Question about Car Audio & Video
Lost the code 4 my cd player in my van how do i get the code
  • xxxxxx xxx May 22, 2011
    The radio SERIAL NUMBER is required for a code
    First remove the radio from the dashboard.
    Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
    This information can then be used to see if a code can be calculated
    Further useful removal information can be found here WWW.UKBOOKSHELF.CO.UK
  • Car Audio & ... Master
  • 4,869 Answers
The radio SERIAL NUMBER is required for a code First remove theradio from the dashboard. Then post the radiomake+model plus all the letters+numbers on any labels,barcodes or stamped inthe metal casing. This information canthen be used to see if a code can be calculated
Posted on May 22, 2011
My renault kangoo van radio/cd player has stopped working. It was when the weather got below -10. No work has been done to te van. Any suggestions?
If the battery went dead or the radio lost power at any time you will need to re-enter the code for it to work again. If this is not the case check the fuse for it as it may have blown in which case you will be required to enter the radio code after replacing the fuse.
Mar 17, 2011 | 2006 Renault Le Car
My 2004 ford freestar van 's 6 cd player isn't working since I put a new battery in the van. The radio displays "check player". The radio works fine. is there a code or something else I'm missing?
I am having the same code display after a new battery. I brought the van into the local Ford dealer for something else and told them about the radio. They wanted $150 to diagnose each problem I was having with the van. What a rip-off, I didn't have them "diagnose" the player. Does anyone have a fix for this?
Apr 19, 2010 | Car Audio & Video
Delco no.90 566 821 ,suplier 4660103 mc,gm 0500x9595741 I need a code for this cd-player, because I losted and it*s from vauxhall vectra
I need a code for this cd-player, because I losted and it*s from vauxhall vectra b delco no.90 493 281 ,suplier 4 660 103 mc, GM 90 493 281 cdr 500 >PA 6 - GF 15< Thanks. mail sgul@qu.edu.az
Mar 06, 2010 | Car Audio & Video
How do i remove radio/cd player from expert van
It all depends on the MAKE + MODEL of the radio
see if this site helps
http://www.fitaudio.com/
If your radio has 4 holes on the front, then see below
Here is a video showing how to remove your radio from the dashboard. A pair of extractors are required (available from Ebay , Halfords etc ) but these can be made from 2 pieces of bent, wire coat-hanger or 4 small drills(using the blunt end)  or 4 small Allen Keys or 4 small screwdrivers or 4 nails or even 4 darts.
An assistant is useful to pull the radio out whilst you are releasing the 4 securing clips
 http://www.youtube.com/watch?v=urC-4NbXvDQ
Jan 13, 2010 | Car Audio & Video
CD PLAYER CODE LOST
If it is a factory radio you will have to remove it> call your local mit dealer and give them the # on the back of the radio. They will tell you the code.
Mar 28, 2009 | 2007 Mitsubishi Montero Limited
KENWOOD AUDIO PASSPORT 4 DIGIT CODE
Contact Kenwood at 1-800-KENWOOD
or look on Ebay for auction #260269084583
Leadispenser
Aug 25, 2008 | Kenwood KDC-135 CD Player
How to remove the cd player from Honda odyssey EX 2002 model
The trim panel that surrounds the radio and contains the climate controls and possibly 1 or 2 other switches needs to be removed. Apply gentle, even pressure on the edges and gradually move to the other edges, and the clips should pop out.
I would advise against unplugging the climate controls or radio however other switches can be unplugged safely.
Once the panel with the climate controls is removed there should be 4 phillips head screws holding the radio in place; remove those and you should be golden.
Feb 19, 2008 | Car Audio & Video
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
