Question about Toro LX466 22HP Lawn Tractor 13RT61RH244
Toro LX460 Twin cam The gas spring came off, don't kinow where it attaches.
2 Suggested Answers
vrb2
SOURCE: how to tighten belt on aToro LX460 V twin
it may have stretched and needs a new belt there is a spring tensioner that can only go so far
Posted on Aug 07, 2012
My Toro won't go in reverse on the left side.
Is the unit new? I saw a situation where Lowe's forgot to attach the steering arm. Then again, your pressure release valve (what allows for free manual movement) may be open.
Apr 01, 2015 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
What is the size of drive belt for toro riding mover lx460
Refer your inquiry directly to Toro or a local Toro dealer.
Jul 27, 2014 | Toro Garden
Drive belt runs off 42 Toro
HI, I have a Cub Cadet 50" cut I had a similar problem and I had to change the spring on the idler pulley it had lost tension and replacing it solved my problem. Not familiar with your mower but if it has the same principles as mine you might want to try that.
Jun 13, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
How to tighten belt on aToro LX460 V twin
Apr 20, 2012 | Toro LX466 22HP Lawn Tractor 13RT61RH244
My snowblower does not seem to run at full speed. Barely throws snow recently. Any adjustments I can make?
There is a spring attached to the throttle linkage. At the other end is an arm that the spring attaches to. Bend the arm so that the spring is tighter and it will throttle up higher under a load. Don't go too far or you will take a chance of blowing the engine. Best to use a rpm tester and set it to factory specs.
Feb 22, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
Toro zreo turn lawn mower... mower runs but won't go when engaged. found a large spring broken?
This spring is the tensioner for the drive belt. visit www.arcolawn.com to look up your model and get the parts shipped to you.
I recommend a hook or rope to install it.
Joe
Feb 12, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Toro Lawn Tractor won't start, engine turns
best guess , blocked main jet or water in the carby
an overhaul would be in order
Oct 24, 2017 | Toro Lawn Mower With Toro Power Tools
Mower will not start,changed plug,new gas,has fire to the plug still will not start,backfires once in a while checked the fues it is ok,it is a lx460 mod# 13AX60RH744, cleaned the points etc,
Replace the air filter. Remove the plug and try to start it. If you don’t smell the gas your problem is fuel. Most have a primer button that needs to be pressed 3 times. Remove the air filter and press the primer button to see if you squirt fuel. If it has no or little smell, continue priming and starting until you have fresh fuel. Replace the filter and plug. Disengage the pto ect ( saftys)before starting. Here is the manual Don’t forget to follow the safty startup list.
http://www.dixiesales.com/ipl/339/13ax60rg744_operators_manual_02_22_06.pdf
Aug 17, 2009 | Toro Lawn Mower With Toro Power Tools
What length is a deck belt on a toro lx460
1/2" x 90" ; Toro P/N 112-5834
Try:
http://www.tractorsupply.com/outdoor-power-equipment/mowers-attachments-accessories-parts/mower-parts/mower-belts/huskee-v-belt-1-2-x-90-in-4461290
for $19.49 if you have a Tractor Supply Company nearby.
Or:
http://www.texasmowerparts.com/catalog/products.asp?ds=DETAILED&category_id=47&group_id=184&section_id=585
# Replaces Toro 112-5834 # 1/2" X 90"
for $14.17 + $5.95 shipping
Danotex
Jul 14, 2009 | Toro Lawn Mower With Toro Power Tools
Toro LX466 22HP Lawn Tractor 13RT61RH244 Logo
210 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
