Question about Bugaboo 'Cameleon' Stroller
One wheel doesnt seem to brake when i put the lever on. it slips and makes a rattle sound. the other side catches on the wheel no problem
    Guru:
  • 541 Answers
This is a common problem with the bugaboo's The brakes use a toothed brake shoe to fit in to a toothed inner rim, What happens is one shoe seems to alway fit into the toothed rim but while the other side always hits the top of the teeth causing the shoes and connecting rod to twist. Eventually you get the problem you describe. The brakes shoes are interconnected by an aluminum rod. The shoes have two splines that fit into slots in the rod and a phillips screw to lock them in. First try taking the back wheels off and getting a strong man to hold the shoe that doest lock while pulling the one that does back in to alignment. This quite often works. If the twist is to much I remove one shoe cut off the splines turn the shoe to align with the other shoe then drill a new hole for the locking screw.
Posted on May 22, 2011
02 alero olds, makes rattling or buzzing sound when i accelerate. What could this be. sound seems to come from driver side undercarriage
Noises such as what you describe can be associated with wheel bearing, drive shaft or brakes.
The rattling noise could be a loose brake-backing plate and the buzzing noise caused by it touching a spinning brake rotor.
However, it could also be a worn drive shaft/constant velocity joint, which is the usual culprit.
The only real course of action you have is to give a mobile mechanic a call or take the car to a workshop and ask them to investigate -it will take just a matter of minutes.
Oct 23, 2016 | 2002 Oldsmobile Alero
My 04 avalanche makes a clinking noise In front underneath when I hit a bump?
dose it speed up and down when you drivings, it could be you have caught the splash guard onto the brake disc and its catching, if its the wheel baring you need to jack up the side with the wheel still on and turn wheel round check for the sound if now sound, grab wheel at 9 to 3 and shack the wheel feeling for movement should be just a tiny bit with no sound. then do the same at 12 and six if there is a lot of movement the bearing will need replacing same if it makes a clunking sound.
Sep 15, 2014 | 2004 Chevrolet Avalanche
2002 Ponitac Grand Am, loud knocking noise in the front drivers side area, when decellerating. We bought the Grand Am brand new, and ithas never gives us any major problems, minor things like the automatic...
Not a wheel bearing - probably not a CV joint. Could be something inside the transaxle. Is it possible something came loose in the caliper-rotor area ?
Jun 25, 2012 | 2002 Pontiac Grand Am
My rpm turns higher but my speed still remains the same.
Sounds like you have a slipping clutch. You can check your owners manual for the proper clutch lever free play. A quick check would be to see where you are starting to engage the clutch or friction zone. With the bike warmed up and running, shift into 1st gear and then start to slowly releash the clutch lever. If the clutch does not start to engage until the lever is 80% released, then you can try adjusting the clutch lever free play. You can do this simply by sliding the rubber cover from the clutch lever. If the cable end is showing a lot of threads then you can loosen the larger lock nut, a serrated looking wheel with a slot in it, and give the cable end a few turns in. Lock in the lock nut and start the bike and see if the friction zone is catching earlier. Try adjusting to get it to catch within the middle of the travel. Once you feel you have the clutch adjusted, give it a road test to see if the engine will not rev higher without a corresponding increase in motorcycle speed. The owners manual will give you a precise range where the clutch lever free play should fall, usually measured from the end of the clutch lever. If the clutch seems to be adjusted properly, then a worn out clutch could be the problem.
Good luck.
Mar 26, 2011 | Suzuki RG 150 Gamma Motorcycles
The brakes and handle on my bugaboo doesnt work the handle does stay still it slides down when im holding it and the brakes work when they want to
Problem 1/ The handle extension lever is held in by the pin it pivots on, cut the tip of a smaller size nail and use it to tap out the pin. There should be a rubber block and a matching steel shim under the lever. The lever pushes on the shim and the shim on to the rubber block jamming it against the handle. The steel shim is the usual problem. it slips out. Open the other side and use that shim to get a copy cut. A piece cut out of a tin can could work.
Problem 2/ This may sound strange but the best thing to do with the Bugaboo brake system is to lubricate it with silicon spray. Both the lever and the cable. The bugaboo does not use friction to brake with but the engagement of teeth. Ratchet teeth in the lever and brake shoe teeth into the wheel hub teeth at the wheels. Lubrication won't effect braking but wear on those teeth will!
Dec 28, 2010 | Bugaboo Cameleon Stroller
2003 Kia Spectra odd rattle in shifter
You are most likely hearing metal on metal on the brake pads. The brakes are not attached to the gear shift in any way. Unless those Koreans have done some really wierd design.
Sep 08, 2009 | 2003 Kia Spectra
My car rattles when I brake
def sounds like warped rotors. doesnt take much of a warp to feel like the wheels are falling off
Jul 13, 2009 | 1993 Honda Prelude
Bonnet catch will not engage
Had the same problem today. First I thaught the catch had slipped out or the spring that connects onto the catch had let go. I was fumblng about for ages, poking around with a screwdriver. Anyway simple answer (if you're sure no cable has broken) oil, Oil, OIL! Spray lots of oil. Push and pull the catch lever under the bonnect. Push and pull the latch which is inside the car. Click the bonnect shut. Open from the latch inside again. Repeat it a few times. Just get all the moving parts, well........ MOVING! with lotsa spray oil. This is particularly the case if you drive lots of miles and like mine ur car is dirty (5 quid for a hand car wash doesnt seem that bad now). If nothings bust it will open (and let me tell u when it does, you'll feel so damned relieved). if that doesnt do it take it to a mechanic cos u'll just frustrate urself and brake something. Good luck
Gayan
Feb 22, 2009 | 2003 Volvo V40
How to install rear brakeshoes
REMOVAL & INSTALLATION
If you are not thoroughly familiar with the procedures involved in brake replacement, only disassemble and assemble one side at a time, leaving the other wheel intact as a reference.
1983-88 Vehicles
See Figures 1, 2 and 3
  1. Raise and safely support the rear of the vehicle with jackstands.
  2. Remove the tire and wheel assembly.
  3. Remove the brake drum, as outlined earlier in this section.
  4. Place Brake Cylinder Clamp D81L-1103-B or equivalent, over the ends of the brake cylinder.
CAUTIONBe careful that the springs do not slip off the tool during removal, as they could cause personal injury.
  1. Remove the shoe-to-anchor springs, using Brake Shoe R and R Spring BT-11, or equivalent, then unhook the cable eye from the anchor pin.
0900c1528006be0f.jpgFig. 1: Place the brake clamp tool over the ends of the wheel cylinder, then remove the shoe-to-anchor springs using the correct tool
  1. Remove the shoe guide (anchor pin) plate.
  2. Remove the shoe hold-down springs, shoes, adjusting screws, pivot nut, socket and automatic adjustment parts.
  3. Remove the parking brake link, spring and retainer. Disconnect the parking brake cable from the parking brake lever.
  4. After removing the secondary brake shoe, disassembly the parking brake lever from the shoe by removing the retaining clip and spring washer.
0900c1528006be10.jpgFig. 2: View of the drum brake components-1983-88 9-inch brake shown 0900c1528006be11.jpgFig. 3: View of the drum brake components-1983-88 10-inch brake shownTo install:
  1. The brake cable must be connected to the secondary brake shoe before the shoe is installed on the backing plate. To do this, first transfer the parking brake lever from the old secondary shoe to the new one. This is accomplished by spreading the bottom of the horseshoe clip and disengaging the lever. Position the lever on the new secondary shoe and install the spring washer and the horseshoe clip. Close the bottom of the clip after installing it. Grasp the metal tip of the parking brake cable with a pair of pliers. Position a pair of side cutter pliers on the end of the cable coil spring, and using the plier as a fulcrum, pull the coil spring back with the side cutters. Position the cable in the parking brake lever.
  2. Apply a light coating of high temperature grease to the brake shoe contact points on the backing plate. Position the primary brake shoe on the front of the backing plate and install the hold-down spring and washer over the mounting pin. Install the secondary shoe on the rear of the backing plate.
  3. Install the parking brake link between the notch in the primary brake shoe and the notch in the parking brake lever.
  4. Install the automatic adjuster cable loop end on the anchor pin. Make sure the crimped side of the loop faces the backing plate.
  5. Install the return spring in the primary brake shoe and, using the tapered end of the brake spring service tool, slide the top of the spring onto the anchor pin.
CAUTIONBe careful to make sure that the spring does not slip off the tool during installation, as it could cause injury.
  1. Install the automatic adjuster cable guide in the secondary brake shoe, making sure the flared hole in the cable guide is inside the hole in the brake shoe. Fit the cable into the groove in the top of the cable guide.
  2. Install the secondary shoe return spring through the hole in the cable guide and the brake shoe. Using the brake spring tool, slide the top of the spring onto the anchor pin.
  3. Clean the threads on the adjusting screw and apply a light coating of high temperature grease to the threads. Screw the adjuster closed, then open it 1/2 turn.
  4. Install the adjusting screw between the brake shoes with the star wheel nearest to the secondary shoe. Make sure the star wheel is in a position that is accessible from the adjusting slot in the backing plate.
  5. Install the short hooked end of the automatic adjuster spring in the proper hole in the primary brake shoe.
  6. Connect the hooked end of the automatic adjuster cable and the free end of the automatic adjuster spring in the slot in the top of the automatic adjuster lever.
  7. Pull the automatic adjuster lever (the lever will pull the cable and spring with it) downward and to the left and engage the pivot hook of the lever in the hole in the secondary brake shoe.
  8. Check the entire brake assembly to make sure that everything is installed properly. Make sure that the shoes engage the wheel cylinder properly and are flush on the anchor pin. Make sure that the automatic adjuster cable is flush on the anchor pin and in the slot on the back of the cable guide. Make sure that the adjusting lever rests on the adjusting screw star wheel. Pull upward on the adjusting cable until the adjusting lever is free of the star wheel, then release the cable. The adjusting lever should snap back into place on the adjusting screw star wheel and turn the wheel one tooth.
  9. Expand the brake adjusting screw until the brake drum will just fit over the brake shoes.
  10. Install the brake drum and wheel and tire assembly, then adjust the brakes.
  11. Carefully lower the vehicle.
Dec 08, 2008 | 1987 Ford Thunderbird
Rattle steering wheel
Sounds like your intermediate steering shaft. Its the slip shaft that runs thru the firewall. They have a slip-stick condition that makes a horrible rattle that you can feel in the wheel. Its a pretty easy repair. Just make sure the steering wheel dosen't spin while you are changing it.
Good Luck
Aug 24, 2008 | 2004 Chevrolet Tahoe
Bugaboo 'Cameleon' Stroller Logo
162 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
