Question about Amana ARGS7650SS Gas Kitchen Range
Amana ARG 7300W - Oven will sometimes come on mostly delayed and more often then not it does not come on at all. If you try to fluctuate the temp when it does come on the oven stops working
aborcass
  • 2651 Answers
SOURCE: Amana gas range
the only f5 code listed for the amana range states faulty erc(electronic range control) solution replace control
Posted on Feb 26, 2008
jonniewalker
  • 1029 Answers
SOURCE: Amana inside oven light not working.
check the socket assembly.remember Before repairs or testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. ! check the switch Usually the switch will be either on the control panel or inset into the oven door opening. Now you need to gain access to the back of the switch in order to test it. Check your range's operating manual for access and mounting details. Most switches are push-in types, and you can carefully pry them out from their location with a thin-bladed screwdriver.
  1. Once you have gained access to the switch, label and disconnect the wires from the switch's terminals Set your VOM to ohmmeter function and set the range to R X 1. Touch a test lead to each of the two terminals on the switch.
  2. If the contacts of the switch do not make contact in either on or off positions, there will be no continuity in either position. If the switch is shorted, there will be continuity in both positions. In both cases, the switch is defective and must be replaced.
  3. Carefully replace the wires to the correct terminals of the new switch. Now install the new switch in its mounting position. hope this helps. pls appreciate by rating as fixyaa
Posted on Dec 23, 2008
SOURCE: Amana ARGS7650 Keypad has no power
what ge gas oven was purchased for replacement part
Posted on Aug 01, 2009
  • 80 Answers
SOURCE: Hello. Regarding my Amana range (MODEL: AGDS902),
You will have to replace the bottom element.
John
Posted on Oct 03, 2009
SOURCE: how do I clean my amana gas self cleaning oven
I have an Amana self-cleaning oven, Model AGR5715QDQ. I can't find my manual - how do I start the process of cleaning? Elizabeth
Posted on Nov 22, 2009
Amana fridge, AS2628HEK fluctuates in temp.Keeps repeating. Replaced the front display board, has been on lock for some time, ice and water were not operating, now it works again but temps not stable?
Replacing the front display board will not do anything other then tell the main control board what you would like to do. The control board that controls the operation is in the fresh food section up in the console area. What do you mean by temps not stable? Refrigerators do fluctuate in temperature especially after defrost.
Dec 07, 2016 | Amana Refrigerators
How close should the temp control hold the temp
Generally the oven temperature will fluctuate as much as 30 degrees above or below the set temperature. The longer the oven is on, the less the temperature fluctuates. If you measure the highest and lowest temperatures readings with a thermometer after the oven has been preheated at least 20 minutes, you should come up with an average temperature somewhere within about 10 degrees of the set temperature. You can calibrate most ovens up to 35 degrees higher or lower if it is off. Any more than that requires replacing parts.
Apr 24, 2014 | GE Profile JTP18 Electric Single Oven
Arg 7302LL OVER DOE NOT LIGHT
Your light blew out.Now I'm not criticizing but that like the only answer there is.
Nov 13, 2011 | Ovens
Amana bz22rw fridge temp fluctuates & is a little warm - freezer is ok should i replace the fridge temp control or the damper
Temp control = controls run time of the compressor and temp of freezer.
damper and cold control = control how cool the fridge is...
also check you fan speed and air flow to the fridge.
Sep 19, 2009 | Amana Refrigerators
Amana oven doesn't heat
IS it gas or electric? If it's gas, you may need to have a technician regulate the air and gas. If it's electric your t-stat may need to be replaced. Hope this helps! :>)!
Aug 14, 2009 | Ovens
G E oven temp fluctuation
No, that is just fine. As a matter of fact, older ranges often had 50 to 60 degree swings in temp. Your oven temp (assuming your thermometer is dead on accurate) is 347 + 365 / 2 = 356 degrees when set at 350. I never mess with ovens which are within 10 degrees of set temp. (when checking the temps, make sure to take the readings after the oven has cycled on and off at least three times, and use a good digital oven calibration thermometer)
Mar 18, 2009 | Kitchen Ranges
Ovens do not come up to set temperature
most common issue wsith these gas wall ovens is faulty ignitors, i would reccomnd replaing the ignitor(s). that being said i wouuld also reccomned a servicer with experience on this model for they can be a more tricky then ohter ranges out there, and the possiblity of "shorting out" adddiont al parts is higher on this model! and no one is currently producing a double self cleaning, full sized gas wall oven, so id hate to see you ruin this one!!!
Feb 16, 2009 | Amana AOGD2750 Gas Double Oven
Amana first addition oven (approx 10 years old) will not heat
I had a similar problem with my Amana oven, also about 12 years old. It was slow to heat and sometimes wouldn't reach the set oven temp. I replaced the oven igniter on a tip that it wasn't drawing enough current to open the gas valve solenoid. That did the trick. It starts immediately and heats to the right temp. Good luck. Joe
Dec 23, 2008 | Amana AGDS902 Gas Kitchen Range
Amana Gas Stove M/N ARG 7302WW set temp. is higher than desired t
the oven safty valve is goin bad. that the part that most oven burners sits on.
Dec 09, 2008 | Amana ARGS7650SS Gas Kitchen Range
Kitchenaid oven KGRT607 HBS6
I also have this problem. Replaced control board, but didn't help.
Sep 01, 2007 | KitchenAid KESC307 Electric Kitchen Range
Amana ARGS7650SS Gas Kitchen Range Logo
37 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
