Question about Whirlpool GS563LXSS - stainless Steel Gas Kitchen Range
While using the oven, the oven will stop heating or maintaining the temp that it was set on.
  • Whirlpool Master
  • 1,902 Answers
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on May 22, 2011
How do I set so oven maintains same temp all day and do not have to pre heat before it is used
The only way is to set it to the temperature that you most use and leave it running all day
Jan 26, 2016 | Ovens
I have a double oven kitchenaid natural gas range model KGRS505X. When I cook in the upper oven nothing I cook will brown. Buiscuits get cooked but are still ehite when done. What is the problem?
The top oven not maintaining heat why plenty of reasons depending on age could be a weak ignitor, bad temp sensor, is the oven light on if so oven stops heating after 30 seconds any oven maintaining set point temp will brown and if left long enough burn
Jan 26, 2015 | KitchenAid Kitchen Ranges
Oven heats up on preheat nut does not maintain temp for cooking
The older type stoves used a flue to maintain the temp. Later on we went to gas or electric heat.
Mercury based bulb mounted to a oven control maintained the flow of gas or shoctricity to the appliance. Todays modern kitchen appliance rely on thermistors to verify temps for the oven control.
A thermistor is a special resister that changes voltages. When the heat rises in the oven the voltage being sent out is messed with. These voltage drops are monitored by headquarters. The heat source is applied by judgement rendered from these measurements. In other words the control gets word and sends heat or don't send none. So what can go wrong? Sensor out of spec throws a monkey wrench in the works. That fancy smancy control yall paid big money fer don't know weather to well yall get the picture. The sensor used to measure temps in the oven is usually 1100 ohms at room temp. if it is off the oven will not work correct.
More Here
Jun 06, 2011 | Kitchen Ranges
My oven is not heating up properly, it either doesn't heat up or it takes a very long time to heat up. The range top works fine and the broiler works, but when i set it to bake it doesn't or takes long.
There are two possibilities for problems with the range. If it has a "timed bake" setting for the oven then it's possible that the last person who used it neglected to return the setting to the manual mode. In "timed bake" mode, the oven will heat to approx. 160 - 185 degrees, what is called a "keep warm" temp. It will maintain that heat setting regardless of what you set the oven temp control to, as long as you're not in the time frame that it's set to bake. This will make trying to bake anything a very difficult procedure.
The second possibility is that the oven glo coil igniter is cracked and will not heat to the proper temp to allow the electricity to flow through it to the oven gas safety valve to allow it to open and let the gas flow to the burner. These things are ceramic and for some reason crack in normal use. If it has a top broiler, that unit is obviously good. Unfortunately, the igniters are seldom interchangeable. You would need a tech to check the igniter with an ohmmeter.
Mar 23, 2011 | Amana Ovens
My oven heats up, but then does not maintain the temp.
If it has a pilot then I would say the thermal couple is bad. If it has a glow type ignitor then the ignitor is bad.
Sep 02, 2009 | Whirlpool GS460 Gas Kitchen Range
GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Mar 14, 2009 | Ovens
GE Spectra XL Oven does not maintain oven temperature
I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
Sep 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool GS563LXSS - stainless Steel Gas Kitchen Range Logo
71 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
