Question about Garden
I need to get blades off Woods Dixie Cutter Model MD 160-1 to sharpen. Please advise
5 Suggested Answers
  • 10865 Answers
SOURCE: I sharpened the blades at the end of last mowing
The problem you discribe is the classic broken blade spindle or quill. The tube that supports the bearings between the deck pulleys and the blades is almost certainly broken. Look under the deck [mower OFF] at the piece right above the blade that is malfunctioning and you will probably find a bad bearing or a chunk of the tube that holds the bearing/blade to be missing. That happens when the blade gets 'wacked'. The outer edge is cutting too high because the belt is pulling the shaft toward the center of the deck. The quills are fairly easy to replace. Get the model number off your tractor before you go to buy the part.
Posted on Apr 04, 2009
  • 32 Answers
SOURCE: duel blades on craftsman riding mower cut unevenly
check the front tire air pressures then for a bent blade
Posted on Jul 20, 2009
  • 61 Answers
SOURCE: need to sharpen my blades.not sure exactly how to
there should be a bolt in the meddle of each
blade 9/16 or 5/8 headed bolt remove the bolt sharpen
blade w/grinder and replace same as removal
Posted on Sep 06, 2009
Its not the tires it is the blades don't line up.One blade is three-quarters of an inch lower.Is there a shim for the star fitting.
Posted on Jun 11, 2010
Need to sharpen the rotary blade
Top 5 Ways to Sharpen a Rotary Cutter Blade ' eBay
www.ebay.com > ... > Quilting > Quilting Tools & Equipment
Since the 1970s, rotary cutters have provided a reliable and efficient method for quilters, garment-makers, and other workers of fabric to create symmetrical and ...
Sharpening and Maintaining Your Rotary Blade from Scrap ...
? 5:54
https://www.youtube.com/watch?v=Kdd3JiWnmtE
Mar 13, 2012 - Uploaded by Craftsy
Sharpening and Maintaining Your Rotary Blade from Scrap Quilting with ... My online Craftsy class, Scrap Quilting: Waste Not, Want Not, will ...
Penny's Hands: How to Sharpen Your Rotary Cutter Blade
pennyshands.blogspot.com/.../how-to-sharpen-your-rotary-cutter-blade....
Mar 5, 2011 - And what has the aluminium foil to do with sharpening rotary cutter ...Thanks for that tip Penny, I have lots of blunt blades I can sharpen now.
Jan 27, 2016 | Food Processors
Removing cutter
Is this a guillotine style cutter or a rotary style cutter? What brand/model? Some rotary cutters are self sharpening and some cannot be sharpened.
Jul 12, 2014 | Tools & Hardware - Others
Can I sharpen the blade on my paper cutter?
You can sharpen the blade on your paper cutter but since they can be hard to sharpen you are better off leaving this task for a professional.
Sep 29, 2013 | Office Equipment & Supplies
I have just had all the blades sharpened for my clippers but they won't cut my dog's fur. Never had a problem before. Can you please help?
It is common to that a Blade Sharpening Service return your blades just as blunt as before, or even worse.
I advise that you try a new Blade Sharpening Service; trying out only a couple blades to begin with.
I recommend a mobile/on-site sharpening service.
Sep 15, 2011 | Oster Golden A5 2-Speed Universal Motor...
Blades need sharpening or replaced. Where do I go in JHB area
Braun syncro 7526 foil and cutter blades is Braun Series 3 combi 30B foil and cutter replacement pack.
Apr 18, 2011 | Braun Syncro 7526 Electric Shaver
Blades normally glide tight thru hair....cleaned and oiled blades but still meeting resistance on perfectly combed not matted hair. Blades are approx 5 yrs old. Do they need sharpened maybe. Should I...
Ok if you take them appart don't touch the screws you will find it hard to re-align, if your blades haven't been sharpened for 5 years the i think its a very good place to start
Jan 22, 2011 | Andis AGC2 Hair Trimmer
Wahl kennel pro 8800 noy cutting hair
if the blade look black on the cutter blade and also the comb blade where the teeeth are U need to sharpen them Mannys Sharpening clipper doc
Nov 11, 2009 | Health & Beauty
Adjustment of sharpened cutter of porter cable 653 versa plane
There are two adjustments. First find the screw on the right side that allows loosening of rear baseplate. Once loose, another screw jacks the base up or down. They are both hex heads on mine.
Turn jack screw until a straight edge along the base just clears the cutter. Spin the cutter once to make sure both edges are the same depth and that both clear the straight edge.
For the front shoe, turn adjustment handle to zero. Remove the adjustment handle from the front shoe and find two vertical slots at the front. Two screws (hex heads) allow loosening of shoe. Once loose, the shoe can be adjusted by sliding up or down. With a straight edge held along the rear base and touching the front base, align the front shoe so straight edge barely clears blade and tighten screws. The front and back base should line up. Replace adjustment lever and recheck zero cut clearance as well as maximum depth. Readjust as necessary. If zero clearance is not an issue, the bases can be set to allow deeper cuts than factory specified. It's a powerful planer so if you're cutting softer woods, a deeper cut might be desired.
Apr 13, 2009 | Dewalt Tools & Hardware - Others
Ryobi 18V Hedge Trimmer Blade Question
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Aug 27, 2008 | Ryobi 18V Hedge Trimmer
Garden Logo
319 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
