Question about BOSS AUDIO SYSTEMS BV9978B Car Video Player
Good afternoon, during a robbery pulled my player screen BV9978B Boss, I need the flex that transmits the data to the screen because it broke
  • 3,018 Answers
  • Due to the nature of this item it is not something readily available. I recommend contacting Boss Audio Systems directly here http://www.bossaudio.com/support/index.php so that you get the correct cable as that is a pricey deck to to take a chance on a second rate after market cord on.
Regards, Tony
Posted on May 21, 2011
Buenas tengo problemas con mi radio Boss numero de serie BV9978B no reconoce memorias microSD ni dispositivos USB que podira ser gracias...
tengo una radio boss con dvd , el problema es que le pongo una pelicula y solo me lee la introduccion y se congela la imagen
Sep 05, 2011 | BOSS AUDIO SYSTEMS BV9978B Car Video...
Screen display cutting out when u move or ben the screen on its hinges
There is a "ribbon" cable between the base (holding the motherboard) and the frame (holding the LCD screen) that transmits the data signals. Obviously, that cable is either partially disconnected, or it is damaged, and "flexing" the laptop triggers the problem.
Take the laptop to a professionial technician, for trouble-shooting and repair.
May 20, 2011 | Computers & Internet
Cheats
Gain Complete Achievement
  • A golden level sign is a badge of honor showing the player they have completed an in-game level to the highest completion standard. It is a graphic that sits above the level select graphic. To have the golden level complete sign hang over every game level, players must collect every available item and rescue every prisoner in the level during one play through. A good tip is to use the x-ray scan card to more easily find all the prisoners and collectibles.
  • All Boss Cards
  • The way to achieve a boss card is to destroy the boss the player is fighting as quickly as possible. If the player defeats the boss quickly, a onscreen message will pop up informing the player they succeeded in getting a boss card for that boss.
    The best way to do this is to make sure the in-game character is equipped with lots of grenades and a special weapon. On the fourth boss, use the flame shot. Try to use the Metal Slug if applicable. Players can use the Metal Slug for the second, third and final bosses.
  • Unlock the Extra Dungeon Mission
  • During the fifth mission, collect the dungeon card. The card is located in level five, section three. In Metal Slug Advance, players can take different paths to the end of a level. To achieve the dungeon card, take the top path directly after the first playable screen of level five, section three. Then, take the top path again at the next opportunity to choose a path. This is a dead end. Kill any existing enemies at the dead end and pick up the dungeon card collectible. Head back towards the previous screen and finish the level. Once the player has completed the fifth mission and collected the dungeon card during play, exit to the mission select screen. In the upper left hand corner will be a selectable extra mission called "Dungeon."
  • http://www.cheatgenius.com/gameboy-advance-cheats/metal-slug-advance-cheats/
    you can also check the above link..if this helped please vote for me.. good day to you
    Dec 23, 2010 | SNK Metal Slug Advance for Game Boy...
    How do I disable the parking brake feature for the DVD for a Boss Audio BV9978B
    This is a feature which is a legal requirement by manufacture when producing unit, Driver is not suppose to watch tv while in control of a car.
    Jun 22, 2010 | BOSS AUDIO SYSTEMS BV9978B Car Video...
    Retrieving data, broken screen
    hi
    The Phone needs a new Keypad flex and most likely a left hinge pin. When the phone is open, the cable runs through the left side of the hinge. It is very common for the hinge pin to become chipped and put a small cut in the Flex Cable.
    You can get the parts on ebay. search for motorola v3 keypad flex, and motorola v3 hinge, or knuckle.
    thankyou.
    May 04, 2009 | Cell Phones
    Have Hitachi 65F59A, Screen broke
    HELLO GOOD AFTERNOON WHERE CAN I GET A PLASTIC SCREEN TV FOR HITACHI 65F59A.NEED HELP PLEASE
    Jan 31, 2009 | Hitachi 65F59A Television
    Replace small rear window
    if you pull back the rubber weatherstrip that goes around the door, you will see a phillips head screw that holds the metal frame of the glass.
    Dec 21, 2008 | 2000 Toyota Corolla
    Bypass parking brake wire
    Boss Audio is the easiest in-dash DVD on the market to bypass; all you do is ground the ebrake wire. I recently installed 12 Boss Audio in-dash BV-7300's and did this to all of the decks problem solved. By the way I did this because they were in the back of limousines where the driver couldn't ever even see one of them while he was driving. I don't think there will be a problem, try it.
    May 20, 2008 | Boss DVD-7500 Car DVD Player
    Sandisk 1 GB SD memry Error
    Well it sounds like you need to backup your Data meaning your Music on the MP3 Player, and put it back on to your Computer. That is the problem that you are having
    Jan 21, 2008 | SanDisk Sansa m240 MP3 Player
    Screen Died
    the lcd screen has lifted up from the flex circuit board or is broke.
    Nov 19, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
    BOSS AUDIO SYSTEMS BV9978B Car Video Player Logo
    215 people viewed this question
    Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
    Jose Velazquez
    Jose Velazquez
    Jerry Umali
    Steve Sweetleaf
    Steve Sweetleaf
    Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
