Question about Asko Dryers
Hi - I have Abrams new Asko T752 gas dryer that has magically stopped working after only 1 week! It's providing an error code of
    President:
  • 3,074 Answers
What is the error code? Tim
Posted on May 21, 2011
  • 1 more comment
  • swessel93 May 21, 2011
    H7, which means gas valve or gas blockage problem. I have disconnected, confirmed gas supply is fine, reconnected, unplugged for several hours hoping machine would reset itself. Still no heat
  • Tim Whalen May 22, 2011
    if I am not mistaken a H7 can mean a motion fault, which means that the belt is loose or worn causing the drum not to turn or to pause. Hope this helped Tim
    there is not reset button, here is the manual:
    http://www.riggsdistributing.com/pdf/ask...
Can I get a list of error messages for an ASKO TL751 clothes dryer?
I googled: Asko TL751 Electric Dryer Error code HI
You may find a manual in this search that gives you the code
If I had to guess it means the high heat is not working, or the high
temperature protection has opened to protect the dryer from
self distruction.
Your owner's manual should give the error codes.
No manual? manualslib.com may have it. YOu may want it next time anyway.
Mar 31, 2015 | Asko TL751 Electric Dryer
ASKO TL751 error messages ?
Asko dryers as model T760 or T780 indicate failure by error message (like "Overflow", "Sensor", "Thermistor", ...) while the model TL751 indicate failure by error code ("H1", "H2", ...)
Below you can see a list of error codes:
H1 error - Humidity sensor error
H2 error - Drying temperature sensor open/short error
H5 error - Heater overheated (ELECTRIC TYPE)
Heater disconnection check and H4/H6 error (ELECTRIC TYPE)
H3 Error - Flame Detector Open Defect (Gas Type)
H7 Error - Gas Valve Defect or Gas Blocked-off (Gas Type)
H8 Error - Igniter Defect or Flame Detector Short (Gas Type)
Dado
HH error code? on magic chef mcbc580dbt
I, too, have just seen (late June 2013) the "HH" code on my Magic Chef wine cooler (and it is running too cold and I can't reset the temperature). Have you found a solution since your posting of about 1 year ago?
Jun 27, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
My dryer will run, but won't heat. After about 15-20 minutes, the dryer stops and all the indicator lights (drying, cool down, etc.) flash but no error code shows. I took off the front panel and...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 11, 2011 | Frigidaire GLGQ2152ES Gas Dryer
Asko TD11 Dryer.....was working but VERY loud. This washer and dryer were purchased on craigslist. It was taking ages to dry and VERY loud. But then the START button just stopped.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 03, 2011 | Asko Dryers
My kenmore gas dryer isn't heating. we actually had a different gas dryer in the same spot that stopped drying about 2 weeks ago. It is odd, they both had the same problem. I am wondering if something...
heatman101;'';
Jun 27, 2011 | Dryers
My asko t721 dryer is one week old and i do not have a manual.it stopped in the middle of a cycle. it had 3 bath towels in it.. it starts when i push the button but will not stay on for more than a few...
Hello, welcome to FixYa.
Based on your description I`d direct you to first check the hi-temp cut out at the back...if you haven`t already.
It will look like this on the Asko dryers...
If you push this to reset and the unit works, great. I would keep an eye on it though since the hi-limit typically trips for a reason such as a excessive long vent or flex vent being used ( stay away from flex venting ) plugged lint filter, plugged vent ot partially plugged etc.
If it doesn`t run after-wards or it`s not tripped, you`ll need to investigate further...if necessary.
Keep me posted on your progress or what you find and I'll help in whatever manner I can. Good luck.
Regards,
Macmarkus :)
Jun 02, 2011 | Asko T712 Electric Dryer
My dryer quit heating up...it still works and spins but won't heat up. any help would be much appreciated!
heatman101,./'l';
Mar 19, 2011 | Asko WCAM1812 Front Load Washer / Dryer
ASKO T760 has no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 31, 2010 | Asko T761 Electric Dryer
My new Perfect Care Gas dryer stops with in a minute of running.
Check your thermo coupler (flame sensor). If it's new it should have a warranty I would think.
Apr 10, 2010 | Whirlpool WED5520SQ Gas Dryer
Dryers Logo
152 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
