It won't install. always says won't work on windows xp.
    Sergeant:
    Champion:
  • 218 Answers
What wont install?, and what version?
Posted on May 21, 2011
Toshiba laptop windows XP has a registry file failure! My home screen won't come up can't get f10 to work safe mode don't work what can I do
Try this fix from the Microsoft WEB site.
http://support.microsoft.com/kb/307545
If it does not work then -
The quickest and easiest fix is to re-install Windows XP, the laptop's device drivers and your programs.
Dec 11, 2012 | Computers & Internet
This Day in History from History.com won't Load
if you have another player installed it may be conflicting..deactivate.reboot...it and try it ..if that doesn't work delete the download and re install..always reboot
Dec 10, 2012 | Microsoft Windows XP Professional Full...
Cannot install MGI PhotoSuite4 on a computer running Windows 7 OS
The PhotoSuite 4 program is very old and won't work under Windows 7. http://sonic.net/mnitepub/pccafe/reviews/photosuite4/photosuite4.html says that the version 4 Platinum edition ran under Win95-Win2000 versions of the Windows OS. Thus even the compatibility mode probably won't help under Windows 7 32-bit. You can try it though by right clicking on the installer and then selecting Properties. In the Compatibility Mode tab, select Always Run this program in the compatibility mode and an older version of Windows. Then right click again and choose Run as Administrator. (You may have to do this again on the program itself.) Since Win7 64-bit requires signed drivers or programs, it is not as likely to work. (Check your version of Windows 7 by clicking Start > Control Panel > System and Security > System. If the title of your OS ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit OS.)
If you have Windows 7 Pro or Ultimate (or upgrade to one of those versions), you can run a virtual version of XP for free. Download and install Microsoft's Virtual PC and then XP mode (in order). This works best if your CPU supports virtualization and you enable the feature in your computer's BIOS. (There are work-arounds for computers without virtualization. See the MS support pages.) Install your PhotoSuite inside the virtual XP program in that case.This old software may run in that case. (However, I've had some Win2K software that ran under XP with the compatibility mode but didn't run under the virtual XP. Note: virtual computers do have some additional limitations. They do not talk to the host hard drive and other hardware directly. (You can install a printer on the host machine or the virtual machine but not both.) You'll need to save files on external media (flash drive, optical disc or other hard drive) to transfer them between the machines).
Another option is to run an older version of Windows on another computer, as a dual boot computer or with Virtual PC (or another virtual computer package - VMWare or Parallels). In that case, you need a licensed version of the older Windows OS. Again install the program while running the older OS.
The final option is to upgrade to a Windows 7 compatible Photo editor and organizer. (Even the Microsoft Windows Live Photo Gallery has some of the features of Photosuite SE.)
I hope this helps.
Mar 24, 2012 | MGI Software PhotoSuite SE V4.0
I can't install win xp pro. on my G41MT-S2P..i always get "a disk error has occured" prompt
This model motherboard does not use IDE/PATA hard drives.
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive. http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Sep 08, 2011 | Gigabyte Giga Byte Technology Ultra...
System won't recognize downloaded driver, I have installed an update provided on HP's site, but it still won't work. trying to install on a windows 7 computer. had installed it earlier on a...
When downloading a printer driver from HP you will need to ensure that you are selecting the correct OS (eg. Windows 7) and the appropriate version (eg. 64 or 32 bit operating system). These drivers are different and using one on the other will not work.
Windows XP drivers also will not work properly in a Windows 7 environment and the majority of Windows XP drivers are 32-Bit.
Sep 06, 2011 | Office Equipment & Supplies
I purchased Egames Lexicon. When I try to install it a message appears that says it cannot start or run due to incompatibility with 64-bit version of Windows. How can I get this software to work on my...
Right click on the executable file that starts the setup, typically setup.exe. Select Properties. Under Compatibility, set it to Windows XP SP3. If that doesn't work, it really won't work without you setting up a virtual machine and installing a copy of XP. If you're running Windows 7, you can download a Windows XP virtual machine to run. It's called XP Mode. Instructions can be found by searching for XP Mode in the Start menu's Help and Support.
Jul 06, 2011 | E-Games Lexicon Word Challenge for Windows
I just bought Intel ATOM D425 MB. I installed winxp. Everything ok. But Network drivers not installed. In device manager it shows as unknown device. I searched the Intel site.They dont also have the LAN...
OF COURSE there are no Windows XP networking drivers for this Intel motherboard. WinXP was released in 2001; this motherboard wasn't even DESIGNED until XP had already been replaced by Windows Vista and Windows 7. Why would Intel ever bother to make drivers for an OLD operating system for NEW hardware?
You bought NEW hardware; you need a NEW operating system to make it work. If you want to use XP, you won't be able to do any networking with this system. If you want to be able to network this system, you'll need to buy a modern operating system for the modern hardware.
I know this isn't the answer you want to hear, but you also won't find Microsoft writing a NEW operating system to work with my OLD AMD 386DX-40 motherboard. Of course, you can always complain to Intel and Microsoft, but that won't change the reality. You have NEW hardware, which is great, but NO ONE is going to design and write NEW drivers for an OLD operating system to work with your new system.
Apr 27, 2011 | Intel D425KT Innovation Series Motherboard...
R193564 driver is not working..
I am glad to HELP YOU!
The driver you are talking about is a WLAN driver [wireless] for Windows XP. It was built to recognize and to be installed UNDER WINDOWS XP ONLY!
So:
1. if you are trying to install it under a different operating system [Vista or Windows 7] won't work;
2. if you have a machine running Windows XP and the driver itself is corrupted you can get it from HERE.
GOOD LUCK!
! Windows Tips
Apr 25, 2011 | Computers & Internet
I have this laptop but don't have the orignal CD's and also replaced the laptop. I can't seem to install XP back on there using a XP CD. It keeps asking for the Rescue CD's that came with the laptop. ...
If you have the COA sticker on the bottom of your laptop, you can pretty much use any disc with the same OS as the sticker (XP Home won't work for XP Pro and vice-versa), the discs you can use several times to install, but the COA is what you're really paying for.
I don't advise ths next suggestion unless you have a pretty good idea of what you're doing, but you could always download an OS from a torrent site such as isohunt.com or thepiratebay.org. Not the most legal way of doing it, it's really pretty dark grey area, but it is pretty effective
Nov 08, 2010 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Sybase Powerdesigner 9.5 Windows 7
PowerDesigner 9.5 wil load on Windows 7 but it won't run. I was able to get it to run by installing it in the virtual XP environment on Windws 7.
For this to work,
Must be running Windows 7 Professional or better, and
Your machine has to allow virtual machines (BIOS Setting).
You will need to download 'XP Mode' and indows Virtual PC' from Microsoft.
http://windows.microsoft.com/en-US/windows7/install-and-use-windows-xp-mode-in-windows-7
You will be able to run PowerDesigner 9.5 and oter applications that will not run in the Windows 7 environment but ran previously in the XP environment.
Mar 15, 2010 | Sybase Powerdesigner 9.5 (20330-01-0950)
Computers & Internet Logo
David Payne
David Payne
