Question about LG 42LE5400 42 in. LCD TV
Trying to hook up to a new Dish network box that was sent as a replacement. Before I can go through the Dish set-up the TV picture blinks on and off constantly. I have replaced the HDMI cable, confirmed that the input setting is correct and cable are hooked correctly. Is there a resolution compatability issue?
    Novelist:
  • 185 Answers
I would try using a gold plated HDMI cable. Often the problem is that the cable is not capable of sending enough frames per second. I replaced mine with a slightly better quality cable I picked up at Sears for $25.00 and the issue was not only resolved th picture quality was unbelievable. If this doesn't help just reply and I will address this with you further!
Daniel Busa
DISH Network
Customer Service
Posted on May 25, 2011
  • gmauser May 25, 2011
    Dan,
    I tried several cables with the same result. I determined that the HDMI 4 input jack recommened for the TV inout was not making proper contact. I connected to the HDMI 1 jack and the system works fine. This all came about during installation of the TV in a cabinet with an auotmated mount that retracts the TV when not in use. I suspect that raising and lowering of the unit caused stress on the cable connection. I now have the cable securely anchored.
    Thanks,
    George
  • Daniel Busa
    Daniel Busa May 25, 2011
    I'm glad you have fixed it! Feel free to contact me here with any questions you may have!
I'm trying to hook up my Xbox 360 to a Philips flat screen tv but i don't know how with the dish network boxs
What does the Dish Network box have to do with anything? Just plug the HDMI cable into an empty port and change your input settings. Done.
Jun 05, 2014 | Televison & Video
Upgraded to Hd and tv started messing up. Double images for first 10 minutes and sometimes tv picture goes off and lines up and down.
Your HDTV is capable of up to 1080P resolution. SDTV (standard def) signals are 480i; EDTV (enhanced def) is 480P; HDTV are 720P, (there is no 720i) 1080i and 1080P. Generally, those modes ending in "P" look better than those ending in "i". 1080i is the highest possible for broadcast TV, but BluRay disks and Directv have 1080P display capabilities.
The double picture you're describing sounds like the TV is set to display only standard or enhanced def signals while the Dish Network box is supplying it with HD signals. You should locate the control for the TV's resolution and make sure it is set to "1080P" and then set the output of your Dish Network set top box to the highest output it offers. Do the same for your BluRay player and any other devices, too.
Once set correctly, you should have a great picture once again. I hope this helps & good luck!
Sep 04, 2012 | Sony KDL-40XBR4 40 in. LCD HDTV
I'm hooked up tp Dish Network an hit wrong button on top for volume and now pic is gone. in lower left corner says no signal., but dish is working, just no picture on screen
Hey there, Cheri Torres with DISH Network Customer Service here. It sounds like you are going to need to change your TV back to the proper input or channel. If the TV remote is not working to change the channels you can also use the buttons on the front of the TV. First look for a button listed as either input, TV/video, source or AUX. When you press this button it will start cycling through all the inputs available, make sure to cycle through them slowly because it make take a couple seconds for the picture to come in. If you do not find a picture on any of the inputs you are going to need to try the different channels. Normally for a TV where the receiver box is the TV should be set to channel 3 or 4. Once you have found your DISH Network picture you will want to make sure to push the SAT button on the DISH remote so that it doesn't change the TV channel again. I hope you find this information useful and if you have any further questions or concerns please let me know. Thanks. :)
Oct 22, 2011 | Craig CLC501 15 in. TV
I have Dish network. I want to record TV onto the VCR, but cannot get channels to record. i can playback videotapes and the record works, but cannot figure out how to get the signal to record.
The output of the Dish Network box should be hooked to the input of the VCR.
The output of the VCR should be hooked to the input of the TV.
The VCR should be on channel 3 to record. Select channel to be recorded on the Dish Network box.
It sounds like you have Dish Network box output hooked to TV input.
& VCR output hooked to an aux. input on the TV.
Nov 28, 2010 | Quasar VHQ401 VHS VCR
Screen "blinks" black every few minutes - Dish Network
Hi, Mary with Dish Network Customer Service. When the picture alternately goes from normal to a black screen, it is an indication of an intermitten signal issue. You can attempt to reset the receiver box by unplugging it from the power for 10 seconds and letting it reboot. Hopefully this will resolve your issue.
Jul 31, 2010 | DISH Network 322 DTV Receiver
Connecting DVD to cable only TV and Modulator box and Dish Networ
Without knowing the actual ports on each of these devices, all I can suggest is that have you tried connecting your DVD to the Dish box (thru VCR scart connection at the back of the Dish box) and then the Dish box into your modulator (and then modulator into your tv.
I have a similar system set up but we have a Sky Digital box here, no idea if its the same as a Dish box but im assuming so.
Jan 01, 2009 | GPX D1816 DVD Player
No signal when hooking up to dish network.
I unhooked the new tv and hooked up the old one to see what channel it was on and then rehooked up the new tv and put it on the same channel as the old one.This worked but I also had to put the cable into the hook up on the back marked cable instead of the one marked HDTV.
Dec 11, 2008 | Polaroid FLM-323B Television
Proron pltv-4250 no signal
THE BEST INPUT ON YOUR SET IS THE HDMI INPUT.2ND THE COMPOSITE INPUT. 3RD THE COMPONENT INPUT. AND 4TH THE ANTENNA INPUT. MOST DISH BOXES HAVE AT LEAST THE COMPONENT OUTPUT. YELLOW IS THE VIDEO AND RED AND WHITE FOR AUDIO. USE RCA CABLES TO GO FROM BOX TO LCD SET. ON THE DISH BOX YOU CAN GO FROM ANTENNA OUT TO THE CABLE OR ANTENNA IN ON THE LCD. SWITCH TV TO CHANNEL 3. AND TURN YOUR DISH BOX ON.
Nov 22, 2008 | Protron PLTV-4250 42 in. LCD Television
I purchased the hdtv model DP32648 at walmart, I hooked it up, it is on and working , But some stupid guy told me I needed a cable called HDMI, OK So I have it But I have Dish Network, their is no place to...
ya dish network reg box isnt hd ok u need call dish get hdtv box then u can use hdmi cable to get hi end picture ok for now use cox cable like u do to u can upgrade dish hd sumday k
Oct 15, 2008 | Televison & Video
LG 42LE5400 42 in. LCD TV Logo
Computer Repairing
Computer Repairing
