Question about Sony Playstation 3 (PS3) Console
My xbox 360 slim won't connect wirelessly to internet it says I need a wireless adapter . Can't get xbox live . I have internet may be fault with the slim.
  • 127 Answers
Yes i think your right but i need more info or visit my website xbox360repairspro.webs for more help
Posted on May 29, 2011
I cannot conect to xbox live. I have internet and wireless .its tells me to test connection when i want to play on line. so i do that .i test it and its stops at xbox 360 to my internet.so i dont know what...
If its not a black xbox 360 slim than it doesnt have wirless so you either need a wireless adapter or ethernet cord that will hook up to the modem from the xbox.
Sep 17, 2011 | Video Game Consoles & Games
Tip
Setup your Xbox to a Wireless Network
Xbox game consoles can be connected <span style="text-decoration: underline;"></span> to a router<a href="http://compnetworking.about.com/cs/routers/g/bldef_router.htm"></a> for wireless access to the Internet and Xbox Live. Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network.<br /><br /> <ol> <li>Connect the appropriate wireless network adapter<a href="http://compnetworking.about.com/od/hardwarenetworkgear/g/bldef_adapter.htm"></a> to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet sometimes also called a wireless network bridge must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi <i>game adapters</i> that connect to a USB port.<br /><br /></li> <li>Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -&gt; Network Settings -&gt; Advanced -&gt; Wireless -&gt; Settings" On the Xbox 360, the menu path is "System -&gt; Network Settings -&gt; Edit Settings."<br /><br /></li> <li>Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.<br /><br /></li> <li>Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)<br /><br /></li> <li>Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard MS Xbox Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.<br /></li> <li>Save your settings and verify the network is functional.<br /><br /> On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.<br /><br /> On the Xbox 360, use the "Test Xbox Live Connection" option instead.</li></ol> Tips: <ol> <li>Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.</li></ol><span style="font-weight: bold;">Troubleshooting</span><br /><br /> The built-in diagnostic of the Xbox can help with any falure.Navigate to the <i>System</i> area of the Xbox Dashboard, select the <i>Network Settings</i> menu option, then select <i>Test Xbox Live Connection</i> to run the test at any time. If the Xbox 360 built-in network diagnostic fails with the following message: <br /> <ul><i>Technical configuration error. Please contact Xbox Customer Support.</i></ul> This indicates a network issue requiring further investigation. The Xbox 360 network diagnostic contains the following tests run in the order listed below. Steps for troubleshooting Xbox 360 connectivity issues depend on which test reports the failure. <br />If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /> <b>Note</b> You can use an Xbox 360 Wireless Networking Adapter with the Xbox 360 S console. If your wireless router is not near your console, you may get a better wireless signal by using a wireless networking adapter. When you connect an Xbox 360 Wireless Networking Adapter to an Xbox 360 S console, the console will automatically use the wireless adapter instead of the built-in Wi-Fi.<br /> If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /><br /> Step 1: Attach an Xbox 360 Wireless Networking Adapter to the back of your Xbox 360 console.<br /> Step 2: If a network cable is plugged into the back of your console, unplug it. Step 3: Check the light on the Xbox 360 Wireless Networking Adapter.<br /> If you're using the black adapter with two antennas:<br /> <ul> <li><b>No light:</b> The adapter is not receiving power. Unplug the USB connector, and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.</li> <li><b>Green:</b> The adapter is connected to a wireless router, gateway, or access point.</li> <li><b>Flashing green:</b> The adapter is attempting to connect to a wireless network.</li> <li><b>Red:</b> The adapter is not recognized. Try plugging the adapter into a USB port on the front of your console. </li> <li><b>Flashing red:</b> There is a problem. The adapter might be experiencing a hardware failure.</li></ul><br /> Configure your wireless settings Go to <b>My Xbox,</b> and then select <b>System Settings</b>. <br />Select <b>Network Settings.<br /></b>Select <b>Configure Network</b>.<br /> <ol> <li>On the <b>Basic Settings</b> tab, select <b>Wireless Mode</b>. <br /> <b>Note</b> If Wireless Mode is still not available, there might be a problem with your hardware. <br /></li> <li>Select <b>Scan for Networks</b>. </li> <li>Select your wireless network name. <br /><br />If your wireless network is not listed, try either of the following:<br /> <ol> <li>Try improve the router signal by moving the router position.If you are not broadcasting your wireless network name, select <b>Specify Unlisted Network</b>, and enter your wireless network name and security type. </li></ol></li><br /> <li>Enter your wireless network password, and then select <b>Done</b>.</li> <li>Press the <b>B</b> button on your controller, and then select <b>Test Xbox LIVE Connection</b>. If you successfully connect to Xbox LIVE, you'll see this screen:Choose <b>Yes</b> when you are prompted to update the console software. <br /></li></ol>
on Jan 18, 2011 | Video Game Consoles & Games
How to get xbox live with out a cable
It depends what xbox you have, XBOX 360 Slim have a wireless built in so no cables needed to connect to the internet but if you have the phat xbox 360 then you'll need an wireless adapter sold in your local store or on ebay around $40 bucks.
www.1RepairStop.com
Aug 25, 2011 | Microsoft Xbox 360 Console
How do u connect an an xbox 360 to xbox live
You need either a blue Ethernet cable to connect the Xbox to an internet outlet or a wireless router. If you use the wireless router, hook it up to your computer so it broadcasts a signal, then, depending on what Xbox you have, if its the new 360 slim you won't need a wireless adapter, you search for the signal, then connect it. If you don't have the 360 slim, then you need to buy a wireless adapter and it plugs into the back of the Xbox.
Aug 24, 2011 | Microsoft Xbox 360 Console
Cant connect to xbox live
What you need:A high-speed Internet connection such as cable A router, gateway, or wireless access point (WAP) that is compatible with Xbox LIVE. An Xbox 360 Wireless Networking Adapter (original Xbox 360 console only) Instructions: On your console, go to My Xbox, and then select System Settings. Select Network Settings. Select the name of your wireless network. Enter your wireless network password. Select Yes if you are prompted to update your console software. When you successfully connect to Xbox LIVE, your screen will look like this:
Jul 25, 2011 | Microsoft Wireless Network Adapter Xbox...
Do u need a wireless adaptor to set up xbox live??
No, a Xbox 360 Wireless Adapter is not required to access, and set up Xbox Live, but you will need an internet connection. If you are close enough to a modem or router, you can buy an Ethernet cord, and plug it in to both the modem/router, and firmly into your Xbox 360 console. You will either need the Xbox 360 Wireless Adapter, or the Ethernet cord. Ethernet cords are very cheaper, much cheaper than a Wireless Adapter, but the Wireless Adapters are much or easier to reason with. So choose wisely with money.
Jul 06, 2011 | Microsoft Xbox 360 Console
Dont know how to set up xbox live with wireless
Is this a new slim unit or the original system? If it is the original system you cannot set up live wirelessly without purchasing a wireless adapter.
If you have the newer slim model which is black with vents running up the side.
stoshua.jpg Slim Orignal
They both can be configured via the dashboard. You need to go to system settings (last screen on the dashboard all the way to the right) Choose network settings Choose wireless network Choose network settings You will need to know your wireless network's ESSID, encryption type, and key.Provided your router is set up to assign your network devices with an IP address automatically (DHCP) you should be fine at this point else you will also need to manually configure your PI address, subnet mask and as well as your gateway.
Once you enter in the information you can go back to the settings screen and test your connection to xbox live. The xbox will attempt to verify a connection to you LAN (local area network) then the internet and finally to xbox live servers. If you entered everything properly you should have no issues with connecting.
Jun 23, 2011 | Microsoft Xbox 360 Console
I bought a new DSL-2642B Wireless Router and Modem but it won't let me connect to Xbox Live, the solution that the Microsoft Solution thingy game me was to change the MTU settings, any idea of how to...
In order to connect to Xbox Live with a Wireless Modem and Router, you will need a Xbox 360 Wireless Adapter. You can get a Xbox Wireless Adapter cheap on eBay, or you can buy it Microsoft at Gamestop. http://www.gamestop.com/browse?nav=16k-Xbox+360+Wireless+Adapter
To find your MTU Settings, follow these steps.
1. Click on 'Start'
2. Click on 'Run...'
3. In the bar, type CMD, and hit enter.
4. A black box should appear. Type "ipconfig" without quotation marks in the field.
5. Your IP Address, Subnet Mask, and Default Gateway codes should pop up.
6 Go to your internet browser and type you IP Address into the URL box.
7. You should find MTU settings, and you can set them to your desire.
May 28, 2011 | Microsoft Xbox 360 Console
I have wireless internet how do i get connect to the xbox 360
Depends if you have an Xbox Elite or an older Xbox 360?
If you have an Xbox Elite then there will be an in- built wireless, For older xbox 360's you will have to go and buy an Xbox wireless adapter.
If you go to settings, network settings, and select connect to xbox live via wireless then you will be prompted to input your security details for your Wireless and you should then be connected via wireless to xbox live.
Feb 06, 2011 | Video Game Consoles & Games
How to hookup wireless internet
To connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
On the Xbox 360, use the "Test Xbox Live Connection" option instead. Tips: Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Feb 07, 2010 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
69 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
