Question about Kitchen Ranges
Thread bunches up under presser foot on singer sewing machine
  • ritedl May 22, 2011
    Thanks bunches for helping with the bunching
  • 10,515 Answers
TRY,
Tension assembly test.
Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn't work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out.
Do the tension test again to make sure you got everything and then try sewing again.
The bobbin should be inserted so that when you pull on the bobbin thread the bobbin turns to the left. If it turns to the right it is upside down and the thread will come out of it.
This should solve your problem unless there are scratches on your bobbin case. Check by removing the bobbin case and visually inspecting it for any groves or scratches. If you find any remove them with an emery stick and then polish it with fine steel wool.
Be sure and use a new needle when you start sewing again.
In situation like this, all you can do is adjust the tension and check for the tension spring as this is the only technical cause for bunching.
If you still find that for go a toss, i can only suggest you to show it to a tech at the nearest shop.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 21, 2011
Lever to control pressure foot will not lower foot
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever?,,.
May 23, 2015 | Sewing Machines
I NEED A FOOT FOR THIS MODEL SEWING MACHING
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever? c
May 21, 2015 | Sewing Machines
Is there a way to increase the pressure on the presser foot?
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever? bb
May 15, 2015 | Sewing Machines
Top stitch looks great, under stitch bunches. I have rethreaded, rebobbined, changed tension. same result. :(
Bunching of thread is 99% a top tension problem. Make sure you thread the top thread correctly. Thread the machine with the presser lever up. Test the tension by lowering the presser lever before threading the eye of the needle, by pulling the thread with your left hand and adjusting the tension with your right hand while slowly pulling downwards. There should be no resistance when the tension dial is on zero, and you should be able to feel more resistance when you increase the tension. Ideal tension is between 3 and 5. When your top tension is correct, your machine should operate correctly. If you feel no resistance with the presser foot down and the tension dial on 5, check the tension disks for fluff or broken thread. When you lift the presser foot, the tension disks should open and you would be able to remove any cotton or fluff. Good Luck
Aug 30, 2011 | Singer 4423 Sewing Machine
I have a singer simple and within only seconds of sewing, the bottom thread will have bunched up 10 times of the amount of thread I would have thought I even used on the bottom side of the fabric
It is in your top threading. Rethread, and with the presser foot up, pull the top thread, it should feed smoothly, now put the presser foot down, the thread should barely move. This should seat the thread in the tension discs. Good luck
Dec 10, 2010 | Singer 3116 Simple
Bobbin thread bunching upu
It is your top threading, rethread and try this test, with the presser foot up, pull top thread, now lower the presser foot and pull the thread, it should barely move. This should seat your thread in the tension discs correctly. Also, change your needle to be sure that you don't have a burr on it from other projects.
Nov 20, 2010 | SINGER 7470 Sewing Machine
The stitching is good on top, but on the bottom it bunches.
Rethread, I know that you think that you have it threaded right but it is not catching on the tension discs somewhere along the way. Do this test, with the presser foot down, pull on the the thread, it should barely move, now put the presser foot up, pull on the thread, it should feed smoothly. Now, insert a new needle if it still does not sew right. Good luck
Oct 28, 2010 | SINGER 7470 Sewing Machine
The thread bunches up underneath the fabric and then the machine stops after about 3/4 " of running. IM sure there is a simple solution, but I dont know what.
Refer to the maintenance section of your manual for cleaning the machine.
Always thread a sewing machine with the presser foot up.
Check the needle to be sure the flat side of the needle shaft faces the back of the machine.
Check the bobbin to be sure the thread is feeding in the correct direction and though the proper guides.
Using the handwheel, lower the threaded needle, holding onto the the end of the thread and then raise to pull up the bobbin thread.
Take both threads under the presser foot and to the back of the sewing machine.
Place the fabric under the presser foot and while holding onto both threads, lower the needle into the fabric by turning the handwheel by hand and create one stitch.
Let go of the threads and press on the power pedal.
If this does not resolve the issue, the machine may need the timing adjusted and this needs to be done in a shop by an authorized Singer tech.
If the machine is new, the warranty may cover the adjustment.
Apr 02, 2010 | Singer 2250 Tradition
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
