Question about Clarke Power Products Clarke 16-Speed Drill Press with Laser Centering Device # BT102
Arbor spins in quill on my bt1029. troubleshooting tips in manual are no help. suggestion?
    Sergeant:
  • 281 Answers
Sounds like it it is not seating.I would check for something stuck up inside.(assuming this is a Morris taper)
I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.
Thank You for choosing FixYa .com.
Posted on May 21, 2011
Does it have a reset button? Mineresarts the spin over and will not get out of the spin cycle
Questions, Troubleshooting Help & Support - Fixya
www.fixya.com/troubleshoot
Get free troubleshooting help, expert advice, repair guides & DIY tips for all your products. ... Mineresarts the spin over and will not get out of the spin cycle.
Out of the Spin Cycle: Devotions to Lighten Your Mother Load
www.amazon.com > ... > Motherhood
Amazon.com, Inc.Out of the Spin Cycle: Devotions to Lighten Your Mother Load [Jen ... FREE Shipping on orders over $35. .... Get your Kindle here, or download a FREE Kindle Reading App..... It's not a how-to manual or one on Christian parenting theories. It's just a fun devotional book that will remind you that, between the cadre of other ...
Jan 18, 2016 | Washing Machines
I bought an Ammco 4000 brake lathe and the arbor was not installed in it. The one they gave me has surface rust on it. It will not fit into the spindle either. I'm not sure on got the correct one. What is...
A standard arbor which you should have been provided with should look like this...
The standard arbor size is 1 inch.
A used arbor is okay--but if it has rust on it, you should remove the rust with a wire-wheel mounted on a bench grinder (and be sure to use eye protection because fast spinning wire-wheels routinely throw off wires).
Any arbor (especially new arbors) have to be lapped into the spindle using a fine lapping compound which can be easily found at auto parts stores.
Apply a small amount of lapping compound onto the mating surface of the arbor and insert it into the spindle with the machine turning. Hold the arbor tight and let the lapping compound grind away for about 40 seconds.
Remove the arbor and reapply another small amount of lapping compound--repeat the grinding process one more time. Remove the arbor and using a rag clean the lapping compound from the arbor.
Clean the lapping compound from the outer spindle seat. The outer seat is easily accessed--the inner seat of the spindle is harder to access. This is cleaned by doubling a rag over the threaded end of the arbor. Holding the rag, insert the threaded end into the spindle and clean the inner seat.
Turn off the machine and insert the arbor into the spindle. Insert the spindle "draw bar" (which you should also have) through the hole in the drum gear box (Infimatic gearbox) on the right hand side of the machine.
Holding the drive pulley, tighten the draw bar.
Next you have to check the arbor run-out using a magnetically mounted dial indicator as shown....
Mount the dial indicator on the machine's twin cutter (tightened down) and crank in the disc-feed carriage until the dial indicator can make contact with the arbor.
Start the machine. The arbor run-out should be no more than 1 1/2 thousandths. If the run-out exceeds greater than 8 thousandths it cannot be straightened. Arbor with slight run-out problems can be straightened.
(Note: If the dial indicator vibrates too much to get a reading--you will have to manually turn the machine using a wrench as described below).
First try loosening the draw bar, and rotating the arbor 180 degrees and then re-tightening the draw-bar. Many time this will solve the problem or at the very least lessen the run-out or bring it within spec.
If the arbor is still exceeds spec, then you have to straighten it. To straighten an arbor, manually turn the machine with the "Ammco wrench" (which you should also have) using the nut on the draw bar. Turn the machine until you find the high spot (straight up), then remove the dial indicator to prevent damage.
Using a copper dead blow hammer, give the arbor a modest whack, and then recheck the run-out. Repeat the process until you manage to get the arbor within spec.
Please note that straightening an arbor using this method will sometimes break the arbor off. You are rolling the dice when straightening an arbor--but this is the nature of the animal. Even brand new arbors sometimes need straightening.
If you need more questions answered contact us at...
http://www.brakelathe.net/
Mar 14, 2015 | Ammco Combination Disc/Drum Brake Lathe
Need to raise the handlebars on Point Beach Schwinn bike
It's called a quill stem.
Google "how to adjust the quill stem on a bike" for video tips or just read this...
http://www.sheldonbrown.com/handsup.html
Jun 06, 2011 | Schwinn Cycling
I cant tighten the blade on to the arbor arbor is spinning
If your saw is not equipped with an arbor lock, there are several methods of holding the blade while you tighten or loosen the bolt. First, hand tighten the nut to get it snug. Then you can either wedge a Phillips screwdriver shaft between a blade tooth and the base, or you can use a pair of pliers to squeeze the blade and hold it in place against the base. Be careful not to nick the tips of the blade and be cautious with your hands. Obviously you want to make sure you are spinning the bolt the right way, too. You don't need to really crank bolt down, just firmly tighten it and leave it be.
Nov 28, 2010 | Skil 558001RT FactoryReconditioned 7 14"...
I do not remember how to assemble the blede & associated parts. Also the direction the blade teeth should be facing
The blade should be installed with the teeth tips facing the front of the saw. Place the blade on the arbor shaft, then the blade washer and then thread the lock bolt in the arbor.
Please go to this site and download a copy of the manual for your saw. Just enter your model number. Power saws are dangerous and you should refer to the users manual for safety info before using. I hope this helps.
http://www.boschtools.com/service/productservices/pages/manualsandpartsdefault.aspx
Jul 03, 2010 | Bosch 7 - 1/4" Skilsaw Circular Saw
Blade shaft slipping
It could be a number of issues. These saws have a built in vari-torque clutch used to prevent kickbacks. Basically, when the blade binds while cutting, the arbor spins but the blade won't (prevents kick-back). It works by not over tightening the blade washer (this is the slip clutch), if you over tighten, the blade washer can't prevent kick-backs because it has no room to slip, if you under tighten, the arbor spins, but the blade won't. I'd try to tighten the blade washer 1/8 turn and see what that does. If your actual arbor shaft is not spinning, you could have a gear issue. If you hear the motor running and the arbor slips (not the slip clutch) sounds like there might be a gear issue,If the rotor is spinning (the part inside the stator-i.e. the electric motor section) but it is not transfering that movement to the arbor, it has to be a gear issue.
Jun 07, 2010 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Where do I get parts for a clarke drill press model bt1029?
the part number I found is BT1029-0038 for the quill spring and you can contact them at 1-800-227-9603 and see about ordering the part. If I have helped you would you please rate this response accordingly and thank you.
Sep 24, 2009 | Clarke Power Products Clarke 16-Speed...
Old ariens model 927030 .. starts and runs fine . however once I sart mowing , it will mow for a few minutes and start bogging down as if something is heating up and starts binding... any suggestions?
YEs it sounds like one of the quill assemblys is heating up and the bearing is starting to bind, the quill assembly is the unit that is between the blade and the belt that the blade and pulley attach to there is 2 bearings inside these and with age they start to wear out and need to be replaced my suggestion is to replace all the quill assemblies at one time as this saves headaches down the line when another starts to fail. Hope This Helps Don
Sep 03, 2009 | Garden
Blad won't spin
If it's the small, stationary saw they show on their web-site, the only thing I might suggest is that you check to make sure there are bushings in place on each side of the blade (is the arbor spinning, but the blade not?). Otherwise, since it's a direct-drive unit, there are no belts, etc. Some small saws have an arbor-lock on the motor, to help with tightening the arbor-nut. If this is stuck engaged, it would keep the motor from turning, even though you hear something. Not familar with this brand though, and their PDF manual leaves a bit to be desired. Hope this helps.
Apr 21, 2009 | Heating & Cooling
Broken arbor on lenox hole saw
Mine has a set screw some of them might threaded
Mar 15, 2009 | Lenox 48CT 3" Carbide Tipped Hole Saw
Clarke Power Products Clarke  16-Speed Drill Press with Laser Centering Device # BT102 Logo
139 people viewed this question
Top Clarke Power Products Drills Experts
Are you a Clarke Power Products Drill Expert? Answer questions, earn points and help others
