Question about Iomega 160GB Ego HD USB 2.0/FW Red 160 GB Hard Drive
Ego 160 not working - not recognized by computer
    Brigadier General:
  • 10,406 Answers
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Posted on May 21, 2011
How do I password protect my iomega ego
Plug your USB imoga ego usb drive into your computer.
Click on the "My Computer" icon at the top of your computer screen.
Double click on the iomega USB icon.
Right click in a blank space in the middle of the window to pull up a small menu.
Select the "New Folder" option from the menu to create a new folder on your Iomega USB 2.0 drive.
Drag all of the files that you want to protect into the new folder you created.
Right click on the folder that you created and select the "Properties" option from the menu.
Go to the "Sharing" tab and click on it.
Scroll down to the "Make This Folder Private" box and check it. Click the "OK" button and wait for the window to close.
Use your Windows log-in password to open the file.
hope this helps
Oct 22, 2012 | Iomega 160GB Ego HD USB 2.0/FW Red 160 GB...
Iomega ego USB not connecting
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Feb 12, 2012 | Iomega eGo Helium 1TB USB 2.0 Portable,...
Well my problem is that my Iomega eGO usb 3.0, 1TB is not being recognized by my computer. when I connect the hard drive via usb 3.0, the computer doesn't recognizes it. I'm using the Conceptronic Pc...
you might have to uninstall the express card restart your computer then reinstall it also make sure its clean and securely seated and there is no dust built up or it might be trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
ports(com&lpt)right click update driver hope this helps
Mar 23, 2011 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
My Iomega eGo 500 GB Extern Hard Drive stopped working, it says that USB is not recognized (I tried in 4 pc's) and LED is ON. What can I do to get it back working?
if that happens after trying it on different computers then it means the magnetic needle inside the drive is broken and will need to be replaced.
Feb 25, 2011 | Iomega 160GB Ego HD USB 2.0/FW Red 160 GB...
My external hard drive does not work on windows xp
You might need to initalize it in XP and then assign a drive letter.
Aug 29, 2009 | Iomega 250GB Ego HD USB 2.0/FW Red 250 GB...
Computer doesn' t recognize iomega eGo portable
a windows update may have run and killed the drivers...try rolling the system back to before the problem started, then if updates run again..and set them to download but dont install..install them yourself..run updates and see if the problem re-appears.
Jul 24, 2009 | Computers & Internet
Iomega Ego USB is not being detected by any computer I plug it in
Your drive is a coaster. Iomega products seem to be made out of tissue paper and mucilage. You are lucky that it worked for any amount of time at all and wasn't dead right out of the box. Have you tried their online-only tech support? (You can call them for $25 if you want to.)
Jun 16, 2009 | Iomega 160GB Ego HD USB 2.0/FW Red 160 GB...
My computer does nor recognize my new portable hard drive ego helium 320gb
Format it using another PC that will recognize it and plug it in to the PC that does not recognize and it should work.
May 12, 2009 | Computers & Internet
My ego 160gb is not being recognized in windows xp
well..then..it's time to drop your attachment to the ego state..just kidding..
who makes that unit? you may need a fresh set of drivers
first, though, unplug it, unhook from computer, then plug in to wall, then to computer..xp should see it.
Apr 27, 2008 | Computers & Internet
Iomega 160GB Ego HD USB 2.0/FW Red 160 GB Hard Drive Logo
422 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
