Question about Philips 42PFP5332D 42 in. Plasma Television
Power Problems - won't turn on
Philips 42PFP5332D/37 power problem. I get the click.
The set blue light comes on, then then standby light comes on and flashes. no picture, no sound and no help from philips. Anyone knows the cause and possible solution? Help
  • 52 Answers
First thing to do is determine if there is a blink code as that gives a direction for t/s. regardless, what you should do first is offload the y main and x main sustain boards from power supply one at a time as there is a common issue where these boards can cause load on power supply and if voltages come up with either one offloaded that board should be replaced before proceeding. if y main is the issue there is an upper and lower buffer board to left of that board and also should be replaced at same time as 3 boards complete a circuit and replacing one could cause damage to others.
Posted on Aug 18, 2008
Philips model: 42PFP5332D/37 The other day it clicked and the picture went out. The blue light comes on and it stays blue with no picture or sound
Your set need a thorough check-up. Contact the authorized service centre or an experienced service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 14, 2015 | Philips 42PFP5332D 42 in. Plasma...
My philips 42pfp5332d/37 when i turn it on the blue light comes on and it has no picture and just makes a clicking noise. If you look at the back you can see 2 green lights go on and off. it happened after...
Power supply board is dead.Replaced the power supply board,that the board where the power a/c cord go into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jun 06, 2010 | Philips 42PFP5332D 42 in. Plasma...
I have a 42pfp5332d/37 plasma tv. I can not turn it on using the remote controller, however when plugged to the AC power source the blue light on the bottom left corner comes on and the screen is black and...
U know basic electronic's and soldering?Take ur tv aparts,where the A/C cord goes that power supply board.Searches all around the power supply board and it supporting boards.Look for these defective parts call capacitors,these capacitors have lekages of gases in one or two years of the tv in used,they alway bulges up it top,puff up it top.These capacitors are dead,replaced them u will stop hearing cliking,and have ur tv power back.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 07, 2010 | Philips 42PFP5332D 42 in. Plasma...
My philips 42PFP5332D/37 keeps making a clicking sound, it wont turn on, and like most other post i have read, the blue power light stays on, but nothing more..it just keeps clicking, its been doing this...
I had the same problem and it was the power supply board,but I replaced it myself and only spent about $140.00 for the part and 2 day shipping . It was easy just pull the back cover off and there are about 8 small screws that hold it on and like 6 connectors that's it. Also ShopJimmy.com was the place for parts on these T.V.'s.
Nov 07, 2009 | Philips 42PFP5332D 42 in. Plasma...
Philips 42 plasma tv. Blue light but no pitcure or sound
it is the bulbs inside the tv you can get them replaced and it should work
Jul 01, 2009 | Philips 42PFP5332D 42 in. Plasma...
Power Problem
usually blink code on front gives direction but first thing to do would be to determine if surrounding sustain boards are causing draw on power supply by disconnecting them one at a time from power supply. y is on left looking from back and x is on right looking from back. if led goes solid with either board disconnected check supply voltages and if come up and stay up replace that board. if no change then you would need to verify vs on command coming from logic main to power supply. should be labeled on power supply connector and should be 3 volts. if present replace power supply if not present verify if logic main board sitting underneath signal board has one solid and one blinking led on if verifying normal operation and if so replace small signal board
Aug 15, 2008 | Philips 42PFP5332D 42 in. Plasma...
Philips Problem
Jul 23, 2008 | Philips 42PFP5332D 42 in. Plasma...
Philips 42PFP5332D 42 in random clicking problem
EVERY TIME I HAVE SEEN THIS PROBLEM IT HAS ALWAYS BEEN THE SMPS...SWITCHMODE POWER SUPPLY CIRCUIT BOARD...THATS WERE THE NOISE IS COMING FROM...RELAYS ON THAT BOARD ARE BEING ENERGIZED WHEN THEY ARE NOT SUPPOSED TO...THE UNIT SHOULD REMAIN IN STANDBY MODE UNTIL AN ON COMMAND IS RECEIVED VIA THE REMOTE CONTROL OR SET POWER ON BUTTON...TRY REPLACING THE SMPS..JOEACE
Jun 06, 2008 | Philips 42PFP5332D 42 in. Plasma...
Philips 42PFP5332D 42 in. Plasma Television Logo
566 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
