The unit doesn't seem to be cooling properly. The inside temp in my mobile home was 81...after 3 hours, it had only cooled to 78. The unit is blowing "vented" air through the home instead of cooling the air
    Problem Solver:
  • 12 Answers
The most probable cause would be the lackof coolant.
Posted on May 22, 2011
My Goodman unit won't cool below 78 degrees inside during this heatwave. The thermostat says
your home may not be insulated well enough or you could have leaking duct or your system may not be charged correctly ac systems are not sized to cool below 76 degrees above 90 degrees outdoors because this will increase your utility bills during the cooler temperatures. thank your governement and all the regulations we have to follow for this. they would rather you save money than be comfortable. and we are actually in violation of state law and federal law if we install a unit that will cool below 76 degrees on 90 degree outdoor temp
Jul 02, 2012 | Goodman CKL36AR36 Air Conditioner
What temp should my golf run at if the cooling system is operating properly? Runs perfectly on the highway but when i stop start it goes from min temp to only half on the gauge but seems to be runnning...
the temp seems to be fine. 80degrees celsius or less in stop and go traffic is normal,especially since the cooling fans are working and coming on at the proper time. the what seems to be running rough is another problem that doesn't seem to related to the cooling system temp. may want to check the spark plugs for worn electrodes.
Aug 08, 2011 | 1994 Volkswagen Golf
Hello. I have a Bryant 561CJ030-D AC unit. The fan comes on but doesn't seem to be cooling. We have had record high temps the past couple of weeks (over 100 degrees), and I'm wondering if the...
Is the compressor turning on? The fan may be running, but you will not get cooling effect unless the compressor is circulating refrigerant. It appears your unit is a 2.5 ton unit. What is the square footage of the space being cooled? Is the space insulated?
Aug 04, 2011 | Heating & Cooling
I just had 'goodman gpc1336h41ab' 13.00 seer unit installed , I have a 1250 sq. ft. home and it just doesnt seem to be cooling. The unit runs constantly. So my question is , is my unit big enough...
There are a few variables that determine the size needed to cool your home - the size of your home, type insulation, are just two. I have a 2600 sq ft home - about 1300 sq ft per floor. I choose to cool the entire second floor (bedrooms and baths) and two of the largest rooms on the first floor (kitchen & living room) via flexible ducts from an air handler installed in my attic. My house was built in 1960, and at the time had electric heat. This means it is fully insulated. I replaced all the windows with energy efficient types, and vinyl sided. I installed soffit, ridge and gable vents to keep my attic well ventilated. I can cool my house in Boston, MA to 70 degrees (when it is 85 degrees inside) with a 4 ton unit in a little over an hour with no problem (one ton of cooling is equal to about 12,000 BTUs). Your condenser should not run non-stop. If it is not cooling then it is not a thermostat problem, but could be a gas charge problem. If you haven't paid the contractor in full yet - that may be the reason why. The contractor should know how much cooling you need for the space you have and installed a properly sized unit. Make sure your air filters on the return are clean and replaced regularly. Call the contractor and explain the problem - he should be able to solve it for you very quickly.
Aug 03, 2011 | Heating & Cooling
We do not run our a/c unit during the day so in the evening I turn it on and it seems like it takes forever for the inside of the house to cool down. This is an older model carrier and was in the home when...
Take a look at the condensor outside. With the unit running even on a cool day, the condensor fan (outside) should be blowing hot air. The air temp coming out of the register should be 20 degrees cooler yhan the coils in the house.. This is a reverse way to chk the evaporator temp for proper cooling. Now, the wire could be a problem if it is coming from the thermostat. Take notice of the outside unit is being controlled by the thermostat by having someone go from off to cool on the T-stst. If everything is working but the discharge air is warm your unit may need a charge. If I haven't confused both of us, I'll watch for you reply -Ned
Jul 06, 2011 | Heating & Cooling
Air condition jsut 10 month old ... not keeping up whith cooling
If it's only 92° outside and the unit won't cool the house, then the unit is either to small or it's low on refrigerant. They are designed to cool a house with outdoor temperatures up to 115° to 120°.Usually you need one ton a/c for every 400 square feet of house, but, you have to take into account for average outdoor temperature and humidity, windows, doors, especially sliding glass or patio doors and which side of the house they are on, insulation in walls and attic.
The air leaving your duct work going into the rooms should be about 20° lower than the room temperature, if you have a 80° room then the air leaving the duct should be around 60°. if it is then the unit is probably to small if, everything is working properly.
Jun 07, 2010 | Goodman CLQ36AR49 Air Conditioner
Indoor temp doesnt go to my punched in setting of 68 on therm
if it is around 93-97 degrees outside,thats all the cool your going to get
Jun 23, 2009 | Honeywell Programmable Thermostat Heater
GSH13 Goodman heat pump split system is running a long time in cooling mode and will not cool below 74 degrees. A lot of condensation generated. The low side pressures 78 to 81 and high side pressures are...
Check sub cooling and super heat. the New ac units are very critical to charge. There is a charging chart on the inside of the cover to the unit outside. Check temp difference across coil. Should be 18 to 22 degress. If you have an ampmeter. Check the heat strips one 5 kw might be stuck.(sequencer). This would cause you not be able to pull down temp. Goodman unit are hard to charge to get the temp difference across coil. Feedback please
Jun 14, 2009 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
119 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
