Question about Honeywell Programmable Thermostat Heater
Just purchased and installed a Honeywell programmable thermostat (RTH6350) and for some reason, the furnace just decided to turn on, and it won't turn off - even when i turned the thermostat off!!! There are no shorts in the wires - all was hooked up corectly. Had to power off the entire furnace just to get the heat from turning on. Any ideas??
  • prov12_9 May 22, 2011
    Thanks for the response.. I checked all the wires and all is fine - they are going exactly where they should be going. And, no wires are touching each other.. Giving the unit time now to see if it responds to the thermostat, but that doesn't seem to be the case. Think I'm just goin to replace the unit all together..
    Sergeant:
    Novelist:
  • 185 Answers
I would recheck your wiring..... Shut the furnace off at the breaker or SSU.... Then get a pen and pad and write down the color of wires and where it is connect on the Terminal strip at the furnace..
Example: Red wire hooked to R terminal etc They should all match up with the subase of the new Thermostat.
Then go up to the thermostat and Check and make sure the colors match what you have wired at the furnace. R= Power W=Heat G=Fan Y=Cooling C=Common
There are two possible ways the heat could be power on all the time..... You have the white wire or W wire wired to G and the thermostat is set to Fan ON... or the insulation on the R wire and W wire is split and touching each other or they got pinched and are touching together which will make the furnace come on with out the thermostat controlling it..... Good Luck, Its is where I would start first.... there our other possibilitys the control board may of gone hay wire.....
Posted on May 22, 2011
I have a honeywell T87K round thermostat (2-wires R and W). I just purchased a honeywell WIF 7-day programmable thermostat RTH6580WF. How do I install the new thermostat? Is it even possible?
Programmable is in unit nothing to do wire fto urnace two wires cut furnace on and off you should have instructions to use two wires with your instructions
Aug 18, 2015 | Honeywell T87K1007 Mechanical Thermostat...
Installed a rth6350 now no power
The RTH6350 is a battery-powered thermostat. Did you correctly install the AA batteries? Press down and pull the battery holder away from the thermostat on the right hand side. Try new batteries. Did you remember to secure the C wire with a wire nut and push it back into the wall. It should not be connected to the thermostat.
If you connected the C wire, you may have damaged the thermostat by providing too much current. Honeywell has the documentation for the RTH6350 on the product page: http://yourhome.honeywell.com/home/Products/Thermostats/5-2-Day-Programmable/RTH6350D.htm . The installation guide is here: https://customer.honeywell.com/request.cfm?form=69-2416ES . See page 23 and subsequent pages for the wiring diagrams.
I hope this helps.
Oct 11, 2014 | Honeywell RTH6350 5-2 Programmable...
Honeywell thermostat won't turn the furnace on after power outage.
probably tripped a limit switch or a low voltage fuse would kill your display on the tstat, you should have battery power on your stat though.unless you have knowlege of electrical you better call a technician
Dec 09, 2012 | Honeywell Programmable Thermostat Heater
Honeywell ct3200 thermostat won't turn on
DON'T BUY A NEW ONE JUST YET! IF THE BATTERIES DIED & THERMOSTA LOST POWER, IT MAY HAVE LOST IT'S MEMORY. IT MOST LIKELY WENT BACK TO FACTORY DEFAULT SETTINGS, & NEEDS TO BE RE-PROGRAMMED THROUGH THE INSTALLER SET-UP MENU. HOPEFULLY YOU HAVE THE PAPERWORK FOR THE THERMOSTAT STILL & CAN POSSIBLY DO THE SET-UP YOURSELF. IT SHOULD HAVE STEP BY STEP INSTRUCTIONS FOR THIS IN THE INSTALLATION GUIDE (NOT THE OWNERS MANUAL)
Oct 13, 2012 | Honeywell Programmable Thermostat Heater
Honeywell RTH6350/RTH6450 Thermostats - Have two that had to be replaced as heat would not work at all. Had Honeywell tech on for 1/2 hour he could do nothing from India!! Wondering if these were...
The problem with the honeywell brand is that the only dependable units begin with TH not RTH the RTH is for residential and you can purchase those at a local home improvement store. Go on Ebay and spend the money for a quality t-stat. "you get what you pay for"
Apr 27, 2011 | Honeywell Electronic Programmable...
New programmable thermostats will not operate the furnace or air
did u turn the power off to unit before installing t-stats,if not then mabe blown low voltage fuse
Mar 28, 2009 | Honeywell Programmable Thermostat Heater
Honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Geno
Mar 07, 2008 | Honeywell Programmable Thermostat Heater
Honeywell 5+2 day programmable thermostat will keep heating to 29 degrees!
Is sounds like you wired it correctly, The black is a little unusual perhaps its blue, anyway, try disconnecting the wires from the thermostat and see if it shuts off. If so, then it may need to re calibrated. I will need some more info to help you anymore.
Dec 03, 2007 | Honeywell CT3200 5-2 Day Electronic...
Heating & Cooling Logo
512 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
