Question about EuroCave Refrigerators
I have a Eurocave Comfort V101 and it has stopped cooling. The compressor is warm but not extremely hot. The return copper is warm, but the covered copper is not cold. If I unplug and let sit for 10 minutes and plug it in, it starts to cool, but then stops.
  • 400 Answers
SOURCE: Normal that copper pipe shows frosting?
No not normal, this is a sign that the unit has been overcharged with refrigerant. If it is just frost or condensate on the copper pipe that is not a big problem. But if the frost extends onto the compressor dome, then I would be worried. Sometimes fridges are charged in an area with a lower ambient temperature and then moved and sold in another area, hence the slight overcharge. No problem. Hope this answers your question. And yes when the unit cycles the frost will melt and of course drip onto your floor.
Posted on Mar 10, 2009
Sea Breeze
  • 4654 Answers
SOURCE: stopped cooling
Best to unplug the refrigerator now and let compressor cool. The internal overload will be damaged if power remains on and trying to start. We need to test the compressor and start components before you buy anything, Let me know Sea Breeze
Posted on Aug 18, 2009
heatman101
  • 43501 Answers
SOURCE: both refrigerator and freezer have stopped
This sounds like your refrigeration unit is low on charge...there probably is a leak in the system...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 25, 2010
SOURCE: Eurocave comfort 264: Problem, ice formation
It's likely that you need to change the filter. Have a look at this post: http://blog.wineenthusiast.com/2009/04/20/caring-for-your-eurocave-3-simple-steps-towards-long-lasting-wine-protection/
Posted on Oct 15, 2010
walterkunesk
  • 683 Answers
SOURCE: My refrigerator and freezer have both stopped
did you try cleaning the condensor coils?
Posted on Apr 15, 2011
Ok so I have a ge cafe. I recently replaced the motherboard as my controls were all messed up and it was not cooling. Afterwards it worked fine except that there was a howling noise inside of the unit. A...
Correct, condenser coils remove heat from the freezer compartment, thusly they will be hot. Sounds like the compressor is failing and that is probably giving off a squealing sound and stops running until it stops. Then your compressor will overheat and stop running until the thermal protector cools down and allows it to run again. Try replacing the compressor cooling fan.
Oct 15, 2017 | GE Refrigerators
I have an Amana heater/airconditioner (Prestige I think) that is not cooling. The outside compressor fan was not spinning, so i I changed the capacitor on the unit. It now spins, yet vent air not cold
If that fan stopped your compressor overheated, shut off on thermal overload. Carefully cool compressor with water hose and restart. If the big copper is cold ,small copper warm, compressor is running. Check capacitor on compressor
Jun 06, 2016 | Amana Heating & Cooling
In garage/works perfectly/slow leak coming from an insulated hose that goes directly into the bottom of the freezer itself.
The hose coming from the bottom of the freezer is draining the melted water produced during the automatic defrost cycle. Usually the water is collected in a pan somewhere around the hot compressor motor so the heat can evaporate the water.
The hot copper tube by the compressor is the high pressure tube going to the condenser. The other tube going to the compressor is the return line from the evaporator and, after normal operation, is cold to the touch. It is this cold refrigerant returning to the compressor that cools the motor.
Aug 19, 2015 | Refrigerators
Eurocave comfort 264: Problem, ice formation inside the unite , half the way the middle section of the unit ( Racks 8-10)
Sep 30, 2010 | EuroCave Comfort 260 Collector's Package...
Both refrigerator and freezer have stopped cooling. The compressor sounds like it is working and then will stop. The fan is working. The copper pipes coming from the compressor are hot/warm to the...
heatman101
Sep 25, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
Problem with compressor
it is entailed process and you would need axcess to torch oxy-acc w #2 tip and silver solder, a evac pump, deep vac pump and container to capture the old freon usually compressors come with a new filter and the electrical parts per normal without sweep charge this process can take up to 4hrs to perform not for the unskilled if you do not remove the moistier from the system the new will fail shortly.....sorry for the news its be done by a professional...
Aug 19, 2009 | EuroCave Comfort 260 - Black Solid Door
Kenmore Coldspot side by side fridge/freezer no longer cold.
The black thing is the compressor. It should run warm but not hot. This usually indicates it's time to clean the condenser coils under the refrigerator. Try using a long soft brush and your vacuum cleaner.
May 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Eurocave Repair
can you tell if if it's running by putting your hand on the compressor,then we can go from there
Dec 17, 2008 | EuroCave Comfort 260 Collector's Package...
Top indicator light is on (orange)
Get info here:
http://www.eurocave.com/wine-cellar/wine-cellar-cooling.htm
Jan 03, 2008 | EuroCave Comfort 260 - Black Solid Door
Refrigerators Logo
77 people viewed this question
Top EuroCave Refrigerators Experts
Jim London
Jim London
Tom Chichester
Are you an EuroCave Refrigerator Expert? Answer questions, earn points and help others
