Question about Plumbing
I have a five-year old Amtrol water system tank, model #CH4202. For some reason, despite regular changes of my well filter, my water has suddenly taken on a bluish tone. Coincidentally (?), it's the same blue as the Amtrol tank. Any connection here? Any experience with this phenomenon?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 306 Answers
This is not related to the well tank. A bluish tint to the water is generally related to the PH and copper corrosion of plumbing. Electrolysis caused from degradation of dissimilar metals and softened water can cause this to occur also. It is rare for the PH of water to change drastically but the water chemistry can change, hardness, iron, H2S etc. I have seen Tannins in water impart a bluish tint also when they are present in very slight amounts. Have the water tested and check for any corrosion of plumbing in the home.
RJ
Posted on May 22, 2011
Testimonial: "Absolutely outstanding response! It was not the answer I was expecting, but the possible solutions given were extremely thorough and helpful!"
  • RJ H2O
    RJ H2O May 24, 2011
    I am glad I could help and hope the suggestions get you pointed in the right direction. I appreciate the kind words. You may find the tip on changing sediment filters and problems with housings helpful also.
    Good luck and Good water,
    RJ
AMTROL WH7P-41 GAL TANK. 12 YRS OLD. BOILER PRESSURE IS INCREASING ABOVE 30PSI, AND DUMPING SMALL AMOUTS OF WATER FROM RELIEF VALVE ON BOILER. Do I replace coil?, or buy a new tank? Thank you
do you have a pressure tank as part of your water heater and water pipes? if yes, check to make sure tank pressure matches your incoming water pressure from your municipal hook up
Aug 18, 2015 | Amtrol Water Heaters
My AMTROL water well tank is copying the pressure of the prussure switch
Sand the points on the pressure switch
Replace pressure switch
http://www.amazon.com/dp/B000BQSERE/?tag=waterheaterti-20
Test you are getting 240Volt to pressure switch
Turn breaker fully off and then fully back on
Replace control box or replace start capacitor:
http://www.amazon.com/dp/B0060C7GFO/?tag=waterheaterti-20
Drain tank, and replace the air valve
http://www.amazon.com/dp/B000BQYKJK/?tag=waterheaterti-20
Gene
Aug 22, 2014 | Amtrol WX-302 WX-302 150S1, 86 Gal...
Fill-trol what does do on the heating system?
How the Amtrol FILL-TROL(c) Expansion Tank System Works:
Water enters the FILL-TROL valve, pushing open the check valve, and flows into the heating system. The automatic shut-off valve is kept open by the diaphragm pressing against the pressure plate, raising the stem of the fill gate, which compresses the automatic shut-off valve spring. When the heating system reaches fill pressure, the tank's diaphragm depresses, and the automatic shut-off valve is closed.
Whenever system pressure falls below 12 psig, the automatic shut-off valve is pressed open by the diaphragm. Make-up water flows into the system to restore pressure.
http://www.plumbersurplus.com/Prod/Amtrol-110-FILL-TROL-Expansion-Tank-4-4-Gallon-110-1/7938/Cat/219
The AMTROL FILL-TROL(c) system consists of a specially adapted EXTROL pre-pressurized, diaphragm-type expansion tank, and the FILL-TROL, a specially designed, automatic, fill valve.
  • Provides accurate system make up
  • Eliminates need for a separate, automatic fill valve
  • Fully adjustable up to a maximum working pressure of 100 psig
  • Factory pre-charged; tank pressure controls system fill
http://www.amtrol.com/filltrol.html
Nov 08, 2013 | google.com
Heater broke, my Amtrol water heater expansion 80 gal tank, takes hot water from the oil fired furnace, and keeps it hot, However, the tank is set at 140 degrees, but the water coming out if the hot wter...
Hiliary
sounds like the primary coil in side is cracked and is mixing hot water.. with the cold water in tank need to check and replace as necessary
Sep 15, 2013 | Amtrol Water Heaters
The relief valve coming out of my hw heater occasionally has a steady drip of hot water after the heater has been running. Drips accumulate in a bucket maybe a gallon/ week. Gas company rep (here for a...
The exspansion tank is more than likly the problem. The temperature/presure valve may also be the problem. Replace both. To replace the exspansion tank turn off the supply water coming into the water heater. Open the relief valve and purge the presure off the tank. drain the water heater slightly below the temperarture/presure valve to replace. The exspansion tanks screws off. Use new teflon taope on the threads when replacing both the exspansion tank and the T&P valve. This work can be compleated by the homwowner with some mecanical inclination.
Jan 23, 2011 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
My A.O. Smith 8 year old water heater drips water out of the expansion valve but only when it is heating water. The builder of my home mounted the Amtrol THERM-X-TROL ST-5 in the horizontal position and I...
It seems that you have this figured. In their literature all units are shown vertical, either inlet up or inlet down. Also, it appears that if the unit is full of water, (water logged) pressure will build up in the system. Temporarily, you could shut off water to the water heater, open some drains and use a pump to put some air back into the tank. This would at least get air into the upper half of the tank for a while until you can get set to make a repair.
Gary
Dec 14, 2010 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
What psi do I set the tank at
Hello The tank pressure must MATCH the system pressure it is instslled on.EX: 70 psi in the pipe = 70 psi in the amtrol.
Sep 04, 2010 | Amtrol ST-120V-C THERM-X-TROL ASME...
I have a large Amtrol water heater. I bought the system origianlly several years ago. Last year the bladder failed. Amtrol honored the lifetime warranty and provided a new one but I had to pay installation...
i would recommend getting a "superstor" tank,...(not messing with the amtrol again) is this run off of your boiler? if so, you'll like a "superstor", good luck, cracklin joe,........
Jan 04, 2010 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
Plumbing Logo
266 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
