Front tires tread bold & start weagle in freeway fast
    Brigadier General:
  • 10,406 Answers
You have "bold" tires? Do you mean "bald" tires?
If so, then replace the tires.
You have "weagle" at fast speeds on the freeway? Do you mean "wobble" or "wiggle" ?
If so, then take your vehicle into the shop, for a front-end alignment, and a safety inspection,
in the possibility that some of the steering mechanism is loose or broken or misaligned.
Posted on May 21, 2011
I replaced the tires on my 2003 mitsubishi eclipse 2 months ago & the front two have worn to the wires on both sides. a week ago there was still some tread on them. why could this be happening?
1. What brand and model of tire was fitted?
2. Please describe the wear pattern on the front tires in more detail. For example is the excessive tread wear.....
A. Right across the face of the tread on each tire or
B. On the outside edges of the tread on each tire or
C. on the inside edges of the tread on each tire or
D. on both sides of the tread but not on the center section of the tread on both tires.
B is normally caused by incorrect toe setting - toe in
C is also normally caused by incorrect toe setting - toe out
D is normally caused by tire pressure set way too low.
Faulty steering and suspension components can also cause abnormal tire wear for any component that affects the wheel alignment settings.
If you can provide a better description of the tire wear on each front tire you will get a better answer.
Dec 28, 2015 | 2003 Mitsubishi Eclipse GS
I'm trying to see why does my 02 nissan pathfinder
sounds like tire unbalance or perhaps you have tread separation on the inside of the tire and its causes dynamic imbalance at higher speeds.
Sep 22, 2014 | 2002 Nissan Pathfinder
I have a '64 Valiant, 225 slant 6, no power steering. When I'm on the freeway it's difficult to stay in a lane, like driving on ice. Air pressure is balanced. Any ideas ?
When you have front end problems like that it helps to underinflate the tires a little, so instead of the 32-35psi, try 28.
Note this is not a fix, just a band-aide to get you by untill you fix the problem.
These old Chryslers are great cars, but they do have front end issues. The front steering/suspension is pretty precise and way ahead of its time. When the parts wear out, watch out.
Inspect steering box, the play can be adjusted. Check tire rod ends, wheel bearings, control arm bushing, ball joints, pitman & idler arm.
Then have the alignment checked. Be sure your front tires match each other in size, brand, & tread. Be sure to run radials, bias-plys are known for their drifting.
The steering box play adjustment can be found at the following forum:
Slant Six Forum
Jul 15, 2014 | 1972 Plymouth Valiant
Uneven tire wear on passenger side--front & back. Inner tread worn more than outer.
you'll need an alignment to determine if their is any parts failure
Sep 17, 2012 | 2011 Hyundai Equus
I have a 91 front wheel drive toyota corolla & I was going down the road and it cut off then fired right back up but was shaking i changed the right side axle but it still does the same. at 30 mph it...
Tires out of balance? Start with the simple things before changing stuff like axle shafts. Take the car to a tire shop and make sure the tires are balanced and the rims aren't bent, as either one of these can cause a rough ride
May 31, 2011 | Toyota Corolla Cars & Trucks
How should I rotate my tires? I've had people say front to back, side to side? front to front, back to back?
It really depends on the tires. Some tires have a one-way tread pattern and are only supposed to rotate in one direction (i.e. ones that pull water away from the center of the tire). In this case, you must rotate driver-rear to driver-front and passenger-rear to passenger-front. If you have a symmetrical tread pattern, you should rotate driver-rear to passenger-front and passenger-rear to driver front.
If you post a picture of the tread pattern, I can tell you which you should do.
Zach
Feb 28, 2011 | 2004 Volvo V70
My 2004 sierra denali vibrates or feels like I'm running over the lane change bumps on the freeway. What could it be? The rear end, the transfercase, or the drive line?
Most likely a bad wheel bearing assembly, Jack up each wheel individualy starting at right front (passenger) under lower control arm, just enough to get tire of the ground. With tire still on place hands on outside of tire at 3 oclock & 9 oclock & try to move in & out, push & pull. If there is play it will need to be replaced. Check all 4 wheels this way.
Nov 01, 2010 | 2004 GMC Sierra Denali
I bought 4 tires at the same time, just had them rotated and was told that the front tires have more traction on them now than the back and that they shouldn't of rotated them. On a 2001 Chevy Cavalier...
You want the tires with deeper tread on the front of the car. As you drive, being front wheel drive the front tires do all the work, the rears are just along for the ride so the drive tires will wear down twice as fast. About ever 6000 - 8000 miles, you will need to rotate the tires to keep all 4 wearing evenly
Oct 16, 2010 | 2001 Chevrolet Cavalier
2004 F-I50 WEARING THE INSIDE OF FRONT TIRES. i noticed and rotated my tires,not the front are doing the same thing but not as fast.
by inside of the tire do you mean inside of tread? If so this is an alignment problem, either toe-in or camber; if you mean sidewall- the tires are rubbing on suspension or fender well and need to be a smaller size or off-set of wheels needs to be corrected ( I don't recomend wheel spacers)... get back to me if this doesn't help you...
Oct 02, 2010 | 2004 Ford F150
Computers & Internet Logo
David Payne
David Payne
