Question about Ritchey Probiscus Aero
I can't find a diagram for attached the padded arm rests for the Ritchey Probiscus aero bar
    Brigadier General:
  • 8,546 Answers
The L-shaped brackets go on the handlebars. It has a couple of width and fore-aft choices depending on how you orient them and which holes you use. Swapping them left-to right gives some variations, too.
The screws go down through the platform for the padded part into the L-shaped brackets and you stick the pads over them.
This picture might help...
http://www.thecyclepeople.com/productdetails.asp?id=1037
Posted on May 21, 2011
HOW TO ASSEMBLE WEIGHT BENCH ?
Lay out all the pieces and check the instructions to make sure everything has been included with your weight bench. Attach the cross brace to the left upright beam and repeat the process for the right upright beam. Tighten them together with carriage bolts and set the backrest adjustment bar onto a slot on the upright beams.
Connect the main seat support beam to the cross brace with two carriage bolts, two washers, and two nuts. Do not completely tighten the nuts in place. Attach the main support beam to the front post with Allen bolts and washers. Connect the diagonal support beam to the front post in the same manner. Attach the other end of the diagonal support to the main seat support beam.
Place the arm curl stand in the front post and secure it in place with a lock knob. Tighten it down completely. Connect the leg developer post to the bracket on the front side of the front post. Attach the arm curl handle to the open bracket on the leg developer with an L-shaped lock pin.
71hekan4jtl._sl1500_-qw1ux3sfzoyydmyeq2qu2kbl-2-0.jpg Attach the bracket supports to both ends of the pivot arm of the support beam and lay the other ends on the backrest adjustment Pull up bar. Connect the backrest board to the supports with four hex bolts. Attach the seat pad with four hex bolts onto the main seat support.
Secure the preacher pad arm to the curl stand with two Allen bolts. Put two foam tubes into the leg developer halfway through the holes and attach the four foam rolls onto the ends of the tubes.
May 28, 2018 | Bench Exercise & Fitness
Ritchey Bikes Racing with crew handle bars
It's a good idea to actually ask a question if you want an answer.
Aug 03, 2017 | Ritchey Cycling
1978 chevrolet pickup power window motor removal
You will need to remove the door handle inside and the door kick pad along with the arm rest and any switches on the door. To remove the kick pad remove the screws around the pad an the switches along with the door handle and arm rest once that is completed just push up on the kick pad and it will come out of the track at the top of the door and then you can see the motor inside the door.
Apr 23, 2017 | Chevrolet Cars & Trucks
How to fit an upgrade armrest on an x type jag?
The center arm rest is attached to the console by 2 small Hex cap screws. The arm rest and intermediate slide panel are attached to the same hinge assembly with rivets.
to replace the upper arm rest, 1st remove the assembly from the console by removing the 2 hex screws this will allow you to work outside of the vehicle on a work bench. 3 rivets hold the arm rest to the hinge. You will need to drill out the rivets using a 1/8" drill bit. and install the replacement arm rest using new 1/8" pop rivets.
see illustration
Feb 07, 2015 | Jaguar X-Type Cars & Trucks
I need a diagram of rear suspension on 1994 Ford Tempo
It's called a control arm. Sway bar is definitely not one of the names. The other two could be, but for different manufactures. And the parts look different. But have the same funtion.
Aug 30, 2014 | 1994 Ford Tempo
2006 Honda 750cc Shadow Aero starts with choke, runs for a minute, sputters and stalls. Won't start again for a couple of days, then starts right up. Electrical?
Hi there
I once had a wee car,whenever it got too much petrol inside itself it refused to go anywhere and had to rest for some time and you had to be very careful with the choke and the petrol so it did not swallow too much of it and need another rest.
kolbrun
Apr 02, 2012 | 2004 Honda VT 750 Shadow Aero
Front tire vibrates when i apply break
Okay.....if it doesn't prove to be the rotors,it's probably the sway bar link bushings,or the sway bar mount is defective(loose). BEEN THERE......SUFFERED THAT! LOL! don-ohio (:^)
Jan 15, 2012 | 2002 Ford Explorer
Can't get the Lock Cutter Attachment to work. The right hand cut fabric won't feed through the fabric just won't go through and get cut and over sewn
tally_girl_35.jpg have you got the little silver arm with a gap in it (see photo above mounted over the needle bar? This is essential as the movement of the needle bar going up and down is driving the blades in this attachment.
The walking foot attachment for sewing machines works the same way, you need to place the little arm over the needle bar to make this aftermarket accessory work as its not driven by the sewing machine motor, purely by the movement of the needle bar.
Saying that, I would be suprised if this attachment cut heavy weight fabric or several layers well, like many things made to imitate a purpose built machine (serger) there is no substitute for the real thing. It might be fine to just trim the fabric loose threads off a fabric edge but also you would need to watch that the trimmed bits are going somewhere and not getting into the seam or your machine. On a serger, the blades are working right beside a vertical drop off with a waste tray below and there is a lot of lint and fibres trimmed which quickly builds up. With this attachment, you'd have to manually ensure that the trimmed fibres are swept out of the way.
I hope this helps you to get it working though - 4 thumbs up if so. :-)
Jun 22, 2011 | Singer Inspiration 4206
What torsion do i set this stem with EA70 Handlebars
The stem should have the torque settings labeled on it. Ritchey, another reputable stem and bar manufacturer calls for 5nm for the handlebars in their installation guide.
Feb 16, 2011 | Easton EA 70 Road Stem
Wiring diagram for 1996 gmc sierra brake asembly
The brake light switch is at fault. Get a new one and replace it. The location is at the brake pedal area mounted on a bracket with a plunger stud that rest on the brake pedal's arm the pad is attached to
May 08, 2010 | 1996 GMC Sierra
Ritchey Probiscus Aero Logo
197 people viewed this question
Top Ritchey Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Ritchey Cycling Expert? Answer questions, earn points and help others
