Question about Refrigerators
How do you add refrigerant to a kenmore fridge and what kind fo you use
  • 10,515 Answers
You have to be EPA certified to install freon in any appliance.
Freon is a greenhouse gas and regulated by the EPA. Any freon took out of system should be recovered.
Are you competent enough to work on appliances?
You have two lines on a compressor, large and small. I braze 2 -1/8" access fittings about 6" away from compressor. Then I install freon gauges to the fittings. I weigh the freon in with digital scales. Freon in a refrigerator is in a small amount and the charge is critical. If the freon is all gone, a deep vacuum will have to be pulled with a vacuum pump.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 21, 2011
How old is my Kenmore refrigerator #363.50237000 serial #04528329
Suggest you email or ring (if in US) Kenmore direct and ask them as they should be able to answer. Add a photo of the fridge may help or photo of the Product Tag yo copied the serial number from. Hope that helps.
Kenmore
Dec 30, 2014 | Kenmore Refrigerators
Can I run my kenmore bottom mount refrigerator from a generator that is not an inverter generator
Yes. The generator must be large enough to produce the necessary amperage to run the refrigerator. It doesn't matter if it's a inverter generator or not.
Aug 04, 2014 | Kenmore Refrigerators
I have power but both the fan and the compressor are not running. All the numbers that indicate the temperature setting are blinking. Is it a relay problem or a circuit board problem.
Your fridge could be in defrost mode. This only lasts fo a few minutes. If it does not start up after 30 min max your defrost timer may be bad. When your fridge kicks into defrost mode the timer turns on the defrost circuit which includes a heating element and a defrost limit switch and turns off the cooling circuit which includes the compressor and fans. The timer use to be located under the bottom of the fridge now its inside the fridge side usually under the top plastic shield or the back. If you locate the thermostate you can turn it manually with a flatblade screwdriver. good luck
Aug 16, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Vegetables keep freezing in the fridge crispers
You have to heat the coil in the back of the fridge. Take everything out and open up the back, then take a hair dryer and heat the coil. After doing this, adjust the heat settings on the freezer.
Nov 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bad tasting ice
disconnected your water line to your fridge and let it rum in to a bucket so you will have fresh water for your fridge but before plug it back to your fridge pour a example in to a cup and drink it to see how it theist like. if that don,t solve your problem, there is a way to get rid of bad rubber taste on the water , but is kind of hard to do first you need to take you refrigerator out side because is going to be messy find some kind of water pump and a bucket and some hose. disconnect the water line going out of the water valve to your ice make and rig your hose together whit that one. on the bucket pour a full bottle of Synthetic vinegar "yes the same stuff you put in your salt", make sure is synthetic not the natural kind using a pump flush your refrigerator whit the vinegar, you can add some water if you need if there is two water valves do the same on both. good luck.
Jun 12, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Warm refrig and freezer
You probably need some refrigerant added. There probably is a leak in the system that caused the lack of refrigerant. Get the leak fixed and add refrigerant before you blow your compressor too. Or get a new fridge.
Nov 04, 2008 | Kenmore 53642 / 53644 Side by Side...
Air Baffle sticks in Kenmore Elite refrgerator
look fo an air leak. could be at ice cube chute door on freezer.
Jim
Jul 27, 2008 | Refrigerators
Refrigerators Logo
282 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
