Question about GE Profile Harmony DPGT750EC Electric Dryer
Ge dryer not heating
I have the GE profile dryer DPGT750EC1PL it has stopped heating. I read from the other comments that you have a manual for this. can you please send it to me [email protected] thanks
  • 2 more comments
  • delfrenchy Aug 28, 2008
    The dryer is a GE DPGT 750. Have had it for 3-5 years with no problems. It was heating this two days ago. No heat this afternoon but tub was rotating and blower was blowing. Tried restarting it with no change in performance. Tried to take it apart to get to the heating element. Haven't been able to figure out how to do that. Changed heating elements in our old dryers which was pretty easy.
  • heatheroden1 Sep 23, 2008
    what did you do to fix it mine is doing the same thing. Please forward if it worked to [email protected]
    thank you,
    heather
  • sgtshaver Oct 29, 2008
    My GE DX4500EG3WW dryer is not putting out any heat. It blows out air in the back and it turns, just no heat. How do I fix it?
  • lashay67 Feb 02, 2010
    Okay Im supposed to check the fuses, circuit breakers or the heating element. Can you tell me where these are located in my dryer. Harmony Profile
  • 734 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
  • Jason Dolan
    Jason Dolan Apr 18, 2014
    How do you get to the heating element?
    Habit-Forming:
    New Friend:
  • 20 Answers
Thnaks for the site
Posted on Mar 27, 2018
SOURCE:
Ge profile dryer does not heat at times
Sounds like one of two things.
1) you have a bad connection, specifically, a loose connection that is making contact once in a while.
2) one of the "overheat thermostat switches" is failing.
If you wish to fix it yourself, you will need to dismantle the machine and have a testing instrument to look for the problems.
Be advised, however, if you take it all apart and it happens to be on a "I will be working now, thank you very much" cycle, you may not find anything!
It really needs to be "not working" for the flaw to show up.
Be blessed.
Feb 22, 2013 | GE Profile Harmony DPGT750EC Electric...
My ge dryer model dpgt750ec1pl is running but no heat i was wondering if this style dryer is suppose to show some fault codes i thought it was the heat assembly but since itsnot showing any codes i thought...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101./
Apr 25, 2011 | GE Profile Harmony DPGT750EC Electric...
Runs but no heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
May 29, 2010 | GE Profile Harmony DPGT750EC Electric...
GE profile harmony dryer electric won't heat after first load
Did you end up replacing this thermistor? If so did that solve the problem? We are having the same issue and I don't want to waste time and $$.
Dec 22, 2009 | GE Profile Harmony DPGT750EC Electric...
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
OUR G.E. PROFILE DRYER MOD.# DPGT750EC1PL STARTS AND RUNS LIKE NORMAL, BUT THE BLOWER DOES'NT BLOW. WHAT DO WE NEED TO LOOK FOR SO WE CAN GET THIS DRYER RUNNING? THANKS.
The fan motor must be tested by energizing it and reading volts from timer control. If the fan is faulty it must be replaced, if there is no volts from timer control, then either wiring harness or timer control assembly must be replaced.
Jul 04, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge harmony dryer not heating up dpgt750ec1pl
If you hear the blower ramp up when you start the dryer and if slowly ramps down or quits all together then you need to replace the blower. If the dryer heats at all then look at the blower.
Jun 20, 2008 | GE Profile Harmony DPGT750EC Electric...
First use the dryers service mode and see what trouble code you are receiving.
It's called "Field Service Mode"
1. Press the POWER key to turn the dryer on.
2. Press HELP. The main help screen is displayed.
3. Press and hold MY CYCLES and BACK simultaneously for 3 seconds. Press EXIT to return to the HOME screen.
There's a 95% chance that it is your blower and your dryer should confirm that.
I just recently replaced the blower in my GE Profile Harmony as well. While I had my dryer apart, I also cleaned the heck out of it. Excellent opportunity to take your vaccum cleaner and get all of those dust bunnies out!
I purchased the blower from www.applicancepartpros.com for about $146 S&H included.
Part No. AP3791484 Item: Motor asm-blower Price $133.05 Plus Shipping.
Mar 12, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
1,352 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
vince
gbob59
Are you a GE Dryer Expert? Answer questions, earn points and help others
