Question about Toro Power Lawn Mower
After pushing the red fuel primer butten the engine runs for a minute then shuts off.
    President:
  • Toro Master
  • 1,545 Answers
This is indicating a fuel flow problem. I would start at the fuel tank and work my way to the main fuel jet on the carburetor. Make sure there is no foreign debris in the tank. Make sure your fuel line is clean and clear of any debris. Small particles can cause huge problems. I recommend installing an inline fuel filter on ALL small equipment. Once the tank and line are clean and clear, remove the float bowl on the carburetor and clean it. The brass bolt that holds the bowl on is also the main jet of the carburetor. I has to be cleaned as well and has very small orifices in the length of it near the top that have to be clear. Use NO metal objects to scrape or clear the main jet. It can be cleaned pretty well with aerosol type carb/choke spray cleaner. Clean the jet till shiny and reinstall. These steps should resolve your fuel flow problem.
Posted on May 22, 2011
Will not prime with primer bulb , can squirt gas in carb and get running then while running you push the primer button it chokes down the engine .
Does it stay running after you squirt fuel in the carb opening? If yes, then there may be a pin hole leak in the hose going from the fuel tank to the primer bulb and it is adding air to your carb.
Thanks
May 01, 2015 | Craftsman 675 Torque 190cc 21" Briggs ...
My TB70SS Bronco weed eater primer bulb will not return when pushed, thus will not run.
something is plugging the fuel flow from tank. the primer is actually as far a fuel flow goes is after the carb. fuel goes from tank to carb to primer and back to tank. could be fuel filter gummed up or plugged. take off line coming from tank filter to carb and see if it pushes in and pops back out. if so its your fuel filter.if it still does it something is plugged in carb. there are little flapper valves in primers to allow fuel in and push fuel out. could be one of those gummed shut. all depends on it has the primer blb on carb or seperate place as to how well you can see where the problem lies.
Aug 09, 2011 | Troy-Bilt Garden
I have a yard machine mower model number 11A-549R729 that will not stay running. Have replace plug,drain fuel tank and clean carb. If you push the primer bulb it will continue to run. But once you stop...
Your carbs main jet is blocked. Using the primer supplements the fuel input and keeps the engine from becoming fuel starved.
You need to remove the main jet and run a strand of fine wire through the jet to clear it.
Aug 17, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Edger will not stay running
Your diagfram is bad replace it in your carb and you will be ok
Apr 12, 2010 | Yard Machines Red Edger
Engine starts right up after pushing primer bulb,
There is dirt in the nozzel inside the carb,take it apart and clean it with torch tip cleaners. Remember to replace all the gaskets you disturb.
Nov 01, 2009 | Toro Lawn Mower With Toro Power Tools
My Poulan P3314 primer won't take in fuel or push it out.
the vinyl primer button on your carb shoots fuel into the crankshaft space. when you pull the rewind air and fuel in the crankshaft area is sucked into the combustion chamber. when the magneto reaches almost top dead center, the high voltage fires the spark plug. if there is an air leak in the gasket that surrounds the crankshaft, the air/fuel mixture will be way off. flooding will occur and the plug will get saturated. remove the whole back of your engine and clean the mating surfaces. now use high temp permatex and run a bead all around the gasket surface. tighten all the bolts - screws. push the primer button twice and try starting the engine.
Oct 24, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Wont stay running without pushing primer
Hi... I have a Poulan PRO Quantum xnp 6.75. Garage kept, unused approximately 2 yrs. Added fuel, primed & mower started but then shut down immediately. Then fuel began leaking from the primer button. I'm a single mom & CANNOT afford to have anyone fix this. However I am attempting to repair myself. PLEASE.... If you have any suggestions &/or solutions I would LOVE to know.
Apr 12, 2009 | Garden
Motor shuts off after about 2 minutes
If you didn't run a fuel stabilizer through the fuel system when you laid up the engine you probably have a varnish build and you may need to take the components off and brake them down to clean with a strong carburetor and jet cleaner.
It is also possible that the fuel pump is also going bad. There is a long shot quick fix that has worked for me in the past with varnish buildup. Add a strong mix of carburetor and injector cleaner of the fuel and run the engine long enough to get it into all the parts. Shut it down and let it sit a day or so. Start it up and let it run. It may run rough at first. If this doesn't work start taking it apart. Good luck.
Apr 06, 2009 | Boating
Toro Power Lawn Mower Logo
102 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
