Question about Linksys IP TELEPHONY - VOIP RTR W/ 2 PHONE PTS Router (RTP300-NA)
My neighbor gave me a linksys model number rtp300 and i cannot find the drivers. i need to install the drivers to be able to use the ethernet ports.
  • 20 Answers
Hello, Richard.
Thanks for your question. Routers do not need drivers to work, but the ethernet ports on your computer do. It sounds like those are the drivers that you're looking for. Try checking the website of your computer manufacturer and see if there are any updates for your network card.
More information about your router can be found here.
~Q
Posted on May 21, 2011
Need driver and firmware for LinkSys RTP 300, or how to set it up for simple home network with interneton the PC and laptop as the 2nd computer.
No drivers are required since there is no actual installation to to the computer. Connect the ISP modem to to the main LAN network port. Then use any available port to access network. 1.Power 2.Main drop. 3.Network. That's it!
If the router is used, you may want to reset custom settings by, holding in the reset pin till it cycles.
Advance setup.
http://www.cisco.com/en/US/docs/routers/csbr/rtp300/installation/guide/RTP300_UG.pdf
Oct 16, 2012 | Linksys Rtp 300 Broadband Ethernet Voip...
I have forgotten all details of password to change my entry into Wireless-Gv Broadband router WRT540.I need its passport to establish a Wi-Fi connection for my Amazon Kindle.William D. Little
Default backdoor passwords
On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
WAP11 MULTI n/a (none)
LINKSYS DSL TELNET n/a admin
LINKSYS ETHERFAST CABLE/DSL ROUTER MULTI Administrator admin
LINKSYS LINKSYS ROUTER DSL/CABLE HTTP (none) admin
LINKSYS BEFW11S4 Rev. 1 HTTP admin (none)
LINKSYS BEFSR41 Rev. 2 HTTP (none) admin
LINKSYS WRT54G HTTP admin admin
LINKSYS WAG54G HTTP admin admin
LINKSYS LINKSYS DSL n/a admin
LINKSYS WAP54G Rev. 2.0 HTTP (none) admin
LINKSYS WRT54G Rev. ALL REVISIONS HTTP (none) admin
LINKSYS MODEL WRT54GC COMPACT WIRELESS-G BROADBAND ROUTER MULTI (none) admin
LINKSYS AG 241 - ADSL2 GATEWAY WITH 4-PORT SWITCH MULTI admin admin
LINKSYS COMCAST Rev. COMCAST-SUPPLIED HTTP comcast 1234
LINKSYS WAG54GS MULTI admin admin
LINKSYS AP 1120 MULTI n/a (none)
LINKSYS PAP2 / PAP2V2 (VONAGE) HTTP admin admin
LINKSYS RT31P2 (VONAGE) HTTP admin admin
LINKSYS RTP300 (VONAGE) HTTP admin admin
LINKSYS WRT54GP2 (VONAGE) HTTP admin admin
LINKSYS WRTP54G (VONAGE) HTTP admin admin
LINKSYS/ CISCO RTP300 W/2 PHONE PORTS Rev. 1.0 HTTP admin admin
LINKSYS/ CISCO RTP300 W/2 PHONE PORTS Rev. 1.0 HTTP user tivonpw
also, holding the reset button for about 30 seconds will clear the password usually.
hope it helps.
If this helps you resolve your problem, please
consider giving me a good rating .It will help me
as well. Thank you.
Oct 28, 2010 | Linksys Wireless-G Broadband Router
5 port network hub
Connect the power supply.
connect the ethernet cable from your router (or the box that your isp gave you to get the internet connection) to the port labeled "Uplink" on the hub.
Connect the ethernet cable from your computer or another device to be connected to any of the ports 1 to 4. Do not use port 5 (that port is used to "chain" another hub)
Please be aware that a network hub is basically a very simple device that will not assign an internal ip number to your devices or computer, and if you have two or more devices or computers, you do need that either your "modem" (the device that is installed by your isp) is capable of handling more than one computer, or you will also need something to act as a router (your computer can do it, but you will need to know how to set up that).
Hope it helps
May 14, 2010 | Linksys (NH1005) 5x10/100 Mbps Networking...
Have linksys broadband router model # rtp300, formally used to receive Vonage service. Can this devise be used to connect a second computer in my home?
Yes.
This is a wired router.
you can connect second computer to the router.
You will need to connect the cable to the router's ethernet port and computer.
Click Here to know more about router and network
Feb 04, 2010 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Linksys RTP300 Broadband VOIP router W/2 phone ports
Have you tried to do a hard reset on the unit?
Apr 05, 2009 | Computers & Internet
No Installation CD
No it's not needed, the main things you need to know is the IP address that the router is set to and it's login details which hopefully your friend can give you. (default IP: 192.168.1.1, default login and password: admin and admin)
After that, as long as your HS Internet modem has an ethernet port you would connect that to the Linksys and your PC's to the routers LAN ports. You can then also login to the router and setup the wireless part if you have any wireless devices to use with it.
Jan 24, 2008 | Linksys Wireless-G WRT54G Router
Hookup with Vonage device
I am going to attempt to give you a solution here. But you must understand a few things before I begin.
First, I would like to clarify that if you have Time Warner internet service, you are on Cable Internet. Not DSL. (This makes a world of difference when it comes to using a router.)
Secondly, you did not specify model numbers of your devices. Therefore I am assuming that you are using the following devices:
If this is not the correct equipment, continue to follow the instructions but be dynamic and adapt my instructions to the equipment you have. It should be similar enough that you shouldn't have any problem easily doing this.
This instruction set is going to begin from a point that is assuming that we're installing all of this equipment from the standpoint of a completely new installation. From the ground up.
Let's begin.
UNPLUG AND POWER DOWN ALL OF YOUR EQUIPMENT INCLUDING THE CABLE MODEM, ROUTER, PC AND VONAGE BOX. Do not power on any of the devices until instructed to do so.
1.) Connect your cable modem to the cable from the wall.
2.) Find the ethernet port on your cable modem. Connect the blue ethernet (CAT5) cable to the ethernet port.
3.) Plug the other end of the blue ethernet cable into the "Internet" port of the router. (Older routers used to also call this a "WAN" port.) It is the only port that is seperated from the rest of them.
4.) Connect another ethernet cable to port 1 of the router.
5.) Connect the other end of the ethernet cable to the network port of your PC.
6.) Connect yet another ethernet cable to port 2 of the router.
7.) Connect the other end of this ethernet cable to the ethernet port of the Vonage box.
8.) Plug in the power adapter of the cable modem. Wait 1 minute for the cable modem to acquire it's signal and set up the connection to Time Warner.
9.) Plug in the power adapter of the Linksys router. It should only take 15-20 seconds to set itself up. (If you have made any configurations to the router prior to this, I recommend pressing and holding the RESET button for at least 10 seconds to give you a fresh configuration state to start with.)
10.) Plug in the power adapter to the Linksys PAP2 VOIP Phone Adapter.
11.) Power on your PC. You should have an internet connection with it.
You see... As I read the configuration you described, I don't think that you're using a PAP2 phone adapter. You said that you connected the "vonage device" to both your modem and your PC. This is not possible with the PAP2 adapter as it only has ONE ethernet port.
I am led to believe that you are actually using the Linksys WRTP54G which is essentially the same thing as the WRT54G, but with Vonage support built-in.
If that is the case, then you will not need to use the WRT54G router. Instead, follow the instructions that I gave you assuming that the router and the phone device are combined into one device. (The ports will still be labeled the same.)
Download the installation guide for the WRTP54G from the product page link I just gave you. You'll find the link to the User Guide on the right-side panel. This will make everything clearer for you if you do indeed have that router instead of the PAP2 phone adapter.
If you continue to be confused, please let me know. DO NOT just give me a poor rating without asking more questions. I am here to help you solve your issue. Not have my rating decreased just because someone is too confused or lazy to ask more questions.
I'm happy to help you. :)
Good luck and let me know what the outcome is. (And please be sure to list your exact model numbers in the future!)
Cyryl
Nov 11, 2007 | Linksys Wireless-G Broadband Router
Setting up linksys adsl2 modem
The ADSL, Ethernet, and USB ports are located at the back of a Linksys modem. These ports are where the phone cable and computer will be connected. The ADSL Line should be connected to the ADSL port and the computer either be connected to Ethernet or the USB port., If u r using a ethernet cable no need to run the setup cd just connect the ethernet cable and contact ur isp..
do not worry about ur sagem modem, let it be inside.. just connect ethernet cables alone..
To setup a Linksys ADSL Modem with usb cable you need to perform two steps:
  1. Connecting the Devices Together
  2. Installing the USB Driver
Step 1:
Connect the phone cable to the wall jack with ADSL service and then connect the other end to the ADSL port of the modem.
Step 2:
Make sure the power adapter is plugged to an available power outlet.
Step 3:
Connect the USB to the USB port on the back of the modem and then connect the other end top the USB port of the computer.
Step 4:
Power on the modem. After connecting the device together, install the USB driver. For instructions, follow the steps below.
Step 1:
Power on the computer.
Step 2:
When the Hardware Update Wizard window appears. Click Install the software automatically (Recommended).
NOTE: Windows XP has pre-installed drivers for the ADSL2MUE and will automatically install the USB driver for the modem.
Step 3:
Click Finish.
Nov 06, 2007 | Computers & Internet
Cannot connect
what is the model number? you can go to this site
www.linksys.com/download
or www.linksys.com only and search for the product. the model number is underneath your device.
Oct 01, 2007 | Linksys 5-Port Ethernet Switch (SD205-UK)
Network adapter install drivers
These drivers are readily available at www.linksys.com Just look under Downloads, enter your model number and get the driver. You will probably need to burn it to a CD or Flash drive to install it on your computer.
Jun 05, 2007 | Linksys Network Adapter
Linksys IP TELEPHONY - VOIP RTR W/ 2 PHONE PTS Router (RTP300-NA) Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
