Question about Poulan "Poulan" Push Mower
My poulan 22 in bogs down when cutting - Poulan "Poulan" Push Mower
  • 3 Answers
There is probably debris that made it through the gas cap and into the tank, and is now clogging the fuel pickup tube. Had this same problem with a Poulan on my first use. Use a suction bulb or vacuum tester to draw contaminated gas out of tank, and rubber band a coffee filter over the cap in the future. DO NOT put a piece of coffee filter under the cap above the cardboard, it will get splashed with gas and stall the engine. Trust me on this one. After I performed this repair, the mower cut like a champ again.
Posted on Jul 01, 2011
How do I adjust the carburator on a poulan wild thing 2375 chain saw that bogs down when cutting and is hard to start?
there are two screws on the carb start by turning them all the way in then 3 full turns out and then make half turn adjustments until you get it right..
Aug 06, 2014 | Poulan Garden
I have weed eater/poulan 22" push lawn mower. It
Hi goldengear...
Make sure you have installed the blade on the right way, if it is installed upside down then it will "beat" the grass instead of cutting it and make a terrible cut, also make sure the blade is good and sharp.
The rough running may be due to trash in your carburetor, I would advise to clean your carburetor and also check you fuel tank for trash, water,etc. if there is any trash,water,etc in there then you need to also clean the fuel tank.
Do one more thing and check/clean/replace your fuel filter if you have one.
Please take time to rate me
Aug 18, 2011 | Poulan "Poulan" Push Mower
Brand new today Poulan P1500..Started, warmed up. Went to accelerate and it just bogged down and died with no cutting load on it. From what I am reading on forums Poulan is going to give me problems. I...
you have 2 options, return it or use a dremel tool and cut a slot in top of low speed jet screw and turn counterclockwise bout 1/4 turn, keep in mind if you do this it can't be returned, I have seen a lot of good poulans and a lot of bad poulans, flip a coin !
May 04, 2011 | Poulan 25cc 2-Cycle Gas Powered String...
Chain saw starts fine, idles fine, and powers up fine when not cutting a long how when starting to cut a log it bogs down and dies. Does anyone know how to fix this problem or what’s wrong with the chain...
Two things that can cause this problem. 1. Your carburetor is not set properly and is not letting the engine get enough fuel under a load. 2. Your chain is binding when you put the chain bar down on the log. Make sure your front chain sproket is turning free and is not too sloppy.
Sep 12, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 22" does not mulch!
When you mulch you can only cut 1/3 of the grass off. If the grass is 3" high you can only cut 1" off.If you are cutting more grass of than you are leaving there is no place to hide the clippings.A general rule is if you notice clippings and clumps beginning to lay set the mower up one notch at a time until the clippings are hardly noticeable.If you like a real low cut then mulching is probably not for you,you will probably want to bag the grass instead.Hope this helps.
Sep 05, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Idels good but when i start to cut it bogs doun
Either the spark arresting screen is clogged with carbon, or the carb is out of adjustment on the high speed jet.
Mar 31, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
I have a poulan 2050 won't stay running
Hi, are you pumping the primer, till it's full, before starting?
Mar 23, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan "Poulan" Push Mower Logo
93 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
