Question about HP LaserJet 1022 Printer
Hp laserjet 1022 not printing
No changes no new cartridge it was working an hour ago and now nothing.
  • Anonymous May 19, 2009
    printer will not print after performing a hard reset and obtaining an IP address.
    Genius:
  • 1,847 Answers
Try reinstall the printer.
do a hard reset and then reset the printer from menu.
reinstall the ink tanks.
Posted on Aug 15, 2008
HP Laserjet 1022 orange light keeps flashing
1. Check any paper jams in side.
2. Check cartridge.
3. Remove back cover, clean paper sensors.
4. Replace Formatter board.
Jan 05, 2013 | HP LaserJet 1022 Printer
I ran my HP Laserjet 1022 out of toner and when I insalled a new cartridge It never loaded the toner and does not print.
slap it from back side of printer your problem will be resolved if it persists then check the cairtage holder for broken if it is so then replace the older your problem will be resolved .
Jul 18, 2011 | HP LaserJet 1022 Printer
My boss want to replace the black ink cartridge for one that prints color. Can this be done with the HP 12-a cartridges? HP Laser jet 1022
Unfortunately laser printers don't work this way. The laserjet 1022 was designed for black and white prints only. In order to do color printing with a laser printer you will need to purchase one that is designed to print in color. The laser printers work a bit differently than the inkjets - the laser printers have 4 toner cartridges, one each for Cyan, Magenta, Yellow, and Black, that work together to print a full color page. With the old inkjets you could just replace a black cartridge with a color one.
So, short answer: Sorry but no you can't make a laserjet 1022 print in color. :)
I would recommend looking at an entry level color laser printer from hp, such as the CP2025 (http://h10010.www1.hp.com/wwpc/us/en/sm/WF25a/18972-18972-3328060-15077-236268-3673580.html) if you are looking into purchasing a color laserjet.
Hope this helps
Please rate this post, thanks!
Mar 09, 2011 | HP 645A Magenta Toner Cartridge (C9733A)...
Triagle light blinks on HP Laserjet 1022
If only the triangle light blinks then is because one of the following reasons:
1.The print cartridge door is open.
2.The printer is out of paper.
3.The print cartridge is installed incorrectly. Try opening the door, removing the cartridge and installing it again. It should snap into place.
4.There is a paper jam. Remove the cartridge and check if there is a paper jam.
Feb 06, 2010 | HP LaserJet 1022 Printer
Laserjet sends out a blank page, even after I put in a new ink cartridge.
It is possible that you have the wrong driver installed. You may try removing the printer and reinstalling it using the driver on the disk that came with the device.
Also, if you have recently replaced the toner cartridge verify that you removed the protective tape that is supposed to be removed before placing the toner cartridge in the machine.
Finally, if you are using Vista or an operating system other than Windows XP, you should check HP's website to determine if there is updated software for your operating system.
Hope this helps - flub
May 29, 2009 | HP LaserJet 1022 Printer
HP LaserJet 1022 changes the output order for checks, statements, invoices. Worked fine until 4-5 months ago (we switched over to a citrix server). Have tried reinstalling to citrix and local hard driver...
It sounds like a computer software issue. However to overcome the problem through the printer you can try this.
When the screen pop up comes up for printer selection, highlight the printer you will be using, then goto "Preferences". At the top tab click on "Advanced". Go to the bottom of the menu for "Layout Options" and change "Page Order". This should solve your problem, though you may have to change it back to print regularly printed materials.
May 18, 2009 | HP LaserJet 1022 Printer
HP Laserjet 1022 printer
there could be two reasons. The transfer roller is off place or the fuser has given up.
Sep 24, 2008 | HP LaserJet 1022 Printer
HP Laserjet 1022
Try to clear dust from cylinders..
I had similar problem and I cleared dust from cylinders with ear sticks and destilled water.
good luck :))
Aug 12, 2008 | HP LaserJet 1022 Printer
HP LaserJet 1022 Printing Blank Pages
Aug 08, 2008 | HP LaserJet 1022 Printer
HP LaserJet 1022 Printer Logo
986 people viewed this question
Ben Johnson
