Question about HP Office Equipment & Supplies
Hello, i have a photosmart all in one  printer C6280 with serial no my7au226zw & i have this working perfectly well on my xp desktop, i now have a laptop vista premien & i have loaded  the softwhere onto it but im haveing all sorts of problams everything is o.k except the create progam it is not displaying it at all could you tell me why this is i have put the disk in taken it out & reinstalled but it's not showing up at all & it's the reason i bought the printer i hope you can help me celia
Hi there, i have fixed the problam not atfter a lot of trouble i ended up takeing the laptop to a IT comoputer guy who wiped off the whole of the vista progam & reinstalling it & thanks to him i now have it up & running as there is no way ave fixed it, i will see how it goes now if i have anymore problams i will sure to get in touch with you
celia foster
Posted on Aug 16, 2008
Can not (re)install HP Solution Center in windows 7 (photosmart c6280)
check leads and connection points
once connected windows 7 should automatically detect your printer search for and install the drivers
click start control panel devices and printers if you see your printer right click on it
you might have to set it as your default printer
click start right click on computer device manager scrollto ports com & lpt
if you see a yellow question/exclamation mark ? ! or a red X a new driver will need to be installed
hope this helps
Dec 12, 2011 | HP Photosmart C6280 Printer
My HP Photosmart C6280 All in One will not scan or copy.....it comes back as unable to scan or copy. I have reinstalled the full feature software
Its not software issue,for copying you need not required any software just plug in power & take copy, if copy is not happening, its definitely printer faulty only..
Open flat bed, check scan head,mechanism & cable,if found any breakage in mechanism,scan head or cable, replace it & check..If its difficulty for you submit unit in service center..
Dec 06, 2011 | Office Equipment & Supplies
I have aHP Photosmart C6280 All-in-One Printer. Scanner.Copier. and my Computer fails to recognise the C6280. Iwould like to download the driver for thismodel of printer.
I understand your printer problem, if you are using XP, then please check to see if there are other printers on your computer that you may longer have. Go to your control panel and then click on printers. Delete any printers you no longer have.
Then go to add and remove programs and uninstall any programs associated with your HP printer.
Turn off your printer and unplug your printer from the computer.
Please go to the HP website by copying and pasting the below link into your web browser.
Select XP or other operating system, Vista or Windows 7 and download the driver / programs for your model printer, save to your desktop. Install program and about half way through the program will ask for you to plug in your printer and turn the power on. Follow the prompts.
If the installation advises that it cannot detect your printer, try another USB cable or port.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=3194498&
Sep 06, 2011 | Office Equipment & Supplies
I am on my husbands computer, however, here is my problem. I had Vista Windows on my computer. It crashed and Windows 7 was installed. Now it will not let me install my printer. I have a HP Photosmart...
Go to HP's website (hp.com), click on Support & Drivers, do a search for "Photosmart C6280", click on "Photosmart C6280", download the drivers and software for Windows 7 (you'll need to know whether you've got the 32 or 64 bit version), then follow the install instructions.
Aug 04, 2011 | HP Photosmart C6280 Printer
I keept getting photosmart ink system failure code 0xc18a0101 I have tried turning the printer off and even uninstalling and restalling the printer and it keeps giving me the same error code I have a...
Hello;
Try Resetting the printer
* Switch off the device
* Unplug the Power cable of the device and the usb device of the printer
* Wait 30 seconds
* Plug the power cord and usb back
* Try test print
If not solved try servicing your device
Nov 03, 2010 | HP Photosmart C6280 Printer
HP Photosmart C6280 not visible as printeroption though installed
this will usually happen if you're disconnecting the USB cable from the computer and putting it back on a different USB ports. try to connect it to where it was working before. this is also true for other USB devices such as scanners and webcams
Mar 13, 2010 | HP Photosmart C6280 Printer
Is photosmart c6280 fully twain compatible?
Yes the Photosmart c6280 is compatible with TWAIN. HP AIO inkjets printers they depend on TWAIN for scanning feature to work.
Regards,
Riztech.
Mar 05, 2010 | HP Photosmart C6280 Printer
Our HP Photosmart C6280 All in One printer is giving me the Ink System Failure message, I have unplugged everything & taken out the ink cartridges & put them back in, same message...HELP!
Check out our web site at: www.ccl-la.com Click on the printer repair link, we have a section under HP that gives a step by step guide to fix your printer. The problem is caused by air in the ink feed tubes and the guide shows you how to purge the lines. You should be back printing in less than 10 minutes.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Sep 25, 2009 | HP Photosmart C6280 Printer
50 people viewed this question
Ben Johnson
