You can perform some Whirlpool electric
dryer timer troubleshooting to determine if the timer is faulty or if
the cause is somewhere else within the dryer.
Test the Timer
Remove the single screw on each end of the control console that
secures the control console housing to the top of the dryer. Grab the
sides of the control console and raise the front of the console up and
toward the rear of the dryer. With the control console in the service
position you will now be able to test the timer.
Replacing the Timer
Set the scale on a volt-ohm meter to the RX1 setting to measure the
ohms of the timer. Place one probe to one terminal and the other probe
to the remaining terminal. You should get a reading between 2,000 ohms
and 3,000 ohms. If you do not get this reading, replace the timer.
Place the new timer inside the console and secure the timer with the
two retaining screws. Attach the wires to the timer and remove the
masking tape from the wires. Lower the control console and reattach the
console to the top of the dryer with the retaining screws. Push the
control knob back over the timer shaft. Push the dryer back against the
wall and plug the power cord back into the electrical outlet.
