Question about Saeco Odea Giro Plus Coffee Maker
During the grinding process its noisier than usual, also its not grinding properly before it spits the half ground beans all through the brew group into the waste and and drip trays. I have the grind set to medium and cleaned and confirmed all settings on the brew group are correct.
  • petemc785 May 22, 2011
    I had made a perfect coffee an hour before it started doing this. Would the bearings take a while to wear out? We are not even getting a brew out now as the beans are spat straight through the brew group.
  • petemc785 May 25, 2011
    thanks for the suggestions guys, its still under warranty so i'll be taking it back to them for a fix. will let you know what happens.
    Guru:
  • 1,833 Answers
Saeco's automatic coffee machines instantly grind the beans automatically. The brew group of this machine only takes a simple gesture for it to be quickly and easily removed from the machine and cleaned. Just rinse it under running water, without using chemical additives, to remove all dirt and coffee residues, So You need to clean all brew group and grinder. Descale the machine. Check the grinder has set properly in the machine. If it doesn't help you then you may have to replace the brewer or grinder.
Posted on May 23, 2011
    President:
  • 662 Answers
The real clue to the problem is that the grinding process is noisier than usual - the bearings in your
grider are nearly shot. These high torque/low RPM small motors are hard on their bearings, and yours is almost dead.
May as well run it til it dies though, since replacing seized bearings is the same amount of work
as replacing almost-dead bearings (if parts are available at all - I don't see any indication that
Saeco sells replacement parts...).
Typically, parts are unavailable for small appliances, unfortunately...
Note that there's a "secret diagnostic mode" designed into the machine, but I have no inside
info to get you into that mode, nor a service manual to guide you once inside diagnostic mode.
Here's a video covering cleaning your Saeco Odea Giro Plus Coffee Maker:
http://www.youtube.com/watch?v=e7iVVSutleE
Here's a video showing the "optimal" performance of the machine grinding 10g of coffee:
http://www.youtube.com/watch?v=4YPho7RRC2s&feature=related
Here's the 192-page online owners' manual for the device (wonderfully rendered in Dutch & English)
http://www.wholelattelove.com/manuals/Saeco/Odea%20Giro%20Full.pdf
If your appliance is still under Saeco warranty,
For warranty service of your Saeco machine, please contact:
Saeco USA Customer Service Department
7905 Cochran Rd. - Suite 100
Glenwillow, OH 44139
Call:1.800.933.7876
Fax: 1.440.542.9173
To the attention of Technical Assistance Service.
www.saeco-usa.com
Posted on May 22, 2011
HOW DO I CHANGE THE GRINDING MECHANISM ON MY SPIDEM TREVI EXCLUSSIVE ESPRESSO MACHINE. I HEAR THE MACHINE GRINDING BUT IT'S REALLY NOT DOING ANYTHING. ANY SUGGESTIONS
When the grinder spins free and fast it only means that fresh beans are not feeding into the burrs. This happens when:
1- Grind setting is too fine and beans cannot enter the grinder mechanism.
2- Use of oily dark roast beans can clog the ground coffee chamber and preven the fresh beans entering the grinder.
3- The ground coffee chamber outlet is clogged due to oily beans or too fine coffee setting.
When you cleaned the grinder you may not have cleaned the coffee outlet to the doser on the left. You can clean the outlet to open the passage of coffee grounds to collect in the dosing device..
After cleaning the outlet, you should next make sure that coffee grounds are not packed in the doser. The doser is inside the door right above the brew group.
To access the doser:
1- Remove water tank.
2- Remove the brew group.
3- Lay the machine on its back for full view of the doser.
4- Pull the doser door open (it is like an Attic door.
5- Keep the doser door open and clean the inside with a brush. The outlet from the grinder is on the right side with a wire wiper cleaner that moves across the grinder outlet fills from the grinder. This opening.
Use a brush to clean the doser.
On the left of the doser space there is a plastic flap that is pushed to the left when coffee grounds fill the doser.
At certain distance push back (1/4") the notch on top of the flap pushes the doser micro switch pin to stop the grinder. Push the flap gently to the left to make sure that it is moving well. With each push back of the flap, one can hear the feeble click sound from the micro switch.
When the above cleaning is done, try the grinding.
If the conical burrs have not been replaced for over 2500 grinds, it is time to do so.
The above grinder and grinder doser cleaning instructions are available as download files on the following page link:
One can find many useful maintenance guides on one page.
Good luck.
http://www.partsguru.com/MaintenanceofEspressomachines.htm
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Feb 10, 2015 | Spidem Coffee Makers & Espresso Machines
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
My Saeco Odea Go only produces weak coffee (like water). Tried adjusting the grinder and also different coffee beans. Any ideas?
have you tried adjust coffee strenght?
This is the bean symbol on the bottom of the front control
Jan 23, 2013 | Saeco Odea Go
Saeco odea does not brew. coffee beans will grind, then coffee maker will start flashing all lights, and ground coffee will spit out without brewing. when i change beans to more oily ones, it works without...
Hi...Keep on grinding until the Auto Dosing System readjust the amount of grind to be in the optimum. Normally it takes 3 to 4 grinds. Whenever we change the type of beans, this condition happens, it is not a problem.
Aug 29, 2011 | Saeco Odea Giro Plus Coffee Maker
Seams that my saeco incanto deluxe has a problem with the brew group possibly the boiler the grounds come out dry. If I do a rinse cycle the water still flows help? How do I clean the boiler?
Hi
Dosage lever or knob (small knob in the bean hopper) is to the max positive and the brew unit can not compress the coffee, so the machine dumps it into the dredge drawer to prevent breaking the machine. Reduce the amount by 1 click back from the full positive, and that should take care of the problem. Another thing that can cause this is the grind is too coarse or the grinder has come apart. The grinds should look like coarse sugar.
PS. It will usually work if the brew unit is clean, but when it is used once it will go back to dumping dry grounds.
Aug 19, 2011 | Saeco Incanto Classic Espresso Machine
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Beans ground but continuous grinding but not brewing
The grind switch is stuck. Try to free it and clean it.
Mar 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Vienna superautomactica found a spring
That spring can fit in many places:-(
I put a blowprint of the brewingunit here.
Jan 31, 2009 | Saeco Vienna SuperAutomatica Coffee...
Saeco Odea Giro Plus Coffee Maker Logo
777 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
