Washer will not drain before going into spin cycle. the lid switch is clicking, so am assuming it is working. have checked the drain pipe from back of washer to drain in wall. i have emptied washer. roper washer rax423pq0 or rax423pqo. serial cr 5071118.
  • 112 Answers
SOURCE: roper rax4232pqo wont spin
Still replace the lid switch. Most have multiple contacts.
Posted on Nov 08, 2008
SOURCE: err02 shown during spin cycle on 1400 haier washing machine
WHEN I INVESTIGATED FURTHER I FOUND THE DRAIN TUBE FROM MACHINE WAS BLOCKED BY SOLID SOAP LUMP BUILT UP AT THE MACHINE END -AMAZING .
Posted on Apr 10, 2009
jsrock516
  • 5911 Answers
SOURCE: ROPER MODEL RAX7245JQ0 WILL FILL AGITATO, DRAIN
Most of these spin related problems are attributed to a lid switch malfunction. A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Let me know if you have any questions. I hope this helps you.
Posted on Jun 30, 2009
  • 126 Answers
SOURCE: Roper washer will not spin or drain-
you may have something stuck in your pump, preventing it from draining. The washer will not spin until it does drain. You'll have to empty the tub (you can do this with gravity by taking the drain hose and putting it down near the floor in a bucket). You will have to take the cabinet off, then take the hoses off the pump. Have some towels ready! Look inside the pump and hoses for an obstruction. If the fins inside the pump are damaged, you will have to replace it. If there is no obstruction here, look down inside the hose drain. Run a coat hanger down if neccessary to see if theres a blockage. The pump could be dead, too.
You could have a dead spot on the timer, but this is doubtful.
Posted on Nov 24, 2009
jsrock516
  • 5911 Answers
SOURCE: My roper whirlpool washer won't spin or drain. the
Yes, a broken lid switch can cause the washer not to drain. The pumps on these washers are strictly mechanical. They have no electrical connections and only have one moving part - the impeller. If the pump were clogged, it would not drain, but if the drain line is clear, the problem is the lid switch. Since you mentioned your switch was broken, I would begin there. Congrats. You've pretty much already diagnosed your problem.
The most common cause of the problem you are experiencing is a lid switch malfunction. Symptoms may include, filling and stopping on the intial fill cycle, a wash tub that will not drain, and stopping right after the wash cycle and not advancing to rinse or spin cycles.
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
A replacement lid switch (if required) can be purchased at any of the following web sites:
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare.
If you have questions, or need additional assistance, please post back with your MODEL NUMBER and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
NOTE: A simple test to determine if the pump is clogged is to use a wet/dry shop to pull a vacuum on the drain line at the standpipe. If the water drains freely, it is not clogged. You can also use simple gravity by removing the drain line from the standpipe at the wall and laying it on the floor. The water will pour out if the pump and lines are clear. This second procedure is messy and I would not recommend it if you have your washer in an indoor laundry room. You can, however, try to use the gravity method by catching the water in a bucket.
Posted on May 15, 2010
Kenmore washer top load not cycling
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
You can also go to the following Sears site and click on "Manuals", enter the stock number, select "residential Washers" and click on the actual model number.
If it neither drains nor spins, the first thing to check is the Lid Switch. This prevents the machine from draining and spinning if the lid is open.
I assume that you cannot hear the motor trying to turn.
See the following for how to access the console and Lid Switch connection.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=6f8112b458c05fcc8f6d1a4139b9a723
Following is a Whirlpool installation and maintenance PDF on top load, direct drive washers. It has a description of how to by-pass the switch.
It also has a troubleshooting guide.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
To bypass the switch, you only have to disconnect the power to the washer, remove the two plastic clips from the console, remove the two screws under the clips, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires that you release the console and pull the cabinet.
Aug 01, 2010 | Kenmore Washing Machines
Have the Indesit Moon washing machine and it will not finnish the wash cycle and go into spin mode. Is there anything I can do? Thanks
A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced.
Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power.
Please donot forget to rate and accept my answer...
Apr 14, 2010 | Indesit W 123 Front Load Washer
Washer wont go into spin mode or discharge the water
Check the lid switch or lid striker that operates the switch. lift the top lid and insert a pen or similar into the hole on the right hand side to operate the switch when in spin mode.
If not try shorting the switch temporary, the top part of the washer needs to be hinged back to gain access, to do this insert a flat blade 4" from each side at the seam with the front panel to release the clips, lid will now hinge back to give access to the internals, Isolate the supply and locate the lid switch on the underside of the top panel and remove the 2 wires and short out/ link together. test the spin cycle now should now work and also drain the machine (Draining only works when washer is spinning) If all ok obtain and install a new switch do not leave the switch shorted.
Note this switch only affects the spin and draining parts of the cycle.
Good luck
Jan 02, 2010 | Admiral AW22 Top Load Washer
Spin cycleis out, doesnt even hum....
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
If it works, the Lid Switch is a relatively inexpensive part.
Oct 02, 2009 | Kenmore 15864/15862 Top Load Washer
Model 110.27802690 stopped after rinse, still full, won't respond. Checked power source, won't work in any switch position
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.27802690
I'm assuming from your problem that the washer went through its' first wash cycle, drained and spun, then filled again for the rinse cycle, went through the rinse and didn't go to the drain / spin cycle.
If that is correct, it appears that the motor, pump and transmission are working. It also appears that the Lid Switch is working. These are the main places to look for a problem such as yours.
If you stop the washer by pushing the control knob in, moving it to the spin cycle and starting it again, and the washer still doesn't spin, the problem points to a defective timer.
Before replacing the timer, I'd check the Lid Switch again by removing the two Trim End Caps and the two screws under them. Tilt the console back and disconnect the connector from the console to the lid switch.
Using a short insulated wire, jumper the Lid Switch at the console by jumping between the two outer pins.
Following is the Whirlpool Installation and Maintenance manual for these machines with a section on how to jumper the switch.
Then try to start the machine in the spin mode.
If it works, the problem is in the Lid Switch.
If not, It is likely in the timer.
Sep 30, 2009 | Kenmore Washing Machines
Washer won't drain or spin
sounds as if you have a lid lick/door switch issue, the machine is not recognizing the door being closed and for safety reasons will not enter spin/drain.. open anc\d close lid a few times slowly, cam you hear a "clicking noise" whe njust about closed?? id assume not replace teh lidswitch
Jan 21, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Washer will not pass wash cycle...Will not Drain
Nightshade, in most cases, no spin, no drain is a lid switch problem. If you advance the timer to the spin position does it spin? If the machine is agitating you can rule out the coupler. If you are sure that it is not a lid switch problem, then you are probably looking at a bad timer....Catriver..post back.
Nov 08, 2006 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
