Question about Electrolux 24 in. EDW5500DSS Stainless Steel Built-in Dishwasher
Model EIDW6105GSO.Start a normal cycle,fills with water,starts washing for about 2 minutes.All the blue lights start flashing. Then it drains water out. Damper dryer light behind kick panel is on.Need to know how to fix this.
  • 1462 Answers
SOURCE: have a trouble: dish-washer will not drain.
bear in mind first program action is drain but at this point there should be only a small amount of liquid in machine.check spigot is free by pouring a little water down it. blow thro drain hose to check free as well - you can get a fat blockage in drain hose. if both are free you may have a blockage in exit to pump.the only other maintenaince is to use a dishwasher 2-3 times a year
Posted on Mar 21, 2007
SOURCE: Dishlex dishwasher
I have the same problem and the main conrol board was replaced. No Problems since.
Posted on Jun 11, 2007
  • 6 Answers
SOURCE: dishlex global 300.... The normal light starts flashing mid wash
i think it means the water heater in the dishwasher is not working,or the element is shot.
my 300 had a burning smell before the light started flashing.
Posted on Apr 18, 2010
SOURCE: electrolux dishwasher all lights blinking and wont
I had the same problem and followed rstecher and his solution. Removed the kick, light flashing was saying a leak was detected. Tipped the DW on it's side, have plenty of towels ready because the pan will be filled with water. Make sure power is off. Removed the pan and every single one of the clamps was loose. Tightened all the clamps at least 4 complete turns. Dried everything so the sensor wouldn't pick up any water. Put the pan back on and it worked perfectly! Thanks rstecher!
Posted on Jun 09, 2010
Daniel S
  • 4323 Answers
SOURCE: dishwasher starts to fill then
Hi
Error code F12 means a shorted connection or wiring on keypad. Turn off & unplug the dishwasher for 2-3 minutes and check the error doesn't appear. If this doesn't resolve the issue then you'll need to disassemble the keypad and check the connections on the keypad, also make sure that the wiring is also fine. If the connections and wiring seems to be fine then use a multimeter to check the continuity between the connections on the keypad. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Sep 29, 2010
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
LG Turbodrum DD 8.5kg WT-R852 washing machine, will not completely fill with water to water, to initiate the wash cycle, wash process stops there.
THE WASHER IS OBVIOUSLY HAVING A PROBLEM DETECTING THE WATER LEVEL? IT DETECTS AS FULL WHEN ITS NOT AND THEN GOES INTO DRAIN CYCLE? THE FILLS AGAIN? I would suspect the water pressure switch but if it was detecting a full cycle it would sent it into wash cycle? the water inlet valve only allows the amount of water it is told to send in and does not control the amount or drain cycle. Im not sure here but Im thinking maybe the water level switch may be flawed, the one that has low-medium and high? all these can be checked with a multimeter
Mar 01, 2015 | LG Washing Machines
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
Wil163 3 lights flash mid wash
My machine starts filling with water, then the power button and the two next to it start to flash, and the water starts to drain from the machine.
Apr 12, 2009 | Indesit WA 115 Front Load Washer
Soon as i set cycle and swich on door light flashes open
hi,
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Thanks for your question.
Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
Asko 1585 Dishwasher
do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
Aug 29, 2007 | Asko 24 in. 1585 Built-in Dishwasher
Electrolux 24 in. EDW5500DSS Stainless Steel Built-in Dishwasher Logo
44 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
