Question about Dyson DC15 Animal Bagless Upright Cyclonic Vacuum
Brush roller wont turn, motor is good and the curcuit board appears fine. No evidence of anything blown or broken wires either.
  • 731 Answers
Judging from this parts diagram:
http://www.searspartsdirect.com/partsdirect/part-model/Dyson-Inc-Parts/Vacuum-Parts/Model-DC15BALL/3207/0645000/50026393/00001?blt=06&prst=&shdMod=
The brus motor has what appears to be a transmission on it.
If you have it apart apply power and make sure the shaft that fits brush is turning.
If the motor spins but the shaft does not you need to replace the motor asm
If the shaft spins the problem is with the brush or the way the shaft attaches to the brush
Posted on May 21, 2011
Why wont the roller brush turn on my navigator shark NV22L
It could be a bad switch or brush roll motor, a broken belt, loose wire or contact. You must inspect and test all these areas to narrow down the cause.
Feb 28, 2017 | Euro-Pro NV22 Shark Navigator Bagless...
Brush wont move and its not the belt
If the belt is not broken, most likely the brush roller needs replacing. If the brush roller turns freely then it is likely the pulley on the motor that drives the belt.
Oct 03, 2014 | Proteam ProForce® 1500XP Bagged Vacuum
Hoover linx cordless bh50010 brush roller not turning
Simple!
Pull brush assembly from the handle.
Remove brush and belt, unscrew ALL screws at the bottom, separate parts, and to your surprise, you will see broken wire leading to the motor. Bad workmanship during assembly leads this wire to be twisted and cut by the plastic parts allowing swiveling. Be prepared to have some hard time setting motor in its place.
Oct 13, 2011 | Vacuums
Dyson dc 15 brush roll not spinning. motor is good, upper switch is good.
Open the right side of the vacuum with a hex head screw driver. There are 4 screws. Inside you will find a circuit board.
1. Make sure the varistor (S20K150) is not blown, these models seem to have an issue with this. It is a flat blue "quarter" looking component near the top edge of the circuit board.
2. At the bottom of the circuit board are two white wires connected via push on connectors. Remove these from the circuit board by sliding them away from the circuit board. Power on the vacuum and engage the drive button. If the lower motor still does not engage check step 3.
3. A blue and yellow wire runs off the bottom end of the circuit board. These are the wires powering the lower motor. Check continuity with a multimeter and make sure they are not broken. I have seen where these wires will break as they run through the housing of the vacuum. If they are broken, replace them with any wire of the same gauge.
Dec 15, 2010 | Dyson DC15 Animal Bagless Upright Cyclonic...
The brush does not spin when engaged. Everything else is working fine.
When you remove the brush, the release button resets a trip fuse on the pcb. If that does not work at sounds like you have either blown the rectifier pcb or burnt out the DC motor that is in the brush head. You can get a complete replacement brush head for 70 pounds.
Jul 28, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Motor turns on, but brush won't turn. belt is not broken
Sometimes hair and debris get in the end of the rollers and keep them from turning. Also, the bearings can become corroded and stick. Try removing the rollers and check for any debris and remove it. If the bearings are stuck, you can spray some lubricant or WD40 or them and try to free them up. On occasion the belt can come off of the motor. You can turn the unit over and see if the belt is moving over the roller. Good luck and let us know how you made out.
Mar 04, 2010 | Bissell 3920 Bagless Upright Vacuum
Kenmore progressive 360 vacuum cleaner has low suction
Check the tube that leads down to the brush head for clogging as well as any motor or HEPA filters. If that still shows nothing, take the cover off the brush head (like you're changing the belt) and look for obstructions in there. Usually, if you have low suction on the accessory hose, the problem is with a motor filter, HEPA filter, or a clog where the hose goes into the unit. If you have good suction on the accessory hose but none on the floor, it's usually in the brush head (clog or broken belt) Good luck
Feb 28, 2010 | Kenmore 35912 / 35913 Progressive Upright...
DC15 Animal brush motor not working?
Just had the same problem. Switches and motor checked ok, then found the circuit board on the left hand side of cleaner. The fuse (on the board) looked ok, but when removed and checked for continuity I found it had blown. The problem I have now found is that the fuse cannot be ordered only the complete board. Hope it gets the brush roller going again.
Mar 01, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Dyson DC15 Animal Bagless Upright Cyclonic Vacuum Logo
226 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
