Question about Karcher 2500 PSI Pressure Washer
I need the owners/operators manual with parts listing and parts numbers for the K'A'RCHER HDS 750 hot high pressure washer.... PLEASE.......
  • 2,841 Answers
What should the persure be for a hds 750 karcher
These units are variable, while the pump has a operating pressure of 1450 psi (100Bar) they can be taken down to 290 psi (20Bar) for steam cleaning.
Hope this helps:)
Brad
Jul 17, 2014 | Karcher Garden
I would like a karcher instruction manual for a HDS650 pressure washer
I believe the HDS sends spark to the ignitor any time the machine is on ( hot or cold) You should hear the crackle of the ignitor in the burner area. Perhaps the ignitor rods are not properly aligned. Perhaps your ignitor coil is bad. There are several safety switches and the thermostat that would keep the burner from firing if they are bad. There is a pressure switch that turns on and off the motor for hot or cold operation. That is apparently working. I think there is a flow switch that turns off the burner. The thermostat might not be opening and closing contacts and that will keep the burner from working. I believe there is a high temperature safety switch as well.
Jul 15, 2014 | Garden
Home lite pressure washer 163 cc do you have parts for this
If you are looking for parts for this machine, you'll need to know the model number; if it is for the engine, the name (Honda, Briggs & Stratton, etc.) and the model number to it. If you still have the owner's manual, there is usually in the appendix, a schematic along with a parts list page.
You can easily go online and enter the "Home lite" brand name of the pressure washer, the model number plus the words owner's manual.
Same thing for the engine.
There are many online manual sources.
Nov 22, 2013 | Garden
6bsxs.3422ht No spark and dealer can't identify which coil it uses
It looks like it uses part #492341. I didn't see any other ones listed. It's item number 333 and they call it an armature even though most people, including myself, refer to it as the coil. Here is a link to the engine parts diagram that I found for it.
http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=18npyLXCnfBhU7y
And here is the main page with the other diagrams and owners manuals that you can down load.
http://www.briggsandstratton.com/generators-pressure-washers/support/operators-manuals/?NTT=30241
Jul 19, 2011 | Briggs & Stratton Power Products 5,550...
My Kärcher K2.080 pressure cleaner (1450psi /
According to my search, Karcher has a 2 year warranty on this product. If you can get the serial number and model number off of it. They should be able to identify when it was made and then can honor that warranty. Otherwise the pump seals appear to be damaged by your description of the problem. Hope I've helped.
Best, Mark
Dec 28, 2010 | Karcher Electric Cold Water Pressure...
I am looking for a workshop manual for karcher hds 555 ci hot pressure washer.or access to where i can download one. any assistance is greatly appreciated
hi could you post your email address and i can email you a full pdf file, also on the chassis of the machine there will be a silver sticker could do with all the numbers to find which modle it is regards
Jan 19, 2010 | Karcher PSI Electric Pressure Washer
Cant change the high pressure hose on a Karcher
On the Kärcher, you have a bayonet mount at the base of the tip end of the pistol grip. This is where you attach different types of nozzles and gadgets after having removed the existing sprayer tube. Just push in and turn a quarter of a turn, then you pull it off the pistol grip. The hose is possible to remove from the machine as well, an ordinary threaded mount but since you need the pistol grip to regulate on/off this is probably not what you want to do. If the telescopic wand is made by Kärcher it should be very easy to snap it into place just like when you removed the sprayer tube/nozzle. If the attachment was made to fit Alto washers there is an inexpensive adapter that works very well. Good luck!
Jun 03, 2009 | Karcher G 2600 VH Gas Pressure Washer
Karcher HDS 750 HOT HIGH PRESSURE WASHER
G-day Mate.
Did you check if the igniters? they may be cloged up with ****. Unscrew the Sight glass on top of the boiler and run the machine (in cold or hot mode, doesn't matter, as the igniters are running all the time) and see if there are working, you should take them out anyway and give them a wipe with a rag as general maintenance item, and when you put them back in there should be about 5mm gap between them.
Less common reasons for the boiler to not work
- Faulty fuel solenoid valve, (You should hear a click sound about 5 - 10 seconds after you pull the trigger)
- Dirty fuel filter,
Take a look at those simple things and let me know if its any of these.
I have a Karcher HDS 750 1989 Year model
This machine just keeps going, it's had a fairly tough life but it has stood up to it all,
i hadent spent anything on it until about 6 months ago when i purchased a new fuel pump for it as the old was wasn't pushing 170PSI to the Disiel injector it had slowly droped 70psi, and it doesn't create a hotter burn in the boiler, but still very good for a 19yr old pump,
other than that thats all it's needed, it's still going strong to date
Very robust machine.
my e-mail is cgodfx@internode.on.net
Cheers Matt.
Apr 07, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
249 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
