Video playback is only in B&W. Video "flickers" and varies in detail. Cleaned the heads and used a "head checker" to test for wear. Also, replaced 2 failing caps in power supply. Any idea on next step?
  • 1 more comment
  • mrpuhl May 22, 2011
    Don't know what happened to the beginnig of my question because it started out with: I have a panasonic VCR, model pv-s4566 that has a playback problem. (why that portion didn't get included, I don't know. Don't care as long as I can get some direction).
    Sorry, but the response is "lame". Did you read the second sentence that's posted? I am well aware of vcr functions (AS I had my own business) - hence I clean the heads with solution and chamios swabs first, use the "head checker" meter (have you ever used one, or know what it is)? to test for wear/abnormalities. After selling the business, I don't have the bench set- up/equipment I once had. At this point, I should have just put the $12.00 charge towards a schematic.
    Last comment! I HAVE worked with LEADER oscilliscopes. I am currently using a Fluke that can display wave forms. I also used the SENCORE VCR analyzer! The fact you don't know what a VCR head wear meter is shows how much you are "limiting" your self. You would not have qualified working in my shop. Good day!
  • 11,800 Answers
The signal coming from the heads is too weak. I'm assuming you have checked the signal cable coming from the drum to the board and its solderings. Since you have cleaned and checked the heads themselves it only leaves on thing - their circular connectors in the drum itself: either dirty or deformed.
Dismantle the drum head and clean it thoroughly.
Posted on May 23, 2011
    Top Expert:
  • Televison & ... Master
  • 75,462 Answers
Hello
What is the model number of your device?. Without it how can I post a solution before you? Provide these by FixYa please.
Posted on May 22, 2011
  • The Knight
    The Knight May 22, 2011
    Hello - Your device is a four head one VCR. Out of which these four heads [head tips] tow of them will be used at regular playing, and the other twos are used for super still, still advance and so on. If the regular pay tips gets dirty, the fault you described will occur. Play a clean casette, I mean, a new one without any recording or fungus infection, for some tiem. This will clear up any dirt or fungus, at moderate thickness. It is best to play a head cleaning casette, if you have. If these does not helps you, one out of two tips [regular one] has a break with it, and the drum assembly as a whole should be replaced with same type. OK.
  • The Knight
    Sir -- I haven't seen this type of testing equipents since 41 years of my regular service work. Have you seen a vectroscope? Have you seen an 8 channel Leader osilloscope? Have you seen the latest Fluke mutimeter that can display any waweform at field. I now owns an Authorised service center for Samsung and Philips at my motherland. OK. Good Bye.
Blaupunkt camcorder video 8 no picture on playback
Your heads are still dirty, You need to hold a piece of white photocopy paper against the heads and rub it to clean the dirt off. Don't use anything soft as it catches on the head and can cause damage.
Mar 09, 2012 | Video Cameras
After recording and replaying, the picture is "sliced up". I've tried cleaning head with dry tape, seemed to help but still there. Trouble is it seems to vary each time I play the same tape.
Do not use a head cleaner - they can damage the heads. Insert a brand new high quality tape and perform a record. Let it record through the entire tape. Then, play back an original prerecorded tape and check playback.
Nov 15, 2010 | Canon GL1 Mini DV Digital Camcorder
I have a Samsung DVD/VHS player and now the video does not work on the VHS. The sound is there and the DVD player works fine.What can I do? Ed
If you have sound on playback & the picture is snowy then I think it appears the video heads are dirty. Try a video head cleaner or better still, get them cleaned by a service centre. You can try to clesn them yourself but you need to be careful you do not damage the heads.
Jun 29, 2009 | Samsung Televison & Video
CCD-TR705e Sony video recorder hi 8 playback 3 beams
the camcorder flickers when viewing playback - pictures flickering
Dec 10, 2008 | Pure Digital Point and Shoot Video...
Head cleaning required
i have the JVC MiniDV Digital Video Cleaning Cassette. I began having trouble when I was shooting DV24P and when I went to playback I noted audio dropouts. I'm using SONY Premium DVM60 tapes. I began having Head Cleaning Required message. I have ran the Cleaning Cassette and the message disappears, but even trying a brand new tape, switching to DV playback i get the error message. Luckily, the shoot i was on the master audio was being captured by a secondary device and we were able to simply use the video from my camera. Since then, I was able to play & capture both the video & audio previously recorded in HDV30P and I didnt receive an error message. Now though I cannot record any DV audio without dropouts. When I tested just moments ago, I was able to record HDV and both video & audio were clean, but during playback I still received the Head Cleaning message. Is the record head different from the playback head? Can you manually clean the heads by removing the plastic door cover with a lintfree cotton swab and rubbing alcohol (obviously disconnecting and removing all power & powering off prior to cleaning), the same way any previous machine heads were cleaned in our stations? I think I may have got a batch of bad tapes that may have gunked up one of the heads some where and its getting missed by the cleaning tape. Is is possible that the head has been scratched, and will require replacement. If yes, is there any way to look at the head and detect this?
May 31, 2008 | JVC GY-HD100 Mini DV Digital Camcorder
Old Sony Handycam Video 8 CCD TR36
Head alignment (re-aligning the tracks) is not something we as owners can undertake - it has to be done professionally.
You can however quite safely clean the heads by using one of the dry cleaning tapes sold for the purpose. I have used an 8mm/Hi-8 cleaning tape made by TDK for a number of years with good results. Remember that if your heads are dirty both recording and playback will be affected and once you have cleaned the heads you need to test the camera by recording new footage and then playing it back to see if matters have improved. Good Luck.
Dec 27, 2007 | Sony Handycam DCR-TRV480 Digital Camcorder
Mosaic picture during playback
either use a manufacturer recommended head cleaning tape or have a tech give it a good hand cleaning. Panasonic head cleaning tapes work well.
Nov 14, 2007 | Panasonic AG-DVX100A Mini DV Digital...
Canon Gl2
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 18, 2007 | Canon GL2 Mini DV Digital Camcorder
Video Playback Sound but no picture
Sounds like the recording and playback heads are dirty. When was the last time you cleaned the heads? If you haven't, buy a Video cleaning kit which are cheap these days and run it through a couple of times. See if that clears it up.
Jul 18, 2007 | JVC Everio GZ-MG27 Camcorder
Camcorder
if all the indicators i.e. battery condition, play mark, counter, etc are visible on the screen then it can be a simple problem of dirty video head. try using a head cleaning cassette or do the head cleaning manually, Open the cover by removing three screws on the right hand side next to the viewfinder. Slide it little towards front and pick it up. The video head will be visible.
Sep 15, 2006 | Sony Handycam CCD-TRV107E Camcorder
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
