Question about Logitech 967233 Keyboard
Keyboard will not work during post or boot
My motherboard recognizes that there is a keyboard because it does boot to windows. But it will not allow me enter into my BIOS or even windows safe mode. The only time that it recognizes a key stroke is in the login screen for windows XP.
  • paramedic416 Mar 11, 2009
    I have the same problem, but when I checked the Bios with another keyboard. The legacy USB was enabled... So now what?
  • lee5338 May 11, 2010
    have done that and I still can't type any thing
    Problem Solver:
  • 16 Answers
The problem you are experiencing is caused by a setting in your BIOS. I recommend getting or borrowing a keyboard with a PS/2 port or getting a USB to PS/2 Adapter for Keyboards. Once you do, you can change the setting in the BIOS to accept USB keyboards. If you are already familiar with BIOS then you don't need to read further to enable USB support, other wise I recommend continuing to get familiar with what you are looking for.
When you get a keyboard that uses a PS/2 port, go to the BIOS for your computer. Go to "Advanced" and search for "USB Legacy Support" or something similar in terms of "USB", "keyboard", or "input". Once found, you will have to change the setting to enable USB. If the name of the setting has "USB", then you want it enabled. If it has "keyboard" or "input", then look at the available options for USB and use it unless it has something similar to "dynamic" or "auto-detect" which are better choices.
After finding the right setting and selecting the correct option, go to "Exit" and select "Exit and save changes". Then the BIOS will save and reboot the computer or continue on as if you didn't open up the BIOS.
Posted on Aug 15, 2008
This solution really works.. I had the same problem. My CPU refused to take any input from keyboard when I tried to press F8 to start Windows in Safe Mode. When I followed these steps, my USB based keyboard started working. Thanks Zanoab !!
Posted on Jan 22, 2010
Why msi motherboard not recognizing keyboard?
The simple answer is to try a different keyboard first just to make sure that the problem isn't the keyboard. If it still doesn't work go into the BIOS and change the settings to report an error if no keyboard detected, if it says it can't find a keyboard during the boot process, then you may have a problem with your hardware/BIOS chip
Aug 18, 2014 | Micro-Star MSI 760GM-P34 FX Desktop...
Keyboard doesn't work after boot
Try booting up with the ps2 keyboard.Once in Win 8.1, unplug ps2 and plug in usb keyboard. See if windows will recognize the usb keyboard and if so it should install software and drivers
Nov 19, 2013 | Gigabyte Computers & Internet
A program deleted my keyboard and now I don't have one showing when I check the keyboard in my control panel. It works at the very start up but not after. I have tried a new keyboard and windows doesn't...
Generally additional drivers are needed for basic keyboard functionality, although Windows does actually install them as unique devices. Sometimes this process can take several minutes (depending on computer speed) and the keyboard will be unresponsive until it's actually installed. Try plugging in your keyboard, rebooting the PC, and giving it a few minutes once it's up and running.
If that doesn't work you can try booting into Safe Mode by hitting the F8 key during the startup process. This will load generic drivers and will allow you to troubleshoot additional drive and/or software issues.
May 02, 2011 | Microsoft Basic Keyboard 1.0A PS/2 KEMIBA
Dear Fixya, my GA 6bx7 (Intel bx440) , GA GF400mx,JNC 235 W Power,Cel 900Mhz start clicking just seconds after (or during) Post (no Hdd ). In Bios signal sound more loudly. There is second or more...
your hard drive is dying or dead,mouse and keyboard ps2 will normally work with operating sys,try with another h/drive should work clicking are heads crashing good luck!
Jan 08, 2011 | Intel Motherboard
Keyboard not working only during booting
If your keyboard is USB, switch to a standard PS/2 keyboard, and enable legacy support for USB in your bios.. This may help you, but your bios may not be able to use a USB keyboard during POST.
May 31, 2009 | Intel Motherboard
BIOS not reachable due lack of PS2 or USB keyboard
just to clarify, your system works well with USB keyboard but doesn't with PS/2.
Jan 06, 2009 | Asrock P4i65GV Motherboard
USB Devices not recognized
Go into bios by pressing F2 on boot and make sure that usb support is enabled. If it is then boot and go to device manager and uninstall the usb devices, then try to reinstall. Instead of just updating the drivers.
Nov 29, 2008 | Foxconn 6150BK8MC-KRSH Motherboard
Asus M2N keyboard problem
You don't need a driver for a PS/2 keyboard nor a USB keyboard. The keyboard lights should lite up at post. After boot press the Caps Lock key and it will light the corresponding light on the keyboard if the controller works. If not it is the motherboard. If you are strapped for bucks get a mobo that can use the same cpu, RAM and drives. Good luck, Steve Medley
Nov 06, 2008 | Computers & Internet
Splash screen reboot
ok, for what I understand you changed your motherboard, tried to boot your old windows and it went bananas on you. Wich is really not uncommon. Then you tried installing windows and your keyboard would not do anything. As far as the keyboard issue goes, I am guessing that you use a USB keyboard. Windows is such a wonderful piece of software that it's no surprise it acts up like that. Try enabling USB Keyboard support in the BIOS, or better yet, try connecting a PS2 keyboard (the round plug). Chances are everything is gonna be just fine after that.
Good luck
Alex J.
www.CAS411.com
Feb 24, 2008 | Evga (122-CK-NF68-T1) Motherboard
Keyboard shuts off after booting up
try starting up in Safe Mode by tapping the F6 key during boot-up. this prevents drivers from loading. you may have a corrupted keyboard driver. if your keyboard works in safe mode, try uninstall of the kbd driver, then reinstall.. check for a newer driver version.
Jul 11, 2007 | EliteGroup P965T-A Motherboard
Logitech 967233 Keyboard Logo
2,819 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
