Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
F3 error. Beeping wont stop. - Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
  • 794 Answers
Hi miketack,
If your Dacor is getting an F3 error code and wont stop beeping this is because of shorted oven temperature sensor or RTD. You can fix this by checking sensor harness and harness connection between oven sensor and oven control. In case that wiring is ok you need to replace oven temperature sensor (RTD). You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Thank you for using FixYa.
Posted on Jun 06, 2011
What does error code F3 mean?
not sure but here is the tech service manual GE JB960 Technical Service Manual
Feb 19, 2015 | GE Kitchen Ranges
E 2 and F3 error, beeping
What is the model number?
Apr 11, 2014 | Roper Kitchen Ranges
F3 - error code, wont stop beeping at us.
Hi luvashley28,
F3 error code means that there's an open or shorted oven temperature sensor (RTD). To resolve this you have to Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Feb 10, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool electric range timer constantly beeps and displays E2-F3 I don't even use the oven I just want beeping to stop I press STOP which changes display back to clock, but soon it returns to E2-F3...
Hi
Thanks for using FixYa.
Error F3-E2 in your Whirlpool oven means oven too hot and to resolve this issue you'll have to replace the oven temp. sensor (probe). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 06, 2010 | Whirlpool GS475LEKS Gas Kitchen Range
I tried cleaning the oven and got the error F3.
Electronic control has detected a fault condition. Push CANCEL pad to clear the
display and stop the display from beeping. Reprogram the oven. If a fault reoccurs,
record the fault number.
Jul 13, 2009 | Electrolux Kitchen Ranges
F3 error
So far so good we unplugged the machine took the filters off the bottom let everything dry out over night and it seems to be working I'll update you tomorrow. I think the steam got the control pannel wet.
Jun 24, 2009 | GE Advantium 120 Convection/Microwave Oven
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Spacemaker beeping loud and f3 message driving us crazy
The error code F3 indicates an oven sensor problem. The oven sensor is most likely the failed part. The oven sensor probe must have the correct resistance readings at specific temperatures. When the electronic range control (ERC) cannot identify the correct resistance of the oven sensor or the resistance is way out of specs F3 will display.
I recommend calling a service technician to diagnose and repair your oven.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Have a ge spacemaker xl1800 - f3 error
I had the same problem. I removed the grill and opened the control panel as I read an answer from "GENE" on APP (Appliance Pros) that this indicated a short in the circuit board (TouchPad). I was going to replace the faulty circuit board but when I opened the control panel there it was......One wire harness had just came unplugged!! I plugged it in, reassembled and the microwave works again!
Mike
Tampa, FL
Jan 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Error msg F3
Nolka, F3 has to do with the oven temperature probe out of spec. You need to change it out. Part number 316217001. Easy fix. Catriver..post back.
Oct 19, 2006 | Frigidaire FGF366E Gas Kitchen Range
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
352 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
240cpa
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
