Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Wheni put a cd in the machine makes 6 bibs and then says it cannot read the disk, but just the other night i was watching it.i did hold the unit up vertically for3 minutes but nothing else.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 70 Answers
Try Cleaning The Disk or take it to ur nearist Video Rental Shop
Posted on May 21, 2011
Suzuki areio cd player
Error #6 is the disk can not be read because it is upside down. If you are getting this error and the disk is in fact right side up you have other problems with the unit such as the Read Write Head is dirty or damaged. Possible that something got in there inserting and removing a disk. You have to remember the small size of the working components here does not require much to muck up the whole system. If this happens with all the disks you try make sure they are clean and devoid of surface damage as scratches will make it impossible to read. Remember this is an optical drive so Fingerprints and Scratches are not part of the language these things read. If it is just the same disk, get a different one. As I've had happen to me that code ended up being a trip to buy a new unit on sale with free installation as it died. But that is what the code means.
Mar 27, 2014 | 2002 Suzuki Aerio
I feel like a dummy buy it says 6 cd player in my new to me 2003 explorer eddie bouer edition. Where is the place to put the cd's?
Check the manual for the exact loading procedure; the unit in the dash holds all 6. I think you have to press a button on the player until the display indicates "LOAD" and then put the CDs in one at a time. If you are putting in less than 6, you have to press the button again so the display no langer reads "LOAD". The manual will give you an exact explanation but the radio unit itself is what holds the CDs.
Jun 26, 2011 | 2003 Ford Expedition
Use the cdn22 on weekends for 6 hours a night. at least twice a nightone of the cd players said no disc when i put one in. its not always the same side that does it. the only way to correct it is to power...
Check for contamination on the disks that won't load. Also if you have things like cigarette smoke or "fog" machine that can cause the problem. The precision of the head of the CD players is amazing as the tracks are millionths of an inch apart and it doesn''t take much to cause a problem. If trying to load again the disk finally works, then it may not be registering on the hub quite right. Care in centering MAY help.
Mar 14, 2011 | Numark Industries Numark CDN 22 Mk4 Double...
I had to restore my emachine to factory settings
Open "My Computer".
Insert a "data" CD, and hold the LEFT-SHIFT key down for a minute.
Watch the icon for the CD-drive change from the "standard" icon to something specific to the data CD.
Right-mouse-click on the CD's icon, and choose "Explore",
to open Windows Explorer to view the "data" files on the CD-disk.
Dec 11, 2009 | E-Machines emachines (emachinees) CD-ROM...
When you put a cd in, it asks you to put in a playstation cd. Is it not reading the cd? It also sounds like the cd is making a clicking sound.
Hi!
Ok, sounds to me like you may have one of the following problems (none of are going to sound very good):
  1. The motor that spins the CD has burnt out/become faulty.
    (Does it sound like the disk is spinning inside the machine?)
    Solution: Return to Sony if it's under warranty..otherwise, look for spare parts on somewhere like ebay. Unfortunately, it may work out easier to replace your PS1. Secondhand ones go pretty cheap online or somewhere like EBGames.
  2. One of the bearings that holds the disk in place has become loose or fallen out.
    (This is the part of the machine that holds the disk in place when spinning the disk. You should have 3 little silver bearings around the outer edge of small circle you click the disk onto. Also check the bottom of your CD..if it has scratches that go all the way around the disk in a circular motion, it may indicate the CD is not sitting in the cradle properly)
    Solution: Same as above. Spare parts online, new machine or steal the part from one of your mates :)
  3. The lazer has died
    (Though this wouldn't really explain the clicking noise. but it would explain the disks not being read)
    Solution: Replace the lazer (which is really cheap to do if you how to install it) or replace your PS1
  4. The disk is scratched & cannot be read by the machine
    Solution: Buy a CD/DVD repair kit & see if you can buff out the scratches. There are a lot of places now that have specialized equipment for doing this now such as video stores, 2nd hand stores etc..they may do it for a small fee.
Sorry there's no real positive ideas for you there..hope this helps point you in the right direction.
Nov 20, 2009 | Sony PSone Console
2005 s40 cd(holds 6) player stuck - reads deck error?
that is one of worse nightmare when you have a magazine loader in the systems when the cd get stuck. its common to all cd player some has better luck than others, Only thing I recommend is to take it to your local stereo shop or do it your self taking the unit apart and remove the cd. Keep in mind, when having magazine loader, some of the older unit will not read the new format or burn disk and it will read no disk or error and the cd will get lock. if the unit cant read the cd, majority of the time its does recognize there is a cd in unit. try tuning on and off couple of time and keep pressing eject button. you may have to do it 8-10 times to see if that will release the stuck cd.
Aug 27, 2009 | Car Audio & Video
My ps3 will not read my game nor dvd
Hi my name is Juan and the problem you got is with the bluray laser lens they have stoped reading games you can check this out put a cd on your ps3 and at the same time place your ear on top cover and will heard 3 cliking noises of the laser but make no noise because this cliking noise is so fine that you need to make no noise i goes clik clik clik you will hear it but make sure you put your ear on top cover at the same time you insert the disk it takes about 3 -4 seconds for the cliking noise after you have inserd the cd some lasers they do try to read and they make the disk to spin off and on some they do make the disk to spin normally but nothing happend and the solution is to replace the laser lens I am a ebay thrusted power seller and I can get you one if you want to
Mar 15, 2009 | Sony Playstation 3 (PS3) Console
Home Theater problem
It seems like u have a dirty optical pickup ( which means the laser head ) which is used to read data from the cd. Most of the time it's dirt and if u did not cleaned it with a lens cleaner weekly, u a re going to take it apart once u get "no disc" error.
If u are upto it I can guide u, but i doubt it. Most of the time the laser unit can be accessed easily by taking the cover and cleaned with just a cotton bud with a light touch on the focus lens.
Still u need to be familier with it, if are going to take it apart.
And yes all it might need is cleaning, and the service guy cud overcharge u by saying he replaced the optical unit....so and so.. hehe
If u have a camera take a pic and sent it to me or we can chat, if u are like to do it urself
Cheers
Rifaa
Nov 08, 2008 | Dual DWM-3900 System
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
43 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
