Question about Uniden Cordless Phone
How do I put a number on speed dial? - Uniden Cordless Phone
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Since you didn't specify the model of your phone, select it from the list beginning at
http://www.uniden.com/scat/cordlessphones_mnl
to get the manual.
Posted on Aug 29, 2011
How do you put speed dialing in a samsung GT-C3520
To Set speed dial numbers do the following:
1. In Menu mode, select Phonebook.
2. Select a contact to assign.
3. Select More -> Add to speed dial.
4. Select a number (if necessary).
5. Select a speed dial number you want to set.
The contact is saved to the speed dial number.
Note:
• You can call this contact by touching and
holding the assigned speed dial number in
the dialling screen.
• The first 3 speed dial numbers will be
assigned to the top 3 list on the widget toolbar.
May 16, 2014 | Samsung GT-C3520 Unlocked Quad-Band GSM...
Speed dial
Feature *4 for personal speed dials.
If you mean Auto Dial button then Feature * 1
Dec 11, 2012 | NorStar M7310 Corded Phone
How to put numbers into speed dial on a Sprint Rumor Reflex
Go to the contacts list. Hit more. Settings. Speed dial. tap a number and select the contct/phone number combo to call.
(Source: I literally just did this on a customers cell phone in best buy mobile)
Apr 07, 2012 | Cell Phones
How to put in speed dial #s in 2.4 Hz Bell cordless phone
With the phone offline press MEMO. The IN USE light will flash. Enter the telephone number you want to store and press MEMO again. Then press the number key under which you want to store the telephone number. To use speed dial, press TALK, MEMO, and the number button where the telephone number is stored.
Jul 21, 2010 | Northwestern Bell 36280-1 2.4 Ghz Cordless...
Programming Auto Dial Number
Yep. Those are speed dial numbers. They are programmed from ext 101 or the main phone. Without picking up the handset, press PROG **1234 and dial 001 and ENTER. Dial your 3 digit speed dial number If there is something there, it will be displayed. A speed dial number is stored with the trunk access code in it (usually 9) so if you're putting in a new number, include the "9" plus the number exactly the way you dial it. Dial your new number with the access code and press ENTER.
Number changed :-)
You can keep putting in a whole boatload of new numbers with this procedure.
Carl
Mar 16, 2009 | Panasonic KX-T7633 Corded Phone
Speed dial access
It's easier if you have access to the database to put in names with the numbers, but in the simplest sense, you can take a piece of paper, write down locations, and start entering numbers.
PROG
They are added in sytsem speed dial from the first extension or one designated as the manager's phone. PROG **1234 gets you into programming and 001 is the system speed dial area. With a combination of NEXT's and ENTER, you can be looking at SD 000 (ie PROG **1234 NEXT NEXT ENTER NEXT) and you're ready to enter a speed dial in bin 000. The complete number starts with an access code (9) plus the number as you would dial it. For example 918005551212 ENTER puts that number in bin 000. NEXT will step to 001.
USE
Press INTERCOM or select a line and press AUTODIAL and dial the 3 digit code. If your installer was lazy, you will have a problem as "9" selects the highest line in a trunk group, one that you might not have. In that case, he'll either have to program the system properly, or you will always have to pre-select a line to use speed dial.
Notice that this is just hte instructions for SYSTEM speed dial. I guessed that it was what you're looking for. Personal speed dial is a different set of instructions and it could be either under a button or in your 10 or 100 number personal directory (so that's where the 2 digit SD's went :-))
Anyway, if you need those instructions and can't find them in the user manual, please post back.
Carl
Nov 21, 2008 | Panasonic KX-T7630 Corded Phone
Speed dialing
which model ?
generally in all cell phones v will be have speed dialing option in range costing handset also... v can set the 9 speed dialing numbers .... in which 1 speed dialing number is common that is sos(112) in samsung and motorola handsets ... common thing is may be in sony ericson also i m not sure ... in nokia handsets if we make the speed dialing option on then if we just press one number means we can call to the person ...
for ex: you may be having some person whom u will call frequently instead of selecting the number by going to phonebook if you put that number to speed dialing list means you can call them by pressing only one button...( while adding to the speed dialing list it will ask to assign the keys like 1,2,3... 9)
as every handset keypad will be having 0-9 number keys this is very useful ...
in some handsets the speed dialing option is found in phonebook & while in other it will be found in call options...
Feb 07, 2008 | Cell Phones
Speed dial not working
Maybe because the speed dial service is not on.
Click.
Menu -> Settings -> Cal Settings -> Speed Dial -> On.
then try.
Nov 14, 2007 | Nokia 6030 Cellular Phone
I have done it. I have found a way to chance the speed dial settings on my Samsung D900i.
The following instructions work for my phone but I cannot guarantee they will work for everyone else.
YOU WILL NEED A PEN AND PAPER.
Press Menu > select Phonebook > Speed dial (4) >Select
You should see names assigned to the numbers.
Decide which speed dial number you want to change e.g. 2 Mum Mobile (remember the name)
Press Back > Contact list (1) Select
Type in/go down to that name e.g. Mum Mobile (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > choose Yes > Back > Speed dial (4)
You should now see that Mum Mobile has been replaced with a big number 2. This means that speed dial number 2 is un-assigned.
Press Back > Contact list (1) > Select
Decide who you want to be assigned to speed dial 2 (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > Yes (HERE IS THE WEIRD THING)
Press Back > Create contact (2) > SIM (2) >Select
Type back in the name and number of person you have just deleted > Save > Back > Speed dial (4)
You should see that Speed dial 2 is now the person of your choice.
HOW COOL IS THAT!!!!!!!!!!
Press Back > Create Contact (2) > Select > SIM (2) > Select
Type in Mum Mobile and Number (THE FIRST NUMBER YOU WROTE DOWN) > Save.
That is it, repeat the instructions until you have all the speed dials of your choice.
Hope this helps the many frustrated D900i users out there.
Aug 31, 2007 | Samsung SGH-D900 Cellular Phone
Resprogram speed dial numbers problem
You can reprogram them using bitpim.
Jun 10, 2007 | Motorola Mobility RAZR V3
Uniden Cordless Phone Logo
20 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
