Question about Viking 24 in. Professional Series VUD040 Stainless Steel (Premium) Built-in Dishwasher
The normal and economy lights are blinking and cannot get to wash through a full cycle. water is in the bottom of the washer
  • Viking Master
  • 3,247 Answers
You will have to check if the dishwasher is stuck in the drain cycle or wash cycle.
The normal and economy lights flashing means there is flooding in the unit.
Reset the unit by pressing START button for 4 secs. If the flashing does not stop then you have to call the technician. There may be a leakage which is causing the flood switch to activate.
Posted on May 21, 2011
  • mpn16 Jul 02, 2014
    DONT CALL A TECH USE THE POTS &PAN, AND NORMAL AND HIT THEM IN ORDER THREE TIMES, THEN PUSH CANCEL CLOSE THE DOOR, AND IT SHOULD RESET IT.
    i JUST DID IT ON MY VIKING PRO 325SS, AND IS WORKING NIOW.
Rinse cycle does not run water, timer stops working. Runs fine when filling for wash cycle, drain, and spin until it gets to the rinse on both normal and economy
Before replacing the water valve, turn off the cold water, and check to see if the screen on the cold water valve is clogged. It may be replaceable depending of the washer model. Otherwise, I clean these filters in the field with a small toothbrush and a little spray bottle.
Jun 13, 2016 | Washing Machines
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
How can I stop my washing machine end indicator light coming on before cycle has finished?.
sound very much like you have a blocked pump or a drainage block. If your machine outlet is connected to a push on spike under the sink, remove it and check Its not blocked. If that is clear CAREFULLY remove the filter cap, Usually on the bottom righthand side of the Machine. I say carefully because if there is water in the Machine it will pour out and flood so do it a bit at a time till its empty. Check the filter it may be clogged up, if it is thats your problem if not it needs further investigating. time to call the repair man. By the way whilst you may have economy 7 I would never advise putting your machine on at night and going to bed if anything should go wrong you are not there to switch off, Ive seen some real nasty stuff over the years where machines have gone rogue unattended, it really isn't a good idea although Thousands would disagree.
Aug 03, 2014 | Tricity Bendix Washing Machines
My Miele W1119 washer won't run. It was fine earlier today and I just completed a load of wash. When I started the next load on the Normal cycle, the timer lights to 58 minutes as always and the...
sounds like bushes mine done the same changed them now all good check it is not leaking water on to the bottom of machine this will activate the sensor to stop washing and drain water
Jun 04, 2017 | Miele Touchtronic W1119 Large Capacity...
My new electrolux front loader is not filling with water during the wash cycle. The clothes are soaked, but there is NO extra water in the bottom of the tub. It does have extra water in there during the...
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
Apr 21, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Washer fills slow only in the rinse cycle
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
Apr 28, 2017 | GE WBSR3140DW Top Load Washer
Our Kenmore Elite Calypso was running great. Put in a load to wash and turn it on as usual. Upon returning the basin was full of water and soap. Tried to get it to spin and it did nothing. We have removed...
remove as much water as possible lean washer back against wall remove bottom cover if pump has screws in bottom remove them and try cleaning pump HAVE TOWELS HANDY..if no screws probably older version they were bad for having stripped drive splines only fix was to replace pump
Sep 09, 2008 | Washing Machines
Frigidaire Washer won't drain water
My will start to cycle and then it will cease to spin. No grinding, no off balance noise-no spinning=no draining of water from tub/basin. Unplugged it for a full 4 minutes. Plugged it back in. Checked to see if washer was level-it wasn't. Made adjustments to ensure washer was level-EUREKA! washer finished cycle no problem. BOO-HISS! Two loads later, same issue as the first time-washer won't spin. Checked to see if washer was still level-it is, new issue-error coed E20 and all lights blinking. ANY suggestions?
Jun 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore ultra wash dishwasher 665.15762 blinking lights
It is likely there are one or more faulty buttons on the control panel. The console will have to be replaced.
Apr 28, 2008 | Dishwashers
Viking 24 in. Professional Series VUD040 Stainless Steel (Premium) Built-in Dishwasher Logo
610 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
