I have the samsung HT-X70 model, and it continually shuts itself off, and in the digital window it will say protection - Good bye. it normally will not last more than 20 minutes without this happening
    Brigadier General:
  • 8,546 Answers
Heat.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on May 22, 2011
Hello my Samsung HT-x70 plays for about 20 minutes and then shuts off. Please help
First check in back that the fan is running. Second: Remove cover and check for bad capacitors in the back right corner. The ones in my system were blue. one had totally dissolved. I replaced the capacitor ad the system worked fine, Then found the fan was not running so replaced that too. It does take some soldering to repace the capacitor.
Jan 02, 2010 | Samsung HT-X70 Theater System
Samsung ht-x70 problem at loading dvd, it stay at a loading looping
I AM HAVING SAME PROBLEM WITH MY HT-X70 I HAD FOR ABOUT 3 YEARS NOW. I OPENED IT UP AND DUSTED THE LASER OFF BUT STILL NO LUCK. ONLY THIN I CAN THINK OF IS LASER IS BURNT OUT AND NEEDS TO BE REPLACED
Nov 02, 2009 | Samsung HT-X70 Theater System
Bought a samsung dvd home theater system HT-X70 off of ebay and its plays beaytifully for like 10 minutes into the movie and then all the sudden it flashes "PROTECTION" and then shuts off. I unplud it and...
Sounds like a heat problem, look on the back of the player and see if the fan is full of debris ( dust, pet hair, ect.) blow it out and see if that helps.
Aug 08, 2009 | Audio Players & Recorders
Samsung ht-wx70 shutting off for protection
The word PROTECTION means that the cooling fan is defective. it needs to be replaced.
Call 1-800-7267864 (SAMSUNG) and they can repair it for you.
Hope this helps!
Jun 30, 2009 | Samsung HT-WX70 Theater System
I have a samsung home theater system HT-X70. After 10 to 15 minutes the word protection scrolls across the screen then goodbye and finally the unit shuts itself off.
ther is dc voltage applying your speakers by amplifire itself and turn on speaker protection circuit itself.
it can be happens because
1.loose connection in amplifire board
2.faulty output section of amplifire
3.short circuit of speakers
4.error detecting circuit faulty.
if youcan open the cover and clean the circuit for dust and resolder the circuit with 30 W soldering iron cairfully.if you want the more asistence please come again
ican hlp you more.
Jan 08, 2009 | Samsung HT-WX70 Theater System
Problem "protect"
Hey guys, just had the same problem and found out it was because I had disconnected the central speaker. This it was creating a back impedance or something and reonnecting did the trick! i.e. check your speaker connections and check that they work... duff speakers could cause the problem too!
Sep 20, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Dvd multiregion unlock code
use the procedure for unlocking the Samsung HT-DM150 .
Oct 28, 2007 | Audio Players & Recorders
Dish 6.3 remote code for Samsung HT-X70 DVD/receiver
You will have to use the AUX button to program it to . Press AUX till lights light up then enter 4 digit code (if you have a 3 digit code use 1 as the first number) then press pund. And your good to go howevetr the only functions that may work is powere on an off.
Oct 08, 2007 | Televison & Video
117 people viewed this question
 Grubhead
Grubhead
