Question about DR Scholl's Health & Beauty
Dr Scholl's comfort plu Foot bath model # DR6652
3 Suggested Answers
SOURCE: I have a Dr. Scholl's
yes,
seal is stuck.
open it with a screwdriver.
then, the side that is stuck, take a plier and remove the metal clip closest to the motor. with pliers again, unstuck the tube that is most likely stuck and remove one side of it. blow into it with your mouth. not too hard.
when unstuck, you can blow and **** air... you should feel and hear the diafragm work fine.
close it up and voilà.
Posted on Jun 19, 2011
SOURCE: Need instructions on how to
How to fill your Dr. Scholl's Thermal Therapy Quick Heat Paraffin Bath1. Take the lid off your bath container and remove all packing materials.2. Place the unit on a flat, heat-resistant surface.3. Remove the plastic rack.4. Remove all three blocks of paraffin wax from the plastic wrapping. Each block is equal to one pound of paraffin wax, and three pounds of paraffin wax are needed to begin using your Paraffin Bath. Break each block in half, then in half again.5. Place the blocks of paraffin wax in the Paraffin Bath container.6. Plug the unit into an electrical outlet. The green light will glow. The red "Heater" light will initially come on and then cycle on and off while the wax is melting.7. Replace the lid and turn the switch to the "high" position. The paraffin wax will be ready for use when it is visibly melted (approximately 120 minutes).8. As soon as paraffin wax has melted, place the plastic rack on the bottom of the heating chamber. This will protect hands, elbows, and feet from heat.9. Turn the dial to the "Keep Warm" setting and wait 25 minutes before dipping hands, elbows, or feet.
Warning: DO NOT place hand or any other body part inside the chamber while the unit is melting the wax.
How to Dip Hands1. Remove jewelry, roll up sleeves, and thoroughly wash and dry hands. You can also rub in some of your favorite hand lotion.NOTE: The lid should be on during the time the unit is heating. Put the lid back on the unit after each use.2. Put a small amount of wax on the inside of your wrist to test the temperature.3. Spread fingers apart slightly and slowly immerse your hand in the paraffin wax container. Then immediately, but gently, remove your hand from the Paraffin Bath chamber. Let the paraffin wax solidify on your hand. Wait at least three seconds (until the paraffin wax no longer appears shiny) before redipping. Be careful to avoid touching the sides or the bottom of the Paraffin Bath chamber.4. Continue to dip your hand in and out of the paraffin wax, following Step 3, to build up layers of paraffin wax. For the best results, do this at least five times. The more layers, the longer the heat will last.5. If desired, cover your hands with glove liners and place your hands in the insulated mitts. These retain heat for better results.6. Remove the hand mitts from your hand. Remove the plastic glove and discard. Peel the hardened paraffin wax from your hands. It is recommended that the hardened paraffin wax be discarded.7. Massage in the oils left on your hand after the paraffin wax is peeled off to get the full invigorating and rejuvenating benefits of your Paraffin Bath.NOTE: Allow the paraffin to remain in place for 10-15 minutes before removing; longer if more layers exist or if the mitt has been used previously.
To Treat Feet or ElbowsFollow steps 1-4 as outlined for hands. Mitts are intended for use with hands only.
Product Care and Maintenance Place paraffin bath in a safe, cool and dry place when not in use. Wipe with a soft, damp cloth. DO NOT use abrasive cleaner. Never submerge the unit in any liquid. Keep away form all solvents and harsh detergents. DO NOT attempt to repair this paraffin bath. There are no user-serviceable parts.
STORAGEWhen not in use, "unplug it."Allow appliance to cool and store out of reach of children in a safe, dry location. To protect from dust or dirt, simply store in its original box. Never wrap the cord around the appliance since this will cause the cord to wear prematurely and break. Handle cord carefully for longer life and avoid jerking, twisting or straining, especially at plug connections.
CLEANING INSTRUCTIONSRemove plastic rack from heating chamber.1. DO NOT unplug the Paraffin Bath. Allow paraffin wax to remain undisturbed for a few minutes.2. Turn unit off and let the paraffin wax "harden."3. Right before cleaning, turn the unit on again until the paraffin wax is visibly melted around the entire edge (approximately 3-5 minutes), then turn unit off and unplug from the electrical outlet.4. Spread an ample amount of paper towels on a hard, flat, heat-resistant work surface and slowly turn the unit upside down to allow the hardened paraffin wax to drip from the chamber onto the paper towels. Allow the surface of the paraffin wax block to harden and then discard it. To clean the empty chamber, wipe with paper towels to remove any sediment.5. To clean the outside of the unit, remove any solidified paraffin wax.6. DO NOT use sharp objects to remove solidified paraffin max.7. DO NOT scratch or damage the Paraffin Bath chamber.8. DO NOT use abrasives when cleaning the Paraffin Bath chamber as it will damage the finish.9. If you discard the paraffin wax after each use, we recommend you clean out the unit completely every 40 uses. If you re-use the paraffin wax after every use, we recommend you clean out the unit completely every 20 uses.
PLEASE NOTE: This appliance should not be used in the presence of open cuts or wounds, inflammatory skin conditions, growth peripheral vascular disease where circulation is impaired, acute inflammation, or where sensation of the extremity is reduced or absent. If there is any question about peripheral vascular disease or decreased sensation of the extremities, consult a physician or physical therapist before using the Dr. Scholl's Thermal Therapy Quick Heat Paraffin Bath. Discontinue use if dermatitis due to paraffin sensitivity occurs. Discontinue use if wax feels too hot or cool, which could indicate health problems with the user.
There are also a bunch of standard warnings about dealing with electric appliances. Take care of them, don't dump them in water, etc., etc., etc.
It's worth pointing out that paraffin wax is flammable.
Posted on Nov 06, 2011
How to adjust a dr scholls
The Dr. Scholl sandal? Slide the metal band backward off the pin and then lift the strap off the pin and adjust to suit your foot.
Mar 10, 2015 | DR Scholl's Clothing Accessories
Have purchases Dr Scholl ANTI -HONGOS Antifungico in spain. Require a set of instructions in English. Can I find them online ? Thank you
I did the same thing. It might be a little late for you, but I found this UK page by Dr. Scholl:
http://www.scholl.com/en-GB/fungalnailrange/Page.raction
Sep 19, 2011 | DR Scholl's Dr Scholl s Fungal Nail...
How do you adjust the ******** Dr Scholls original sandals?
There are buckles that are easy to adjust once you know how. Take the slide and move it sideways to the outside. Lift the strap and adjust it to fit and then close the buckle. You should be set!
Sep 15, 2011 | DR Scholl's Dr. Scholl Dr.Scholl Shoes
I have a pair Dr Scholl sandals with the cork sole and suede straps. Can you please tell me is there anyway of cleaning them? Thank you Sharron
You didn't say what needs to be cleaned. If it is the straps, any shoe repair shop or any good shoe store should have suede cleaner.
It won't be cork under the bottom and if that is dirty, then an old soft toothbrush with dish detergent would take care of most dirt that you would get on them. You can seal them with something like Klebfast cork sealer to keep the dirt from coming back in at the sole.
Mar 22, 2011 | DR Scholl's Dr. Scholl Dr.Scholl Shoes
I have a Dr. Scholl's Comfort Plus foot bath model number DR6652 only one side of the bubble is working what could be the problem. And how do I thoughly clean it.
yes,
seal is stuck.
Sep 27, 2010 | Vacuums
Health & Beauty Logo
198 people viewed this question
Top DR Scholl's Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a DR Scholl's Health and Beauty Expert? Answer questions, earn points and help others
