutch spring caps and that stops the slipping! thats a low on cash fix or just replace the clutch ,cost about 40 bucks!
Mar 30, 2010 | Kenmore 22422 Top Load Washer
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
My Kenmore washer somtimes won't go threw spin cycle
kenmore washers have a 2min. drain before it spines if leting it drain for 2min does not work u proberly need a new lid switch. haundi24
Jul 03, 2009 | Kenmore 22422 Top Load Washer
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
315 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
